Dynon Skyview Airspeed Calibration...
Site Admin
PostPosted: Mon Dec 26, 2011 7:43 pm    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
Dear Listers,
I've been flying the new 10" Dynon Skyview in the RV-6 for a few weeks now and it seems like the airspeed is reading maybe 10mph fast. The GS always reads 10mph or more slower than the True airspeed, no matter which way I fly with respect to the current wind. Looking through the configuration options on the Skyview, I'm not seeing parameters to calibrate the airspeed. If the airspeed were *slow* compared to the GS, I could envision making adjustments to the Pitot tube to get it in better alignment with slipstream. But *fast* is a head scratcher. If there's no electronic configuration parameters to adjust, what do you do? Are there Pitot line "attenuators" like for RF in coax? Wink
Matt
Matt "Red Dawg" Dralle
Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
Status: 42+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
email(at)jaredyates.com
PostPosted: Mon Dec 26, 2011 8:43 pm    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
Perhaps it is an issue with the way it is calculating tas. Do you have an ias indication? If so perhaps you could use a flight computer to verify. Have the Dynon folks had any input?
On Dec 26, 2011, at 22:39, Matt Dralle <dralle(at)matronics.com> wrote:
Dear Listers,
Matt
bbradburry(at)bellsouth.n
PostPosted: Mon Dec 26, 2011 9:06 pm    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
The problem is with your static port. Check out this link.
http://www.kilohotel.com/rv8/rvlinks/ssec.html
Bill B
bakerocb
PostPosted: Tue Dec 27, 2011 6:06 am    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
12/27/2011
Hello Matt, You wrote:
1) "Are there Pitot line "attenuators" like for RF in coax?"
Not pitot tube line attenuators, but both attenuators and augmentors in the
form of wedges before or after the static port portion of the pitot - static
system that can be used to tweak airspeed (and altitude) indications.
2) "But *fast* is a head scratcher. If there's no electronic configuration
parameters to adjust, what do you do?"
See this posting to the aeroelectric list for a more complete explanation of
the use of wedges to adjust airspeed indications:
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=88398860?KEYS=static_port?LISTNAME=AeroElectric?HITNUMBER=9?SERIAL=0431117943?SHOWBUTTONS=YES
A bit of search around in your Matronic's archive system on pitot static
systems and airspeed, particularly any posting on this arena by Kevin
Horton, will reveal a host of material for thought and action.
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
Time: 07:43:08 PM PST US
Subject: Dynon Skyview Airspeed Calibration...
Dear Listers,
and
10mph
respect
Skyview,
scratcher.
Matt
racerjerry
PostPosted: Tue Dec 27, 2011 7:12 am    Post subject: Re: Dynon Skyview Airspeed Calibration... Reply with quote
If the airspeed is reading too HIGH, a quick & dirty solution is to install a controlled leak in the pitot system. Install a “T� in the pitot line and use the third port as a drilled jet to vent to cabin air. Begin with a #80 drill bit and open up. For calibration, extend the new line (plastic tubing) into the cockpit so your co-pilot can make adjustments in flight.
You may want to verify that your altimeter is reading the correct altitude. An altitude error reading would point to problems with the static port/system. If a static system problem exists, fix this first before trying to calibrate airspeed.
Jerry King
pwmac(at)sisna.com
PostPosted: Tue Dec 27, 2011 7:19 am    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
Pitot is not an issue since it is pretty insensitive to angle of
attack. A quick check in just about any gas dynamics text will tell
you error vs angle of attack. My memory is bad, but its pretty hard
to get much of an error due to angle. Static location can be an
issue. The text book pitot static probe had many static ports and one
dynamic port.
Paul
At 08:39 PM 12/26/2011, you wrote:
Dear Listers,
Matt
n801bh(at)NetZero.com
PostPosted: Tue Dec 27, 2011 7:33 am    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
That is a viable fix.... Another easy and adjustable way is to go to a pet supply store and buy a small needle valve they sell for aquariums and plumb it in the line. That way you can dial in the exact bleed off.
electric-list(at)matronics.com
Subject: Re: Dynon Skyview Airspeed Calibration...
Date: Tue, 27 Dec 2011 07:12:09 -0800
--> AeroElectric-List message posted by: "racerjerry" <gki(at)suffolk.lib.ny.us>
If the airspeed is reading too HIGH, a quick & dirty solution is to install a controlled leak in the pitot system. Install a “Tâ€� in the pitot line and use the third port as a drilled jet to vent to cabin air. Begin with a #80 drill bit and open up.  For calibration, extend the new line (plastic tubing) into the cockpit so your co-pilot can make adjustments in flight.
