Posted: Wed Nov 30, 2011 3:01 pm Post subject: Budd Davisson's RV10 article in Sport Aviation |
Is it my imagination or are most of the speeds and feeds stated in the
article BS.
Flap extension speed = 115 knots
22" & 2300 producing 160 to 165 knots indicated, true even higher
Target speed on final = 98 knots
Seems like an old school factory ride where none of the numbers can be
believed. Or is just as simple as scrambling mph and knots (which
again, is how old school reviews were done).
rv10flyer(at)verizon.net Guest
Posted: Wed Nov 30, 2011 3:44 pm Post subject: Budd Davisson's RV10 article in Sport Aviation |
First off I believe the demo plane(s) are MPH so believe everything as MPH,
those flying and have done the transition training in Tx, know that Alex
teaches the Vans way 90-95 MPH on final. I floated at that speed, at 98
knots I call that a "fly-by". As far as flaps I believe the flap speed is
100knots per Alex so that would be 115 MPH.
Yes, I thought it was a great marketing article. I can tell you that at 5500
MSl 22/2300 I saw 159 TAS/ 140 indicated or 161 MPH.
So I conclude it is MPH not Knots. That would be about right in that case.
Pascal
Bob Turner
Posted: Wed Nov 30, 2011 4:51 pm Post subject: Re: Budd Davisson's RV10 article in Sport Aviation |
I too assumed the numbers must be MPH.
Also, the "flap speed" mentioned is only for the first two notches. Vans recommends something slower (87 KIAS as I recall) for full flaps.
_________________ Bob Turner
RV-10 QB |
toaster73(at)embarqmail.c Guest
Posted: Wed Nov 30, 2011 4:52 pm Post subject: Budd Davisson's RV10 article in Sport Aviation |
I noticed the numbers being all over the place too, very odd.
With Mike Seager I was taught 85-90 mph from initial to base and to final.
I usually preferred the 85 mph on relatively calm day, stay at 9o mph if
windy.
We used 100 mph for Vfe.
At 23" and 2400 I think we would see about 165 Mph IAS.
-Chris
N919AR
Yes, it looks like a lot of confusion over mph and knots, though the
confusion isn't even consistent.
So much of what we do is about precision. One of the reasons so many of
us are here with the RV line is the refreshing veracity of Van's
performance quotes. I'm sure they're not looking for marketing hype of
this kind.
Budd, gush if you like, but leave the numbers alone unless you make the
effort to get them right!
Bill "entertained but not enlightened... think I'll just go fly
tomorrow" Watson
On 11/30/2011 6:41 PM, Pascal wrote:
MPH, those flying and have done the transition training in Tx, know
that Alex teaches the Vans way 90-95 MPH on final. I floated at that
speed, at 98 knots I call that a "fly-by". As far as flaps I believe
the flap speed is 100knots per Alex so that would be 115 MPH.
at 5500 MSl 22/2300 I saw 159 TAS/ 140 indicated or 161 MPH.
case.
Pascal
Bob Turner
Posted: Wed Nov 30, 2011 5:21 pm Post subject: Re: Budd Davisson's RV10 article in Sport Aviation |
"One of the reasons so many of
performance quotes."
Amen.
I think that's why the grins are so large.
I still can't get over the fact that something I put together came in at book weight, and makes book speeds.
RV-10 QB |
Kelly McMullen
Posted: Wed Nov 30, 2011 6:15 pm Post subject: Budd Davisson's RV10 article in Sport Aviation |
Wow. 1.3 Vso if you believe Van's advertised numbers is 82mph at gross wt of 2700. I could see 85mph on final decreasing to 80 over the fence. Most folks are going to make the majority of their landings at least 100-200lbs below gross, which would indicate even lower numbers. Of course if less flaps are used, speeds would have to go up. I'd have to believe that Van's landing distance numbers are achieved with lower speeds.
On Wed, Nov 30, 2011 at 4:41 PM, Pascal <rv10flyer(at)verizon.net (rv10flyer(at)verizon.net)> wrote:
[quote] --> RV10-List message posted by: "Pascal" <rv10flyer(at)verizon.net (rv10flyer(at)verizon.net)>
First off I believe the demo plane(s) are MPH so believe everything as MPH, those flying and have done the transition training in Tx, know that Alex teaches the Vans way 90-95 MPH on final. I floated at that speed, at 98 knots I call that a "fly-by". As far as flaps I believe the flap speed is 100knots per Alex so that would be 115 MPH.
