AFS / VP-X / Fast Stack Based Panel
Goto page 1, 2  Next
kearney
PostPosted: Sun Dec 11, 2011 8:43 am    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
Hi Andrew
Send me a note anytime. If I can help, I will. Here are the answers to your questions:
1. No. I have internal battery backups in the EFIS screens. I made a deliberate decision to eliminate any high power switches related to avionics etc.
2. I have 2 X AF4500's, and a center stack top to bottom (PMA8000B audio panel, Garmin GNS430 WAAS, Garmin SL30 NavCom, Garmin GTX 327 Txpndr, TruTrak RV10 autopilot)
3. See attached. I will take a few more and send later (after I put the panel back on).
4. My concern was that I did not want to install steam gauges / "normal" backups if at all possible. By having dual EFIS screens with battery backups and independent AHRS, I have complete redundancy. Although I have contemplated adding an Airspeed / Altimeter / T&B as backups, I didn't see the payback for the expense. I also have a Subaru engine that has added a few interesting twists. The engine is powered by two independent buses each with its own PC680 battery. The switches controlling the engine and related components are all lever lock mil-spec Honeywell - the best I could find. The buses also have their own circuit breakers (they are on the right side of the panel). Should the need arise, I can take both batteries off line so they are dedicated to the engine. I can also isolate the power to the engine (in the event of a fire etc). Effectively, the VP-X controls everything except the engine.
5. I purchased my cables from Tim at Approach Systems (Fast Stack). Given the cost, why would you want to build your own. Tim's cables have superb quality. Besides the potential for screwing up on home-grown cables is enormous. There are are a lot of pins to be mapped. Tim also provides very detailed info on the cables and how the pins are mapped. Seeing this, I can't imaging doing this on my own - I just wouldn't know where to start.
6. I started out with a VP-100. I considered a VP200 but realized that a) it duplicated much of what appears on my EFIS screens b) I didn't have the panel real estate. After I purchased the VP100, VP came out with the VP-X that integrated with the AFS EFIS. I talked to Marc at VP and he agreed to let me swap the -100 for the -X.
I goggled the PAR100EX. It looks very nice. For my install I would still go with the PMA800B. I like the features including the cell phone interface / music interface etc. As well, I wanted a redundant NavComm. The PAR100EX doesn't have the Nav side. For IFR, I need two independent sources of navigation, The GNS430 WAAS is one, the SL30 is the other. That being said, I also have another non-TSO'd WAAS puck GPS receiver I plan to install.
Something else you may not know. There is an AFS specific autopilot head made by TruTrak. It is very simple as the advanced features are controlled by the EFIS and not the AP head. I had originally ordered the TruTrak RV10 AP but later changed to the AFS version of TruTrak and saved some $$$$.
Cheers
Les
Sent: December-11-11 2:36 AM
To: kearney(at)shaw.ca
Subject: RE: Re: RV-10 Flap Positioner
Hi Les,
Your stack is almost exactly the same as the configuration I am looking at. If I may ask some questions and keep in touch that would be great.
1. Do you have VP-X bypass switches allowing direct power to the various instruments?
2. What is the full configuration of your panel by component?
3. Do you have any pictures of the panel?
4. What were the areas of concern that you addressed in the selection?
5. Did you purchase all the cables and Hub from Approach Systems Fast Stack, or did you make some of your own cables?
6. Why the VP-X and not the VP-200?
The stack I am looking at is as follows:
  • 2 x Advanced Flight Systems 5500 with GPS and backup batteries
  • Scorcerer RV-10 (Maybe AFS AP or Digitrack II)
  • Garmin GSN430 (Maybe a 430)
  • PAR100EX (Audio Panel/Coms combo)
  • GTX-327 (Transponder)
  • Vertical Power VP-200/400 or VP-X + harness
I would like any opinions you could offer on my selection, and any learnings you have developed on your systems.
Thanks in advance.
Andrew Long
www.ozrv10.com
Hi
This is one topic that I can add a bit of perspective. I have just powered
up the avionics on my -10 that uses a VP-X integrated with am AFS 4500
EFIS
screens with the avionics backbone being provided by Approach Systems Fast
Stack. No smoke and lots of pretty displays!
All the wiring was done by me, myself and I. Although I have read
everything
on the VP-X etc, I was amazed at how simple the wiring was done. With Tim
Hass's Fast Stack, I was left with wiring sensors, power lead, antennas
etc.
