Trimming Cabin top
billz
PostPosted: Sat Jan 07, 2012 5:47 am    Post subject: Trimming Cabin top Reply with quote
I've got everything trimmed except the area around the left door. The bottom of the left door opening looks like it needs to be trimmed another 1/8 in? This will allow the top to drop the 1/8 in needed in the area just behind the door. My concern is making the area on the bottom of the door too thin. Perhaps I'm overly concerned, since there will be filling done in that area.
Looking for ideas from those who have been through this, already.
 Filesize:  543.4 KB
 Viewed:  4239 Time(s)
 Filesize:  602.67 KB
dave.saylor.aircrafters(a
PostPosted: Sat Jan 07, 2012 6:39 am    Post subject: Trimming Cabin top Reply with quote
How thin will it end up if you take off that last 1/8"?  There's not much if any of the vertical  flange left by the time you're done.  You may even end up taking off material from the bottom of the horizontal portion, that is, the section with the bevel on the outboard edge.  Look at the entire surface across the bottom where the cabin cover bolts to the door sill and make sure you don't have a high spot that's interfering and keeping the cover from settling down to onto the sill.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Sat, Jan 7, 2012 at 5:47 AM, billz <billz(at)roadrunner.com (billz(at)roadrunner.com)> wrote:
[quote] --> RV10-List message posted by: "billz" <billz(at)roadrunner.com (billz(at)roadrunner.com)>
http://forums.matronics.com/viewtopic.php?p=362654#362654
http://forums.matronics.com//files/img_1470_208.jpg
http://forums.matronics.com//files/img_1469_562.jpg
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
msausen
PostPosted: Sun Jan 08, 2012 6:04 am    Post subject: Trimming Cabin top Reply with quote
Man you guys with the pink tops sure have it nice. I was laughing to myself on the index mark conversation earlier that I couldn't even see 3 of the marks on. Y doors. Smile
Michael
johngoodman
PostPosted: Sun Jan 08, 2012 7:44 am    Post subject: Re: Trimming Cabin top Reply with quote
It's hard to tell because the pictures are way too big. From what I can tell, you are safe to cut that 1/8".
