bu131(at)swbell.net Guest
Posted: Mon Jan 09, 2012 2:57 pm Post subject: helmets (Noise) |
nothing a well trained flexum digitorum longus couldn't handle
To: yak-list(at)matronics.com
Sent: Mon, January 9, 2012 4:00:58 PM
Subject: RE: Re: helmets (Noise)
Roge⦠increased volume of the canal with increased number of vibrissae per mm of canal length along with the increased volume of the mass of desiccated mucous means increased resistance to flow. It really becomes a huge buggar to extract then! ( AKA The Woolley Booger)
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of cjpilot710(at)aol.com
Sent: Monday, January 09, 2012 2:55 PM
Subject: Re: Yak-List: Re: helmets (Noise)
Doc,
Would extended length of the nasopharynx have an effect?
Pappy
In a message dated 1/9/2012 2:24:43 P.M. Eastern Standard Time, viperdoc(at)mindspring.com (viperdoc(at)mindspring.com) writes:
Pappy,
Vibrissae and desiccated mucus in the nasopharynx will most definitely decrease O2 flow through the nose. (aka Buggars). I know you knew that.
;^O))
Doc
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com] ([email][mailto:owner-yak-list-server(at)matronics.com][/email]) On Behalf Of cjpilot710(at)aol.com (cjpilot710(at)aol.com)
Sent: Monday, January 09, 2012 11:28 AM
Subject: Re: Re: helmets (Noise)
OMG! Next we'll start talking about nose hair and its interference with oxygen flow!!!
Pappy
In a message dated 1/9/2012 11:43:18 A.M. Eastern Standard Time, brian(at)lloyd.com (brian(at)lloyd.com) writes:
On Mon, Jan 9, 2012 at 8:14 AM, Warren Hill <k7wx(at)earthlink.net (k7wx(at)earthlink.net)> wrote:
--> Yak-List message posted by: Warren Hill <k7wx(at)earthlink.net (k7wx(at)earthlink.net)>
Brian,
The Communications & Ear Protection system is what I had before the Westone system. Did not like it very much. Still had difficulty hearing the radio. It was touted as having superior noise reduction, but I found it lacking in many ways at the noise levels we experience in the CJ. My Lightseed noise reduction headset did a much better job, but would not allow me to wear a helmet.
Ear hair? You know, as we get older that damed ear hair gets tougher and can keep the expanding foam earpiece from sealing in the ear canal. I am guessing that it may be different for different people.
One way to find out is if silicone foam earplugs work. If they do, then the CEP earphones should work too.
Brian Lloyd, WB6RQN/J79BPL
3191 Western Dr.
Cameron Park, CA 95682
+1.767.617.1365 (Dominica)
+1.916.877.5067 (USA) http://www.matronics.com/Navigator?Yak-Listhttp://forums.matronics.com | 01
234567 | 890123456789012345
6
fish(at)aviation-tech.com Guest
Posted: Mon Jan 09, 2012 6:07 pm Post subject: helmets (Noise) |
Nels,
Yes you can modify it relatively easy.
I purchased a civilian mike & earphones form Gibson/Barnes, then a
converter that plugged into the single plug to two plugs.
Works great.
Laterrrrr
John Fischer
On 1/9/2012 1:11 PM, Nelson Sprague wrote:
Brian I have my jet helmet from my air force days can I modify it for use in the yak? Nels
Brian Lloyd<brian(at)lloyd.com> wrote:
> On Mon, Jan 9, 2012 at 8:20 AM, Herb Coussons<drc(at)wscare.com> wrote:
>> For clarification-
>> Is the Westone molded earpiece a com speaker?
> Yes.
>> Or just an earplug utilizing the existing coms of the helmet?
> No.
>> It appears the CEP option is an in the ear com device that connects to the
>> helmet coms, bypassing the earcup coms already installed?
> Not bypassing them. They are in parallel. You don't disable the stock
> earspeakers so the helment/headset will continue to work normally without
> the CEP earpieces plugged in.
> 3191 Western Dr.
> brian(at)lloyd.com
2.2 MB |
3939 Time(s) |
1.46 MB |
3939 Time(s) |
751.48 KB |
3939 Time(s) |
rijaeger(at)wausau.k12.wi Guest
Posted: Tue Jan 10, 2012 5:43 am Post subject: helmets (Noise) |
'Anyone got an extra / used helmet they'd be willing to part w/? Thanks!!
| Quote: | >> John Fischer <fish(at)aviation-tech.com> 1/9/2012 8:02 PM >>>
Nels,
Works great.
Laterrrrr
John Fischer
| Quote: | --> Yak-List message posted by: Nelson Sprague<nelsprague(at)hotmail.com>
>> For clarification-
> Yes.
> No.
> 3191 Western Dr.
> brian(at)lloyd.com
Posted: Tue Jan 10, 2012 8:00 am Post subject: helmets (Noise) |
Ah, nothing like blunt dissection!