I started slowly as I was learning as I went but by the end I was pretty
confident as to how things would turn out. There is still a lot of work
involved in wiring - I was surprised about the amount of wire that goes to
the tail.
After seeing how the VP-X spins up on the EFIS, how easy it is to define
circuits and how they operate, how the number of high energy wires being
switched was reduced (all the VP-X switches are to ground), I can't
imagine
using a traditional bus bar for my avionics etc. It was beyond cool
watching
the avionics turn on, box by box, as I changed the VP-X configuration
settings on the EFIS.
With any system, it is wise to think about failure modse. I my case, if
the
VP-X fails I need only replace the box. Even if this happened in flight,
my
EFIS screens have internal backup batteries so it shouldn't be a huge
issue.
A final note, the support from Marc (VP) and Tim (Approach Systems) has
been
stellar. Both have been very helpful getting up a steep learning curve.
Cheers
Les
#40643
_____
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: December-10-11 2:41 PM
Subject: Re: Re: RV-10 Flap Positioner
I agree completely with this. I just finished wiring an airframe with a
VP-200. It took 2 days from start to finish. There is absolutely no way I
could have done that the traditional way, with the bus bars, switches,
breakers, etc. The VP keeps it clean and makes it easy, as well as giving
a
lot more information about a problem when you have it. In over 2,000 hours
flown on VP's that I have installed, I have had to send a total of one
unit
back to VP for repair, and have never had a completely dead unit. As Robin
said, you can't lump quality equipment made by VP with
"nothing-but-headache" stuff from BM.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Dec 10, 2011, at 3:47 PM, Robin Marks wrote:
I don't think you can lump VP and BMA in the same category. One is
exceptionally well thought out and tested system while the other is a
"let's
start selling it and then work on finishing the development over promising
while under delivering. I don't own a VP because my -10 build was too
early
but it is an impressive system. I kick myself for not adding it to my 8A
build.
Respectfully,
Robin
Ofdavidsoutpost(at)comcast.net
Sent: Saturday, December 10, 2011 12:29 PM
I could not agree more with Wayne. Yesterday I spent the day at my
buddies
cold (freezing) hanger to help trouble shoot electrical issues on the Cozy
MKIV we built. He went with a Blue Mountain power board that has been
nothing but trouble,,,, and you really need to know that stuff when it
fails. And yes,,,,you are grounded until fixed. The last time it failed
it
took an electronic engineer from Visteon who is a good friend to fix it!
No
Thanks. Not bashing VP at all. Its just not for me.
David Clifford
RV-10 Builder
Howell, MI
_____
Sent: Saturday, December 10, 2011 3:00:44 PM
Subject: Re: RV-10 Flap Positioner
--> RV10-List message posted by: "rv10flyer" <wayne.gillispie(at)gmail.com>
I used the show planes from Vans like Jessie is selling. Good deal if yoy
choose that route.
When it breaks it will be pulled out with a std flap switch put in place.
I
have the same problem as others with having to hit the down toggle
position
twice to go from 18 to 33 degrees flaps. Has to do with micro switches. It
is just one more thing to go bad...more money/wire/weight.
VP is a nice system unless it goes out then your grounded. I did not have
the money for it anyway. I have learned with hvac systems that the more
circuit boards you put on something the more expensive it is to fix and
you
better know your stuff to fix it yourself. One reason I do not sell 16
seer+
hvac systems.
Wayne Gillispie, A&amp;P 05/93 PP 10/08
Bldr# 40983SB Started 12/1/2009
N715WD Flying 12/1/2011. Paint 2012.
 Filesize:  84.03 KB
 Viewed:  14818 Time(s)
rleffler
PostPosted: Sun Dec 11, 2011 9:37 am    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
I would second Les's comments about the PSE8000BT. I went with a gtn650. My backup gps source is the farming unit afs sells. The sorcerer doesn't really buy you much for the extra expense over the afs ap. primarily just the ability to use the ils approach independently of the efis
I too went with the vp-x, primarily for economic reasons.  I wanted the vp-200, but had tighten the budget.
I wired the panel myself. It isn't hard just tedious.
I am planning on using a Gemini PFD as my backup. Unfortunately that won't ship for another month.
I hope to be able to power my panel up in a couple weeks.