Jerry King
http://forums.matronics.com/viewtopic.php?p=361733#361733
____________________________________________________________
53 Year Old Mom Looks 33
The Stunning Results of Her Wrinkle Trick Has Botox Doctors Worried
consumerproducts.com [quote][b]
kuffel(at)cyberport.net
PostPosted: Tue Dec 27, 2011 8:34 am    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
Matt,
Agree with others the symptoms indicate a static problem, specifically the
location is producing a vacuum when moving.
While introducing a "controlled leak" in the pitot side might fix the
airspeed error, probably at only one airspeed, it wouldn't fix the altitude
error also produced by static error.
Two very simple things you can do to confirm the problem and start toward a
solution.
First on takeoff set the altimeter to an exact division. Note as you speed
up and rotate if the altitude changes, even a little. Higher altitude
implies dynamic vacuum at the static port(s) which will produce the effect
you describe, lower altitude means dynamic pressure.
As a test, tape a wedge, or even a block such as a short piece or two of
tongue depressor, behind the port(s). If your error decreases you are on
the right track and set for a little cut and try with wedge size and
placement. Before starting be sure to have accurate error measurements.
Use the spreadsheet mentioned by others to get wind independent actual true
airspeeds. Or you are welcome to the spreadsheet I developed from the same
formula with 4 leg input. The 4th leg provides redundant information to
indicate the quality of the input data.
Tom Kuffel, CFI
EAA Flight Advisor
khorton01(at)rogers.com
PostPosted: Tue Dec 27, 2011 8:51 am    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
On 2011-12-27, at 11:12 , racerjerry wrote:
If the airspeed is reading too HIGH, a quick & dirty solution is to install a controlled leak in the pitot system. Install a “T” in the pitot line and use the third port as a drilled jet to vent to cabin air. Begin with a #80 drill bit and open up. For calibration, extend the new line (plastic tubing) into the cockpit so your co-pilot can make adjustments in flight.
If the airspeed is reading too, it is quite likely a problem with the static system. This could be a static system leak, or a poorly designed or located static port. Errors in the static system will affect both airspeed and altitude, so it is much better to find and fix the static source problem than it is to create a pitot leak too.
If you were to fiddle with the pitot system to fix the ASI indication (or provide ASI adjustments, as some EFIS systems allow), you would still have errors in the altimeter, and these can be safety of flight issues. The TCAS systems on larger aircraft provide guidance to avoid collision with you based on whatever altitude is reported by your transponder. If you have static system errors, the TCAS system may be giving commands that increase the risk of collision.
Static system leaks on RVs often produce ASIs that read about 10 kt too high, so the first thing to do is a static system leak check. Another common problem is flush mounted static ports on RVs, but this typically leads to ASIs reading too low.
Kevin Horton
RV-8
Ottawa, Canada
gerry.vandyk(at)shaw.ca
PostPosted: Tue Dec 27, 2011 9:22 am    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
Matt, I've got a couple of thoughts: The pitot / static system depends on
the static port being true ambient pressure, which is actually pretty
difficult to achieve in airflow. If you've got the port(s) in a spot that
generates a slight positive pressure on the static side you will
de-calibrate the airspeed to the low side, if there's negative pressure at
the port airspeed will read high. On the C172SP I rent there's a 1/8" high
lip on the fitting right beside the static hole. As the lip is at an angle
to airflow, I presume they dial in the static system by rotating the fitting
so the angle gives the correct pressure at the port for a specific speed
range. I've read somewhere (perhaps the Bingelis books) about making
adjustments to the static port by laying strips of tape in front of or
behind the port. As an example, the area in front of the windshield on a
stock car is a high pressure area where they take the induction to the
engine, I would suggest laying down a few thicknesses of tape behind the
port to start. Then again if your port is in an area of laminar flow,
tripping the flow in front of the port may have the same effect.
I believe once you have a modification that works you can make a permanent
'fix' that would be more efficient than a bleed port in the line.
Hope this helps.
Gerry
PostPosted: Tue Dec 27, 2011 1:39 pm    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
If you build in a leak in the system, I doubt that you will ever pass your
biannual transponder check. Just something to consider...
Bill B
Site Admin
PostPosted: Tue Dec 27, 2011 9:16 pm    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
At 07:39 PM 12/26/2011 Monday, Matt Dralle wrote:
Dear Listers,
Matt
Listers,
Thank you for all the great suggestions on resolving this airspeed issue! I took a look at the static ports on the RV-6 today and found that they are done using a flush head screw with a hole drilled in the center on either side of the fuselage. They do *not* protrude from the side of the plane at all. They are totally flush (see attached picture). Just for fun, I whipped up a couple of quick test deals using a 3/16" washer and some electrical tape. I poked a 1/16" hole in the center of the tape and then put the washer centered over the static ports on both sides of the fuselage (see attached pictures). Then, I went flying on this beautiful December 27 day in California!
