Dennis Thate
Posted: Wed Nov 30, 2011 4:00 pm Post subject: Primer Kit Installed |
503 Rotax Kolb Firestar
67.44 KB |
17722 Time(s) |
44.83 KB |
17722 Time(s) |
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern |
David d.
Joined: 04 Jul 2011 Posts: 60 Location: Fitzgerald Ga.
Posted: Wed Nov 30, 2011 6:12 pm Post subject: Re: Primer Kit Installed |
Hi Dennis,
Was your 503 hard to start?
Does it also have a choke?
David d.
_________________ Kolb Mark IIIX 582 Blue head |
Posted: Wed Nov 30, 2011 6:56 pm Post subject: Primer Kit Installed |
David d.
David D/Kolbers:
Don't think the 503 has choke, but an enricher.
The enricher does primarily the same thing a primer does, shoots a rich load
of fuel into the intake.
There is an enricher jet and an enricher well built into the float bowl of
the Bing carb. With the throttle closed and enricher pulled full on, the
idle circuit is bypassed. As soon as the engine turns over, the contents of
the enricher well are sucked into the engine and the engine will operate at
a richer mixture through the enricher jet. If the throttle is not closed,
the charge in the enricher well will not be sucked into the engine.
If you don't read the operators manual and use the proper procedure the 503
will be difficult to start without a primer in cold weather. However, do it
correctly, and she will crank every time.
Bing uses the same basic enricher system for all the Rotax two strokes and
four strokes.
Personally, I don't want any fuel lines routed into the cockpit.
_________________ John Hauck
Titus, Alabama |
byoungplumbing(at)gmail.c Guest
Posted: Wed Nov 30, 2011 8:08 pm Post subject: Primer Kit Installed |
| Quote: | >>>>>>>>>>>>>>>>>>>>.
another thing that helps in cold weather. I pull the enrichener and close
the throttle,,,, then when I do a walk around,,, I hand prop a few
blades... that will empty the enrichener bowl into the manifold and
cylinders. when I get in and start the engine,,, I get a second burst of
fuel, and with everything primed, it starts up extremely quick. the
other thing that helps is make sure the plugs are gaped properly.
boyd
Posted: Wed Nov 30, 2011 9:27 pm Post subject: Primer Kit Installed |
boyd
Boyd Y/Kolbers:
That is a good idea. Glad you shared that with us.
On my 912ULS, if I have a problem starting in cold weather, and so far I
have not had a problem starting with the enricher well below freezing, I
could wait a few seconds with the electric boost pump on to refill the bowl
and the enricher well, then hit it again to attempt to start.
It is better to go to close with the spark plug gap than what the book calls
for, or to wide. The 912ULS calls for .028". I gap for .020 to .025". If
the gap gets too big, it will not fire across them at start up, although it
will run just fine if you luck up and get it started.
Titus, Alabama - 28F and dropping.
Titus, Alabama |
Posted: Wed Nov 30, 2011 9:43 pm Post subject: Primer Kit Installed |
boyd
maybe I should explain,,, when I say I pull a few blades... make sure the
ignition switches are off,,, I stand behind the prop arc, then I put my
left hand on the descending blade, and my right hand on the ascending
blade,,, and when I pull it through I do it as quickly as I can,,, I
usually get 3 and sometimes 4 compression per pull. I have used this
method to start the engine when the battery was dead.
boyd y
Arksey(at)aol.com Guest
Posted: Wed Nov 30, 2011 9:47 pm Post subject: Primer Kit Installed |
my firestar with the 503 now starts very good with a pull starter...some people convinced me to do away with the enricher and use a primer which I did...the 503 starts the first pull when primed correctly....and I keep it running at times with the primer until it is warmed up...however my original problem with starting in the beginning was bad plug wires and carbs not set up right. I now I sort of think that with everything correct the enrichers should do the job and have some advantages...for what it is worth....jim swan just put the firestar away for the winter.....lots of snow up here now... another thought I suspect the enricher may need maintence more often for proper seal if used...