On Dec 11, 2011, at 11:40 AM, "Les Kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
Hi Andrew
Cheers
Les
To: kearney(at)shaw.ca (kearney(at)shaw.ca)
Hi Les,
Thanks in advance.
Andrew Long
www.ozrv10.com
Hi
EFIS
everything
etc.
the tail.
imagine
watching
the
my
issue.
been
Cheers
Les
#40643
_____
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)
a
unit
Jesse Saint
C: 352-427-0285
F: 815-377-3694
"let's
early
build.
Respectfully,
Robin
Ofdavidsoutpost(at)comcast.net (Ofdavidsoutpost(at)comcast.net)
buddies
it
No
David Clifford
RV-10 Builder
Howell, MI
_____
From: "rv10flyer" <wayne.gillispie(at)gmail.com (wayne.gillispie(at)gmail.com)>
--> RV10-List message posted by: "rv10flyer" <wayne.gillispie(at)gmail.com (wayne.gillispie(at)gmail.com)>
choose that route.
I
position
you
seer+
hvac systems.
<IMG_0781.JPG>
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
Bob Turner
PostPosted: Sun Dec 11, 2011 1:14 pm    Post subject: Re: AFS / VP-X / Fast Stack Based Panel Reply with quote
For complete redundancy when you have 2 similar systems, I'd suggest not upgrading software in both units at the same time. Run one of them on the old software until you're reasonably certain the new software has no bugs.
I've seen one post here where a software bug crashed all of his interconnected systems.
Bob Turner
RV-10 QB
glastar(at)gmx.net
PostPosted: Sun Dec 11, 2011 1:36 pm    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
And do a backup before you upgrade so you can switch back
Werner
no bugs.
Jim Combs
PostPosted: Sun Dec 11, 2011 1:47 pm    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
One of the nice things about the setup that Les has is that the AP will fly the plane all by itself.  Heading changes can easily be dialed in to the AP along with climb and descent all without any support from the EFIS units.  Make sure one provides a redundant GPS source.   Given the 430W stays up you have a moving map with com and let the AP fly the plane. Bare bones but provides a solution if both EFIS units go south in IFR conditions.
Bob, You are correct to not upgrade both units until you have a reliable / working update.
Jim C
N312F - 300+ hours
On Sun, Dec 11, 2011 at 4:14 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
[quote]--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=360700#360700
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
le, List Admin.
RV-10 -> N312F - Flying as of 12/2008
rv10flyer(at)verizon.net
PostPosted: Sun Dec 11, 2011 3:19 pm    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
"I'd suggest not upgrading software in both units at the same time"
May be fine with the AFS, but one can not do a software upgrade on a Dynon
Skyview unless both/all units are upgraded. it's a networked system
(master/slave, per se) or redundancy that requires all hardware (AP servos,
EMS, PFD, etc) are the same version otherwise the red XXX is what one will
get. With VP, there are separate circuits for each display, so if I lose one
VP powered circuit I'll have the display go dark (although I have a battery
backup), if I lose another quadrant of the VP, which say my other display or
servos are on, I lose that specific feature, but the Dynon continues to run
with the other display being the master.
"I've seen one post here where a software bug crashed all of his
interconnected systems."- happened to a Glasair just this week. In his case
a reboot was missing after the upgrade but nevertheless, you are correct it
would crash the complete system.