I didn't have time to do any real scientific multi-leg testing, but I was amazed that the True Airspeed is now falling in a much more believable range compared to the GPS-derived ground speed. On one cross-country leg, I had an exactly 90 degree crosswind component and the True Airspeed and GPS Ground Speed were tracking exactly the same. Yahoo!
Obviously I need to do some additional, more scientific measurements and probably come up with a slightly more "permanent" washer arrangement, but the early returns are very promising! Smile
Thanks again for all the great feedback!
Matt
 Filesize:  57.45 KB
 Viewed:  15397 Time(s)
 Filesize:  136.56 KB
 Filesize:  124.68 KB
 Filesize:  68.35 KB
peter(at)sportingaero.com
PostPosted: Wed Dec 28, 2011 3:00 am    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
You could just cut the head off the pop rivet that Van's recommends and
stick that on with epoxy (or double sided tape to start with)?
Peter
> Dear Listers,
> Matt
Listers,
Matt
bakerocb
PostPosted: Wed Dec 28, 2011 5:15 am    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
12/28/2011
Hello Matt, I think that you are on the right track. The correct approach is
to use a semi circular wedge either before or aft of the static port in
order to achieve the results required. Here is the sequence that I went
through with my two static ports (one on each side of the fuselage) in order
to lower my airspeed indicator airspeed indication before I was satisfied
with the results:
1) Taped over one side static port and test flew.
2) Removed the first tape, taped over the other side static port and test
flew.
3) Put wedges aft of both side static ports using double sided sticky tape
and test flew.
4) Removed wedge from one side static port and test flew.
5) Switched the single wedge from one side static port to the other side
6) Declared victory and installed the single wedge more permanently.
Note that my focus was on good airspeed indication at landing approach
airspeeds, not at cruise airspeeds. On a calm / no wind day a check between
my airspeed indicator airspeed and my GPS ground speed on landing approach
are very nearly identical. I see no significant altimeter change indication
with airspeed change.
The next time I am out at the airport (if I remember) I will take a photo or
two of the single aluminum wedge on one of my static ports and email it to
you.
Good luck.
Listers,
took
using
are
a
the
amazed
compared
were
probably
Matt
bakerocb
PostPosted: Sat Dec 31, 2011 5:04 am    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
12/31/2011
Hello Matt, Attached are pictures of the two static ports on the foward
fuselage sides of my KIS TR-1:
0599 is the plain static port on the right side of the fuselage.
0602 is the same basic static port on the left side of the fuselage, but
with a self made aluminum wedge installed on it.
Since the wedge is installed aft of the opening in the static port it has
the effect of slightly increasing the static pressure that this port is
sensing and sending to the rest of the static portion of the pitot static
system. This slight increase in static pressure, in the airspeed indicator,
balances out or reduces the effective force being applied to the indicator
by the air pressure coming in from the pitot tube. The result is that the
airspeed indicator indicates a slightly lower airspeed than it would without
the wedge.
A wedge applied before the static port opening would have the opposite
effect.
Plan on doing a lot of test flying to get your wedge(s) fine tuned to
accomplish what you want in the way of airspeed reading without
significantly adversely affecting your altimeter readings.
My thinking is that it is more important to have the airspeed reading what
it should be in the approach speed arena rather than the cruise speed arena.
 Filesize:  746.27 KB
 Viewed:  15366 Time(s)
 Filesize:  752.85 KB
tim2542(at)sbcglobal.net
PostPosted: Sat Dec 31, 2011 6:48 am    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
I just did all this on my plane, the GRT equipment has a calibration utility built in that makes it a snap. Just fly the heading displayed and push a button for a given airspeed. Very simple &easy.
I would imagine the Dynon has something similar.
On Dec 31, 2011, at 5:00 AM, <bakerocb(at)cox.net> wrote:
Hello Matt, Attached are pictures of the two static ports on the foward fuselage sides of my KIS TR-1:
0602 is the same basic static port on the left side of the fuselage, but with a self made aluminum wedge installed on it.
Since the wedge is installed aft of the opening in the static port it has the effect of slightly increasing the static pressure that this port is sensing and sending to the rest of the static portion of the pitot static system. This slight increase in static pressure, in the airspeed indicator, balances out or reduces the effective force being applied to the indicator by the air pressure coming in from the pitot tube. The result is that the airspeed indicator indicates a slightly lower airspeed than it would without the wedge.
A wedge applied before the static port opening would have the opposite effect.
Plan on doing a lot of test flying to get your wedge(s) fine tuned to accomplish what you want in the way of airspeed reading without significantly adversely affecting your altimeter readings.
My thinking is that it is more important to have the airspeed reading what it should be in the approach speed arena rather than the cruise speed arena.
'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge."
<100_0599.jpg>
<100_0602.jpg>