Yes, I thought it was a great marketing article. I can tell you that at 5500 MSl 22/2300 I saw 159 TAS/ 140 indicated or 161 MPH.
Pascal
A&P/IA, EAA Tech Counselor
KCHD |
Bob Turner
Posted: Wed Nov 30, 2011 6:25 pm Post subject: Re: Budd Davisson's RV10 article in Sport Aviation |
Kelly,
I'd guess most cfi's will recommend a somewhat high approach speed, especially for new comers to the plane, because, compared to a typical Cessna, it is much easier to inadvertently apply a little back pressure on final. And if you do, especially with full flaps, the plane loses speed rapidly.
I'd say it works out well with a nice gentle round out, because then your over-the-fence speed ends up being quite a bit lower.
RV-10 QB |
partner14
Posted: Wed Nov 30, 2011 7:10 pm Post subject: Budd Davisson's RV10 article in Sport Aviation |
Had to chime in here.... flying back to TX last Sat from SoCal I was informed halfway that conditions were terrible... winds at destination 30mph gusting 45, and the airport I was landing at it also meant a 60 degree crosswind landing... all that coupled with a low, very low, left main tire. (which later meant wheel pant repair) In an attempt to reach home before dark, I ran an rpm setting 200 higher than I normally do. (and yes, I normally cruise at 2,100rpm.... 3 blade MT, and lot's of hp) Attached is a pic of my panel during the last part of the trip.... 2300rpm, 20.2mp, 10.7gph, 21.6mpg, 166mph IAS, 199mph TAS, 231mph GS, 11,700', winds 316 at 81mph with crosswind comp of 69mph.
This is a great plane!!!!!!!!!!!!!!!
OK, I threw in a pic taken several days before while I was heading from Fullerton to the Sacramento area, showing my normal cruise rpm of 2,100, 21.5mp (not WOT, ck quadrant), 8,500', 9.8gph, 19.6mpg, 164mph IAS, 189mph TAS, 192mph GS.
Two weeks ago we ran some speed checks with 3 RV10's and an RV7. 5,500', wot, 2,500rpm.... all 3 10's were within 3mph, with the fastest achieving 207TAS... the 7 was about 5mph slower. We did not work on mixture or see if a slightly higher rpm would have increased the TAS.
Some other very useful info for others out there like me (cheap).... Cruising back from Sedona last month at 9,500' with my normal settings the ground speed was 181knots while burning 10.0 gph. Pushed the levers forward... wot and 2,500rpm, although speed increased a whopping 7 knots (a 3.8% increase), the fuel burn was now 16.6 (a 66% increase).... NOT a good tradeoff.
Don McDonald
Flying, and loving every minute.
Sent: Wednesday, November 30, 2011 6:48 PM
Subject: RE: Budd Davisson's RV10 article in Sport Aviation
--> RV10-List message posted by: "Chris" <toaster73(at)embarqmail.com (toaster73(at)embarqmail.com)>
windy.
-Chris
N919AR
465.98 KB |
11369 Time(s) |
429.02 KB |
11369 Time(s) |
40636 |
dlm34077(at)q.com Guest
Posted: Wed Nov 30, 2011 7:29 pm Post subject: Budd Davisson's RV10 article in Sport Aviation |
Slow to flap speed upon entering the pattern; 120 KIAS remove reflex; <100 KIAS 0-15 degrees; about 85 KIAS for flap >15 degrees. I use 65-70 KIAS 50-100% flaps on short final; 65 KIAS if two aboard; 70 KIAS if four aboard over the numbers. Easy turnoff at 2500 feet without braking; easy turnoff at 1200 feet with moderate braking. If you plan to use strips < 1000 feet, you may want to practice technique.
See http://www.azcloudflyer.com/flight_test/proc_landing.jpg this website is updated by a friend who is an engineer and flew a comprehensive Phase I.
rv10rob(at)gmail.com Guest
Posted: Thu Dec 01, 2011 10:26 am Post subject: Budd Davisson's RV10 article in Sport Aviation |
Van's says 100 MPH is the maximum speed with full flaps, but I haven't seen any info from Van's stating that a higher airspeed is acceptable with less than full flaps. Did I miss something?