along(at)aanet.com.au
PostPosted: Sun Dec 11, 2011 6:39 pm    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
Hi Les,Thanks for all that info. The AP you have runs independant of the EFIS correct? So if your EFIS go down, it will run as a full backup just like any other AP? Also, I wanted to know, do you still have the TruTrak RV10 autopilot as you listed in your setup. Are you using it, if not, what price would you like for it? TT doesn't seem to stock that version any longer. Is there a reason for that?Regards, Andrew Long www.ozrv10.com > Hi Andrew > > Send me a note anytime. If I can help, I will. Here are the answers to > your > questions: > > 1. No. I have internal battery backups in the EFIS screens. I made a > deliberate decision to eliminate any high power switches related to > avionics > etc. > > 2. I have 2 X AF4500's, and a center stack top to bottom (PMA8000B audio > panel, Garmin GNS430 WAAS, Garmin SL30 NavCom, Garmin GTX 327 Txpndr, > TruTrak RV10 autopilot) > > 3. See attached. I will take a few more and send later (after I put the > panel back on). > > 4. My concern was that I did not want to install steam gauges / "normal" > backups if at all possible. By having dual EFIS screens with battery > backups > and independent AHRS, I have complete redundancy. Although I have > contemplated adding an Airspeed / Altimeter / T&B as backups, I didn't see > the payback for the expense. I also have a Subaru engine that has added a > few interesting twists. The engine is powered by two independent buses > each > with its own PC680 battery. The switches controlling the engine and > related > components are all lever lock mil-spec Honeywell - the best I could find. > The buses also have their own circuit breakers (they are on the right side > of the panel). Should the need arise, I can take both batteries off line > so > they are dedicated to the engine. I can also isolate the power to the > engine > (in the event of a fire etc). Effectively, the VP-X controls everything > except the engine. > > 5. I purchased my cables from Tim at Approach Systems (Fast Stack). Given > the cost, why would you want to build your own. Tim's cables have superb > quality. Besides the potential for screwing up on home-grown cables is > enormous. There are are a lot of pins to be mapped. Tim also provides very > detailed info on the cables and how the pins are mapped. Seeing this, I > can't imaging doing this on my own - I just wouldn't know where to start. > > 6. I started out with a VP-100. I considered a VP200 but realized that a) > it > duplicated much of what appears on my EFIS screens b) I didn't have the > panel real estate. After I purchased the VP100, VP came out with the VP-X > that integrated with the AFS EFIS. I talked to Marc at VP and he agreed to > let me swap the -100 for the -X. > > I goggled the PAR100EX. It looks very nice. For my install I would still > go > with the PMA800B. I like the features including the cell phone interface / > music interface etc. As well, I wanted a redundant NavComm. The PAR100EX > doesn't have the Nav side. For IFR, I need two independent sources of > navigation, The GNS430 WAAS is one, the SL30 is the other. That being > said, > I also have another non-TSO'd WAAS puck GPS receiver I plan to install. > > Something else you may not know. There is an AFS specific autopilot head > made by TruTrak. It is very simple as the advanced features are controlled > by the EFIS and not the AP head. I had originally ordered the TruTrak RV10 > AP but later changed to the AFS version of TruTrak and saved some $$$$. > > Cheers > > Les > > > > _____ > > From: Andrew Long [mailto:along(at)aanet.com.au] > Sent: December-11-11 2:36 AM > To: kearney(at)shaw.ca > Subject: RE: Re: RV-10 Flap Positioner > > > Hi Les, > > Your stack is almost exactly the same as the configuration I am looking > at. > If I may ask some questions and keep in touch that would be great. > > 1. Do you have VP-X bypass switches allowing direct power to the various > instruments? > 2. What is the full configuration of your panel by component? > 3. Do you have any pictures of the panel? > 4. What were the areas of concern that you addressed in the selection? > 5. Did you purchase all the cables and Hub from Approach Systems Fast > Stack, > or did you make some of your own cables? > 6. Why the VP-X and not the VP-200? > > The stack I am looking at is as follows: > > * > > 2 x Advanced Flight Systems 5500 with GPS and backup batteries > * > > Scorcerer RV-10 (Maybe AFS AP or Digitrack II) > > > > * > > Garmin GSN430 (Maybe a 430) > * > > PAR100EX (Audio Panel/Coms combo) > * > > GTX-327 (Transponder) > > > > * > > Vertical Power VP-200/400 or VP-X + harness > > I would like any opinions you could offer on my selection, and any > learnings > you have developed on your systems. > > Thanks in advance. > > Regards, > Andrew Long > www.ozrv10.com > >> Hi >> >> This is one topic that I can add a bit of perspective. I have just >> powered > >> up the avionics on my -10 that uses a VP-X integrated with am AFS 4500 >> EFIS >> screens with the avionics backbone being