Doc
On Jan 9, 2012, at 4:54 PM, Dr Andres Katz <bu131(at)swbell.net (bu131(at)swbell.net)> wrote:
[quote]nothing a well trained flexum digitorum longus couldn't handle
From: Roger Kemp MD <viperdoc(at)mindspring.com (viperdoc(at)mindspring.com)>
To: [url=mailto:yak-list(at)matronics.com]yak-list(at)matronics.com (yak-list(at)matronics.com)[/url]
Doc
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of cjpilot710(at)aol.com (cjpilot710(at)aol.com)
Doc,
Pappy
In a message dated 1/9/2012 2:24:43 P.M. Eastern Standard Time, [url=mailto:viperdoc(at)mindspring.com]viperdoc(at)mindspring.com (viperdoc(at)mindspring.com)[/url] writes:
Pappy,
;^O))
Doc
From: [url=mailto:owner-yak-list-server(at)matronics.com]owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)[/url] [mailto:owner-yak-list-server(at)matronics.com] ([email][mailto:owner-yak-list-server(at)matronics.com][/email]) On Behalf Of [url=mailto:cjpilot710(at)aol.com]cjpilot710(at)aol.com (cjpilot710(at)aol.com)[/url]
Pappy
In a message dated 1/9/2012 11:43:18 A.M. Eastern Standard Time, [url=mailto:brian(at)lloyd.com]brian(at)lloyd.com (brian(at)lloyd.com)[/url] writes:
On Mon, Jan 9, 2012 at 8:14 AM, Warren Hill <[url=mailto:k7wx(at)earthlink.net]k7wx(at)earthlink.net (k7wx(at)earthlink.net)[/url]> wrote:
--> Yak-List message posted by: Warren Hill <[url=mailto:k7wx(at)earthlink.net]k7wx(at)earthlink.net (k7wx(at)earthlink.net)[/url]>
Brian,
3191 Western Dr.
6[/url]
[url=http://www.matronics.com/Navigator?Yak-List]
[/url]
[url=http://www.matronics.com/Navigator?Yak-List] 7
Posted: Tue Jan 10, 2012 8:05 am Post subject: helmets (Noise) |
I have that adapter also to use with my current helmet. It is a bit weighty and unruly under G.
Doc
On Jan 9, 2012, at 4:29 PM, "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil> wrote:
Gibson-Barnes also has an adapter cable. Assuming you have the standard U-174 connector on the end of your military helmet, you can take out any pre-amp module that might have been in the O2 mask, and using the stock mike and earpieces, the adapter cable will match the impedances and you can use it with the original earpieces and microphone element. It converts the U-174 connector to what is usually used in general aviation, which is the mono headphone male connector, and the standard mike plug.. the nomenclature of which I forget! Sorry.
Anyway, I've tried it, it works.... but I'd recommend doing what the folks below are talking about versus this. Just letting you know it's there.
Mark
Posted: Tue Jan 10, 2012 2:04 pm Post subject: helmets (Noise) |
There is a long and a short version. Secure it to the airframe. The
female plugs are held in place with Adel clamps, so ......
Yes, it you leave it just hanging, it is a mess.
Mark
HawkerPilot2015
Posted: Thu Jan 12, 2012 2:12 am Post subject: Re: helmets (Noise) |
As an Aerial Gunner on USAF Combat Search and Rescue helicopters, we use CEP's with our 56/P helmets. In our VERY noisey environment, they come in handy but with some limitations. If they are not placed perfectly in your ear, they can start to hurt. The small wire will push against your ear and after a short time, start to cause a "hot spot". Also, the wire has to be managed and is not very stout. The ear cushion has to be replaced every 20 uses or so. They compliment the comm's and can be helpful. Sometimes, I just pull them out and put in ear plugs and crank the volume.
brian(at)lloyd.com Guest
Posted: Thu Jan 12, 2012 7:02 am Post subject: helmets (Noise) |
On Thu, Jan 12, 2012 at 2:12 AM, Tim Gagnon <NiftyYak50(at)fuse.net (NiftyYak50(at)fuse.net)> wrote:
| Quote: | --> Yak-List message posted by: "Tim Gagnon" <NiftyYak50(at)fuse.net (NiftyYak50(at)fuse.net)>
Using ear plugs and then cranking up the volume is what the motorcyclists typically do. It gets really noisy inside a motocycle helmet in an 80mph (or faster) breeze.
But I like the idea of CEP or something like it (in the ear canal) because active noise reduction does such a poor job attenuating upper midrange and high frequencies. Between shooting and flying (even though I always wear hearing protection) I now have tinnitus. Anything that reduces noise and makes the comm frequencies clearer helps a lot.
3191 Western Dr.
threein60(at)yahoo.com Guest
Posted: Thu Jan 12, 2012 8:27 am Post subject: helmets (Noise) |
That's exactly what makes ACCES from Westone great. They are formed from your own ear and can only fit in one way. Once installed correctly, they're no problem.
Larry Pine
--- On Thu, 1/12/12, Tim Gagnon <NiftyYak50(at)fuse.net> wrote:
Subject: Re: helmets (Noise)
Date: Thursday, January 12, 2012, 3:12 AM
http://forums.matronics.com/viewtopic.php?p=363135#36313Navigator?Yak-List" target=_blank>http://www.matronics.com/Navigator?Yak-; - MATRONICS WEB FORUMS -
| [quote][b]
