PSPRV6A(at)aol.com Guest
Posted: Tue May 23, 2006 8:23 am Post subject: RV-List Digest: 26 Msgs - 05/22/06 Carb ice |
One of the best carb ice detectors is EGT. Carbureted Lycomings will
develop small amounts of ice under surprisingly clear conditions. The first
symptom if you are cruising fully leaned will be a small drop in EGT, no change in
power. If EGT recovers to normal lean cruise temp after a SHORT application
of carb heat, you had a trace of ice. This is common on those perfect clear
mornings. 25 years of flying the same Cessna with the 0-320 E2D engine gave
lots of familiarity with this. Paul S. Petersen, RV6A building, flying
soon