provided by Approach Systems >> Fast > >> Stack. No smoke and lots of pretty displays! >> >> All the wiring was done by me, myself and I. Although I have read >> everything >> on the VP-X etc, I was amazed at how simple the wiring was done. With >> Tim >> Hass's Fast Stack, I was left with wiring sensors, power lead, antennas >> etc. >> I started slowly as I was learning as I went but by the end I was pretty >> confident as to how things would turn out. There is still a lot of work >> involved in wiring - I was surprised about the amount of wire that goes >> to > >> the tail. >> >> After seeing how the VP-X spins up on the EFIS, how easy it is to define >> circuits and how they operate, how the number of high energy wires being >> switched was reduced (all the VP-X switches are to ground), I can't >> imagine >> using a traditional bus bar for my avionics etc. It was beyond cool >> watching >> the avionics turn on, box by box, as I changed the VP-X configuration >> settings on the EFIS. >> >> With any system, it is wise to think about failure modse. I my case, if >> the >> VP-X fails I need only replace the box. Even if this happened in flight, >> my >> EFIS screens have internal backup batteries so it shouldn't be a huge >> issue. >> >> A final note, the support from Marc (VP) and Tim (Approach Systems) has >> been >> stellar. Both have been very helpful getting up a steep learning curve. >> >> Cheers >> >> Les >> #40643 >> >> _____ >> >> > From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint >> Sent: December-10-11 2:41 PM >> To: rv10-list(at)matronics.com >> Subject: Re: Re: RV-10 Flap Positioner >> >> >> I agree completely with this. I just finished wiring an airframe with a >> VP-200. It took 2 days from start to finish. There is absolutely no way >> I >> could have done that the traditional way, with the bus bars, switches, >> breakers, etc. The VP keeps it clean and makes it easy, as well as >> giving >> a >> lot more information about a problem when you have it. In over 2,000 >> hours > >> flown on VP's that I have installed, I have had to send a total of one >> unit >> back to VP for repair, and have never had a completely dead unit. As >> Robin > >> said, you can't lump quality equipment made by VP with >> "nothing-but-headache" stuff from BM. >> >> Jesse Saint >> Saint Aviation, Inc. >> jesse(at)saintaviation.com >> C: 352-427-0285 >> F: 815-377-3694 >> >> On Dec 10, 2011, at 3:47 PM, Robin Marks wrote: >> >> >> >> I don't think you can lump VP and BMA in the same category. One is >> exceptionally well thought out and tested system while the other is a >> "let's >> start selling it and then work on finishing the development over >> promising > >> while under delivering. I don't own a VP because my -10 build was too >> early >> but it is an impressive system. I kick myself for not adding it to my 8A >> build. >> >> Respectfully, >> Robin >> Do Not Archive >> >> > From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf >> Ofdavidsoutpost(at)comcast.net >> Sent: Saturday, December 10, 2011 12:29 PM >> To: rv10-list(at)matronics.com >> Subject: Re: Re: RV-10 Flap Positioner >> >> I could not agree more with Wayne. Yesterday I spent the day at my >> buddies >> cold (freezing) hanger to help trouble shoot electrical issues on the >> Cozy > >> MKIV we built. He went with a Blue Mountain power board that has been >> nothing but trouble,,,, and you really need to know that stuff when it >> fails. And yes,,,,you are grounded until fixed. The last time it failed >> it >> took an electronic engineer from Visteon who is a good friend to fix it! >> No >> Thanks. Not bashing VP at all. Its just not for me. >> >> David Clifford >> >> RV-10 Builder >> Howell, MI >> >> >> >> _____ >> >> >> > From: "rv10flyer" <wayne.gillispie(at)gmail.com> >> To: rv10-list(at)matronics.com >> Sent: Saturday, December 10, 2011 3:00:44 PM >> Subject: Re: RV-10 Flap Positioner >> >> --> RV10-List message posted by: "rv10flyer" <wayne.gillispie(at)gmail.com> >> >> I used the show planes from Vans like Jessie is selling. Good deal if >> yoy >> choose that route. >> >> When it breaks it will be pulled out with a std flap switch put in >> place. >> I >> have the same problem as others with having to hit the down toggle >> position >> twice to go from 18 to 33 degrees flaps. Has to do with micro switches. >> It > >> is just one more thing to go bad...more money/wire/weight. >> >> VP is a nice system unless it goes out then your grounded. I did not >> have >> the money for it anyway. I have learned with hvac systems that the more >> circuit boards you put on something the more expensive it is to fix and >> you >> better know your stuff to fix it yourself. One reason I do not sell 16 >> seer+ >> hvac systems. >> >> -------- >> Wayne Gillispie, A&amp;P 05/93 PP 10/08 >> Bldr# 40983SB Started 12/1/2009 >> N715WD Flying 12/1/2011. Paint 2012. >> >> >> >> >> >> > > [quote][b]
Bob Turner
PostPosted: Sun Dec 11, 2011 7:02 pm    Post subject: Re: AFS / VP-X / Fast Stack Based Panel Reply with quote
If you want an autopilot that can stand alone, I'll put in a pitch for Trio.