Jim Swan Kolb Firestar ll, 503 Rotax , 6147 Wilcox Rd., Eaton Rapids, Mi 48827 ph 517-663-8488 GPS GPS FOR MY RUNWAY N 42 deg 28.581 W084deg 44.825
In a message dated 12/1/2011 12:27:46 A.M. Eastern Standard Time, jhauck(at)elmore.rr.com writes:
| Quote: | --> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com>
boyd
Boyd Y/Kolbers:
Titus, Alabama - 28F and bsp; (And Get Some AWESOME FREE o find ifts bsp; lder's LP you for ; -Matt Dralle, List e ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
johngilpin
Posted: Thu Dec 01, 2011 12:31 am Post subject: Primer Kit Installed |
| Quote: | <...If the throttle is not closed, the charge in the enricher well will not be sucked into the engine....>
Boy, isn't that the truth!
How many times have you seen someone can't get a Rotax 2-stroke to start until you insist that they hold the throttle completely closed, then it fires next pull.....
JG | [quote][b]
David d.
Posted: Thu Dec 01, 2011 4:50 am Post subject: Re: Primer Kit Installed |
While we are on this starting issues.
If I have a balky starting engine on any of my gadgets. Chain saws, weed eater, tractor etc. I do not wear out the starter nor pull the cord out by the roots. Just a small shot of starter fluid or raw gas.
Therefore just a question. Do you use starting fluid on your airplane engine?
I have not and probably will not. But I have not seen this mentioned on any of the forums.
David d.
Mike Welch
Posted: Thu Dec 01, 2011 5:15 am Post subject: Primer Kit Installed |
Starting fluid has NO place anywhere near an airplane engine, unless you are going to wash
parts in it (ether). Starting fluid places a tremendous strain on an engine, and there is NO
way you can determine how much strain you are actually doing to it.
If you have to depend on starting fluid to get an airplane motor running, then the fuel
delivery system is not set up correctly, or at least the choke/primer is NOT correct.
Keep the starting fluid around for your tractor. Keep it away from an airplane. Just my opinion.
Mike Welch
Posted: Thu Dec 01, 2011 7:21 am Post subject: Primer Kit Installed |
engine?
of the forums.
David d.
No,,,, i dont own a can of starting fluid... ive heard of people blowing
head gaskets using the stuff.
boyd
rickofudall
Posted: Thu Dec 01, 2011 1:41 pm Post subject: Primer Kit Installed |
Mike, I'll take the alternate view. I use starting fluid on any bulky starting engine regardless of what it powers, BUT, I only fog it around the aircleaner or, if the intake tract is restrictive, I'll pull the air cleaner cap and fog it, then close up and start. The key is using good sense. If you spray down the carb throat and wash the oil off the cylinders you deserve the damage you'll get. As with most things in life, moderation is the key.
Rick Girard
On Thu, Dec 1, 2011 at 7:13 AM, Michael Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: Michael Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)>
| Quote: | --------
Mike Welch
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
http://forums.matronics.com
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
pcarillonsr(at)neo.rr.com Guest
Posted: Thu Dec 01, 2011 3:30 pm Post subject: Primer Kit Installed |
On 12/1/2011 4:40 PM, Richard Girard wrote: | Quote: | Before I peeled off the left landing gear of dear old Zulu Delta, I had a chance to test which works best, primer or starting carbs (enrichners, but they really are small separate carb that only work when the throttle is completely closed as noted). Whereever my 582 ends up, most probably on my old Firestar, it's will have enrichners and no primer. Ken's 582 starts much easier than mine, especially in cold weather.
A side note to using the primer with an oil injection engine is your probably shooting raw gas into the cylinders at start up. I don't know if this little bit of raw gas will hurt any thing or not, but might be something to think about. Anybody know the answer?
Jack Carillon Akron Oh. FS II
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
russk50(at)gmail.com Guest
Posted: Thu Dec 01, 2011 4:26 pm Post subject: Primer Kit Installed |
Mike, I agree completely. I've seen a generator's camshaft broken by use of ether. I do use it, but only on a cheapie leaf-blower that was wearing out my right shoulder -- if it dies, no big deal.
NOT for any aircraft engine use.
Russ K
On Dec 1, 2011, at 8:13 AM, Michael Welch wrote:
Mike Welch
Posted: Thu Dec 01, 2011 7:01 pm Post subject: Primer Kit Installed |
Kolbers,
When the FireFly was pushed around by the Rotax 447, I used the enricher to
get it started. It was a pain in that in cold weather, it took too many
pulls to get the engine started. Even though I pumped the carb bowl full of
gas, a few times, I pushed the FireFly back in the hangar because I could
not get it started. After reading up about the engine, I found that the 447
spark jumps both plugs at the same time. I re gapped the plug to a lesser
gap and things improved.
