Joel
Joined: 06 Oct 2006 Posts: 57 Location: Bremerton, WA USA
Posted: Mon Jan 09, 2012 8:09 pm Post subject: Tygon tubing 5/16 id |
Kitfoxers,
I've located some yellow Tygon fuel line for my model 5, but had to buy a full roll of it. I'm selling eight foot lengths, enough for both wings to the header tank lines for $20 with pre-paid shipping anywhere in the U.S. My old fuel line was getting brittle and made wing folding problematic.
Joel Mapes
foxfloatflyer(at)hotmail.com
Kitfox V 912ULS
Full Lotus 1650s this summer!
Roger Lee
Posted: Tue Jan 10, 2012 5:53 am Post subject: Re: Tygon tubing 5/16 id |
Hi Joel,
Please don't take this the wrong way, I'm just curious.
Why didn't you use regular black rubber fuel line?
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Joel
Posted: Tue Jan 10, 2012 4:59 pm Post subject: Re: Tygon tubing 5/16 id |
Hi Roger,
I selected Tygon because I can see fuel flowing through it and because it is more flexible than rubber fuel line, making wing folding easier.
Joel Mapes Kitfox 5 912ULS
Joel
poasttown(at)yahoo.com Guest
Posted: Thu Jan 12, 2012 8:18 pm Post subject: Tygon tubing 5/16 id |
I switched to the yellow tubing a few years ago. I also used this tubing for my sight gauge. I found it difficult to see the fuel level so I purchased two fuel gauge floating balls from I think Univair and placed them in the sight guage. It works pretty good. One problem was that the balls were too large for the inside diameter of the tubing. I had to file/sand the balls down to the correct size. I know what some of you are thinking, I have too much time on my hands.
Sent: Thursday, January 12, 2012 5:04 PM
Subject: Re: Re: Tygon tubing 5/16 id
Not sure about other colors, but the yellow is translucent, so fuel flow is visible. Here is a link to a source on Amazon.
http://www.amazon.com/dp/B000PHF152/ref=asc_df_B000PHF1521858085?smid=ATVPDKIKX0DER&tag=hyprod-20&linkCode=asn&creative=395093&creativeASIN=B000PHF152
[quote]http://www.matronics.com/Navigator?=======================
rick(at)5mike3.com Guest
Posted: Fri Jan 13, 2012 6:50 am Post subject: Tygon tubing 5/16 id |
I think I answered my question.
I couldn't find the clear tube rated for fuel.
On Thu, 12 Jan 2012 17:04:17 -0800, Joel Mapes wrote:
mikeperkins
Posted: Sun Jan 15, 2012 1:36 pm Post subject: Re: Tygon tubing 5/16 id |
Clear polyurethane tubing sold by Wicks Aircraft under p/n 0545-107 (3/8" ID) is rated for fuel. And I've used it successfully for sight gauges with premixed fuel/oil. However, it comes in every size except 5/16" ID.
_________________ Mike Perkins
Havana, Illinois
Model I, 532, B gearbox, GSC prop |
mikeperkins
Make that 0585-107. ;-o
Havana, Illinois
Joel
Posted: Mon Jan 16, 2012 11:29 am Post subject: Re: Tygon tubing 5/16 id |
I replaced my wing tank to header tank fuel lines over the weekend with the 5/16 id Tygon fuel line. It was easy to work with and fit the barb fittings perfectly. I dipped the line in a little engine oil prior to sliding it over the fitting, installed the clamps and poured some fuel into the tanks. No leaks, and no more fuel vapor smell in the cockpit. I've got some tubing left from the roll I purchased. It takes about 8 feet at $1.85 per foot, plus $5.20 for shipping via USPS Priority Mail.
_________________ Joel Mapes Kitfox 5 912 ULS Aerocomp amphibs |
taildragon(at)msn.com Guest
Posted: Tue Jan 17, 2012 1:10 pm Post subject: Tygon tubing 5/16 id |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->
Since we have alcohol in our mogas in CA, I use
Bing Alcohol Resistant Fuel Line. It use to be sold by ACS but I didn't see it on-line just a few minutes ago. Another source might be:
http://shop1.actinicexpress.co.uk/shops/partsforaircraft/index.php?cat=Fuel_Hose_and_Fittings
or
http://www.skyshop.com.au/pdf/2009-2010_catalog%20119.pdf
(Click to Enlarge)
Bing Alcohol Resistant Fuel Line - sold by the foot
Blue fuel line that will not rot or deteriorate from the inside.
Will withstand 50 PSI and has a high elastic memory, ideal for using with barbed fittings in low pressure applications without the need for clamps
1/4" / 6mm internal diameter
7.49 KB |
26809 Time(s) |
occom
Joel
Posted: Tue Jan 17, 2012 5:13 pm Post subject: Re: Tygon tubing 5/16 id |
Unfortunately, none of the catalog stores, including Aircraft Spruce, sell 5/16 id fuel tubing. The 1/4 id line, either Bing or Tygon, works great for the vent line, but 5/16 id is required for the lines between the wing tanks and the header tank. If any of the usual mail order sources carried 5/16 id, I would not have needed to order a roll from a wholesale supplier. I even searched the Kitfox parts catalog at kitfoxaircraft.com but didn't find it.
All that said, if anyone wants to purchase enough 5/16 id Tygon line for their Kitfox without buying a whole roll of the stuff, I have a couple 8 foot lengths left.
mike>bentley
Joined: 10 Oct 2011 Posts: 17 Location: United States
Posted: Tue Jan 17, 2012 5:33 pm Post subject: Re: Tygon tubing 5/16 id |
Has anyone thought about USCG approved fuel line?
http://marineengineparts.com/shopsite_sc/store/html/page487.html
_________________ Mike Bentley
Joplin, MO
N5498B
Kitfox Model 4-1200
Jabiru 2200 #438
Rotec Aerosport LCH Heads
Prince Prop (64 x 34)
Ellison EFS-2 Throttle Body |
Joel
Posted: Tue Jan 17, 2012 5:56 pm Post subject: Re: Tygon tubing 5/16 id |
I just removed some Shields Fuel Feed Hose-5/16" I.D. from my Kitfox for 3 reasons:
1. There was a perpetual, small leak at one wing tank fitting. Just enough to generate fumes.
2. It is opaque, so I couldn't visually verify fuel flow.
3. It is fairly stiff, making solo wing folding a bit more difficult.
It is also a bit more expensive than Tygon or Bing line.