I have no connection to the company, it's just that I see them as the 'little guy' and I think competition with the big guys is a good thing. With their recent price reduction they are very competitive.
I cannot vouch for their interface with AFS; but I have a GRT EFIS (HX) and it interfaces perfectly with it. And, works fine in a stand-alone mode.
Of course like all these autopilots it can only follow a GPS signal, not an ILS or VOR, in the stand alone mode.
If you decide to go this route be sure to order the auto pitch trim option. I use this even when hand-flying (it can be used when the servos are off) for a very fine pitch trim adjustment.
Bob Turner
RV-10 QB
kearney
PostPosted: Sun Dec 11, 2011 7:07 pm    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
Hi Andrew
I have yet to investigate all the possible A/P EFIS failure modes. I suspect the A/P would work quite fine without the EFIS screens, however. It would mean just a bit more work to get the data into the A/P head. Perhaps someone more knowledgeable than I can get a more authoratiative answer - I still have a stack of manuals to read.
I don't have the TruTrak RV10 A/P (never did). I changed my order before it was shipped.
Cheers
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Andrew Long
Sent: December-11-11 7:35 PM
Subject: Re: AFS / VP-X / Fast Stack Based Panel
Hi Les,
Andrew Long
www.ozrv10.com
Hi Andrew
your
questions:
avionics
etc.
panel back on).
backups
each
related
so
engine
except the engine.
it
go
said,
Cheers
Les
_____
Hi Les,
at.
instruments?
Stack,
learnings
Thanks in advance.
Andrew Long
www.ozrv10.com
> Hi
> powered
> EFIS
> Fast
> everything
> Tim
> etc.
> to
> the tail.
> imagine
> watching
> the
> my
> issue.
> been
> Cheers
> Les
> #40643
> _____
> I
> giving
> a
> hours
> unit
> Robin
> Jesse Saint
> C: 352-427-0285
> F: 815-377-3694
> "let's
> promising
> early
> build.
> Respectfully,
> Robin
> Do Not Archive
> Subject: Re: RV10-List: Re: RV-10 Flap Positioner
> buddies
> Cozy
> it
> No
> David Clifford
> RV-10 Builder
> Howell, MI
> _____
[quote]> To: rv10-list(at)matronics.com
> yoy
> choose that route.
> place.
> I
> position
> It
> have
> you
> seer+
> hvac systems.
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
Jim Combs
PostPosted: Sun Dec 11, 2011 7:10 pm    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
I am flying the same configuration as Les except I have the AFS AP (TT with different software).  The Static and Pitot are plumbed into both EFIS units and the AP.  GPS receivers are also wired into both EFIS units and the AP as well.
Holding the AP Engage button on the stick for 3 seconds gets you into AP stand alone mode (heading and alt hold).  Pressing the EFIS button on the AP couples the EFIS and AP together to allow the Flight Director in the EFIS to command the AP.  Works very well.
Jim C
N312F 300+ hours
kearney
PostPosted: Sun Dec 11, 2011 7:23 pm    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
Hi Jim
My A/P is a TruTrak branded with the AFS logo. Is that different from yours.
Cheers
Les
On 2011-12-11, at 8:06 PM, Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote:
[quote]I am flying the same configuration as Les except I have the AFS AP (TT with different software). The Static and Pitot are plumbed into both EFIS units and the AP. GPS receivers are also wired into both EFIS units and the AP as well.
Jim C
N312F 300+ hours
PostPosted: Sun Dec 11, 2011 8:13 pm    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
Hi Jim,Does that AP have ILS/GPS RNAV approach capability (i.e. with it navigate alt as well as heading?)My want.... is basically to have a 3-axis AP that can be managed independant of the EFIS should it fail (shounds like this does) and can be coupled to a ILS/GPS RNAV approach. Does this fit the bill? Sounds like it does, just clarifying..... Smile Regards, Andrew Long www.ozrv10.com > I am flying the same configuration as Les except I have the AFS AP (TT > with > different software). The Static and Pitot are plumbed into both EFIS > units > and the AP. GPS receivers are also wired into both EFIS units and the AP > as well. > > Holding the AP Engage button on the stick for 3 seconds gets you into AP > stand alone mode (heading and alt hold). Pressing the EFIS button on the > AP couples the EFIS and AP together to allow the Flight Director in the > EFIS to command the AP. Works very well. > > Jim C > N312F 300+ hours > [quote][b]
Bob Turner
PostPosted: Sun Dec 11, 2011 8:22 pm    Post subject: Re: AFS / VP-X / Fast Stack Based Panel Reply with quote
Neither the TruTrak, nor the Trio, will fly an ILS without coupling to an EFIS.