When I changed to the Victor 1+, I had the same carburetor, a Bing. I
mounted a push bulb on the float bowl. While the FireFly was in the hangar,
I would open the valve, squeeze the press bulb two times, close the valve,
and then pull the propeller through two compressions. Then I would pull the
plane out of the hangar, get into my gear and into the cockpit. By priming
early, it gives the gas plenty of time to vaporize inside the crank case and
the cylinder. Never fail, the engine would fire up on the first or second
turn of the crank. The nice thing about this primer installation is that
there are no long connecting tubes to the cockpit.
With the MZ 34, I installed the same system on the Tillotson carburetor.
This time I used a ready made push bulb rather than one scavenged from a
dead weed wacker. The start process is the same as described above, and the
engine fires the first time over.
If you would like to see these setups the Bing primer may be found at:
http://jackbhart.com/firefly/firefly89.html
And the Tillotson at:
http://jackbhart.com/firefly/firefly153.html
I do not believe there is any need for concern about shooting enough gas to
prime an oil injected engine. The amount is quite minuscule. Also, when I
tore down the 447 and the Victor 1+, I was amazed as to how much oil was
inside the engine.
Jack B. Hart FF004
Winchester, IN
Posted: Thu Dec 01, 2011 7:23 pm Post subject: Primer Kit Installed |
Also, when I tore down the 447 and the Victor 1+, I was amazed as to how
much oil was inside the engine.
Jack B. Hart FF004
Jack H/Kolbers:
Got to turn the engines to clear the crankcases.
Low rpm's on a two stroke is murder on them. They like to turn.
Titus, Alabama |
undoctor
Joined: 21 Oct 2008 Posts: 212 Location: Bethelhem, PA
Posted: Thu Dec 01, 2011 7:41 pm Post subject: Primer Kit Installed |
Kolbers,
I generally allow my FF to idle for a minute or two after landing to
cool it down. Is this counter-productive? I like my engine and want to
treat it with as much kindness as I can.
Dave Kulp
Bethlehem, PA
FireFly 11DMK
On 12/1/2011 10:21 PM, John Hauck wrote:
Jack B. Hart FF004
Jack H/Kolbers:
Posted: Thu Dec 01, 2011 7:52 pm Post subject: Primer Kit Installed |
I generally allow my FF to idle for a minute or two after landing to cool it
down. Is this counter-productive? I like my engine and want to treat it
Dave Kulp
Dave K/Kolbers:
Engine has probably cooled down during decent and taxi to tie down.
Titus, Alabama |
undoctor
Posted: Thu Dec 01, 2011 8:23 pm Post subject: Primer Kit Installed |
Good to know. Thanks, John.
Dave
On 12/1/2011 10:50 PM, John Hauck wrote:
Dave Kulp
Dave K/Kolbers:
Posted: Fri Dec 02, 2011 7:35 am Post subject: Primer Kit Installed |
At 09:21 PM 12/1/11 -0600, you wrote:
Jack H/Kolbers:
Kolbers,
| Quote: | From the above, the implication is that I run my engines too slow. The 447
was running wide open when it seized on climb out due to contaminated
Amsoil. The Victor 1+ was flown for a half an hour at cruise speed and then
I returned to the airport, landed, taxied back to the hangar and shut it
down. Upon pulling it into the hangar I found a coolant leak. Fried the
cylinder and piston but not to the point of seizer.
Think about it, the non volatile oil is splashed all through out the case by
the rotating and oscillating parts where it adheres to the case wall and all
other parts. Some proceeds on through into the combustion chamber were it
burns and is blown out the exhaust. After shut down, the oil that has been
plastered against the case and clinging to other parts, by gravity flows or
drips downward to the bottom of the case.
The other implication of John's statement is that you should run your two
stroke wide open to prevent lubrication problems. If you run your engine
within the range published by the engine manufacturer, and you properly set
up your injection system and/or mix your fuel correctly you will not have
any lubrication problems.
If you would like to check out how much oil remains in the case, take the
cover off you two stroke weed wacker and take a peek. You will find the
parts well coated with oil.
Jack B. Hart FF004
Winchester, IN