If you get them with the GPSS/GPSV options, they will fly an LPV approach without an EFIS. They need the GPS signal, of course, to do this.
Your EFIS needs to have an ARINC interface to couple to them for the ILS.
Bob Turner
RV-10 QB
PostPosted: Sun Dec 11, 2011 9:01 pm    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
Hi Bob,But you can dial in altitude and heading and AP will follow correct? Which means that it runs independantly. That is fine. I would couple the Heading to the EFIS and the Garmin GPS with an ability to uncouple as per your setup. Then I have an independant AP if all else is lost that can manually be tuned in.Do you know which of the AP's from TruTrak and/OR AFS do this? Do they all?Regards, Andrew Long www.ozrv10.com > --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu> > > Neither the TruTrak, nor the Trio, will fly an ILS without coupling to an > EFIS. > If you get them with the GPSS/GPSV options, they will fly an LPV approach > without an EFIS. They need the GPS signal, of course, to do this. > > Your EFIS needs to have an ARINC interface to couple to them for the ILS. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=360728#360728 > > > > > > > > --> http://www.matronics.com/contribution > > > > > [quote][b]
kearney
PostPosted: Sun Dec 11, 2011 9:57 pm    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
Andrew
This manual show give you the info you want regarding the AFS ap.
http://www.trutrakap.com/documents/AFS%20Pilot%20Installation%20Manual.pdf
Cheers
Les
PostPosted: Mon Dec 12, 2011 3:26 am    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
Thanks for your help. I appreciate it. Thanks.Regards, Andrew Long www.ozrv10.com > --> RV10-List message posted by: LES KEARNEY <Kearney(at)shaw.ca> > > > Andrew > > This manual show give you the info you want regarding the AFS ap. > > http://www.trutrakap.com/documents/AFS%20Pilot%20Installation%20Manual.pdf > > Cheers > > Les > > > ---
rleffler
PostPosted: Mon Dec 12, 2011 4:01 am    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
Not entirely true. The Trutrak Sourcerer has the capability. But whether
the additional expense is worth the added value is another discussion.
Check out the following table.
http://www.trutrakap.com/autopilot2_2.html
Bob Leffler
N410BL - Phase I
dlm34077(at)q.com
PostPosted: Mon Dec 12, 2011 6:50 am    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
My TT VSGV has a switch (mine(AP signal source)) which allows (1) track and
pitch synchronization, altitude hold; (2) LNAV VNAV with the Cheltons and
(3) LNAV with the GRT Sport.
msausen
PostPosted: Mon Dec 12, 2011 10:44 am    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
I also have a similar configuration using a pair of AFS, TT AFS AP, VP200, etc. I have a switch next to the AFS TT AP that will switch ARINC inputs from the AFS units to the GTN650 so in addition to the AP alt/hdg mode I can drive the AP directly from the GTN if I want.
Michael
Sent from my iPad2
On Dec 11, 2011, at 9:17 PM, "Jim Combs" <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote:
[quote] I am flying the same configuration as Les except I have the AFS AP (TT with different software). The Static and Pitot are plumbed into both EFIS units and the AP. GPS receivers are also wired into both EFIS units and the AP as well.
Jim C
N312F 300+ hours
ectric.com
builthelp.com
ics.com
msausen
PostPosted: Mon Dec 12, 2011 10:47 am    Post subject: AFS / VP-X / Fast Stack Based Panel Reply with quote
By itself no, but when coupled with the AFS efis or other ARINC input yes.
Michael
Sent from my iPad2
On Dec 11, 2011, at 10:26 PM, "Andrew Long" <along(at)aanet.com.au (along(at)aanet.com.au)> wrote:
[quote] Hi Jim,
Andrew Long
www.ozrv10.com
> with
> units
> as well.
> Jim C
> N312F 300+ hours
ectric.com
builthelp.com
ics.com
Goto page 1, 2  Next
Page 1 of 2