-Rob
On Wed, Nov 30, 2011 at 4:51 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
| Quote: | --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=359950#359950
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
le, List Admin.
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
Posted: Thu Dec 01, 2011 12:40 pm Post subject: Budd Davisson's RV10 article in Sport Aviation |
I missed it too. I have only seen 100mph or 87knots from Vans.
Having said that, my current practice is to slow it down to about 100 knots, then letting the 1st notch of flap get me down under 90 knots.
On 12/1/2011 1:22 PM, Rob Kochman wrote: [quote] Van's says 100 MPH is the maximum speed with full flaps, but I haven't seen any info from Van's stating that a higher airspeed is acceptable with less than full flaps. Did I miss something?
-Rob
Bob Turner
RV-10 QB
Bob Turner
Posted: Thu Dec 01, 2011 1:21 pm Post subject: Re: Budd Davisson's RV10 article in Sport Aviation |
Yes, Vans does publish (higher) speeds for partial flap extensions. See the post about 3 up.
The numbers are in the paperwork that comes with the finish kit - same part that talks about weight and balance.
RV-10 QB |
Posted: Thu Dec 01, 2011 1:28 pm Post subject: Budd Davisson's RV10 article in Sport Aviation |
page 21 of FINAL INSPECTION AND FLIGHT TEST
140 Mph for Trail
110 Mph for 1/2 flap
100 Mph for Full flap
Sent: Thursday, December 01, 2011 12:37 PM
Subject: Re: Re: Budd Davisson's RV10 article in Sport Aviation
-Rob
Bob Turner
RV-10 QB
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
scottmschmidt(at)yahoo.co Guest
Posted: Thu Dec 01, 2011 1:41 pm Post subject: Budd Davisson's RV10 article in Sport Aviation |
The flap speeds are in the packet that comes with the finishing kit. I am sure someone has a scanned copy.
I can't remember all the speeds but the -3 to 0 degree speed is 120 knots and the final flaps are 90 knots.
20 degrees is something in between but I just slow down to 90 before adding 20 degrees.
Scott Schmidtscottmschmidt(at)yahoo.com
[quote]From: Bill Watson <Mauledriver(at)nc.rr.com>
Sent: Thursday, December 1, 2011 1:37 PM
Subject: Re: RV10-List: Re: Budd Davisson's RV10 article in Sport Aviation
On 12/1/2011 1:22 PM, Rob Kochman wrote: | Quote: | Van's says 100 MPH is the maximum speed with full flaps, but I haven't seen any info from Van's stating that a higher airspeed is acceptable with less than full flaps. Did I miss something?
-Rob
Bob Turner
RV-10 QB
www.aeroelectt="_blank" href="http://www.buildersbooks.com">www.buildersbooks.comhttp========================
Posted: Thu Dec 01, 2011 1:51 pm Post subject: Budd Davisson's RV10 article in Sport Aviation |
Wow, I missed that the first time. Thanks, guys. I've forgotten to raise my flaps after takeoff a few times, so hopefully I haven't damaged anything.
-Rob
On Thu, Dec 1, 2011 at 1:24 PM, Pascal <rv10flyer(at)verizon.net (rv10flyer(at)verizon.net)> wrote:
| Quote: | page 21 of FINAL INSPECTION AND FLIGHT TEST
140 Mph for Trail
Rob Kochman
Woodinville, WA
Tim Olson
Posted: Thu Dec 01, 2011 1:58 pm Post subject: Budd Davisson's RV10 article in Sport Aviation |
For some reason, I can't remember ever seeing that in my packet
that there was any restriction from -3 to 0. I believe you
though.
The thing that boggles my mind is, why would there be any
limitation on going to zero degrees of flap. I can't imagine
why it would matter if you are at 120 or 140 or 160 if you
are at zero...it seems that going -3 is just a way to get
speed benefit.
If someone knows that answer, I'd love an education on that.
On 12/1/2011 3:37 PM, Scott Schmidt wrote:
| Quote: | The flap speeds are in the packet that comes with the finishing kit. I
adding 20 degrees.
Scott Schmidt
Bob Turner
Posted: Thu Dec 01, 2011 2:15 pm Post subject: Re: Budd Davisson's RV10 article in Sport Aviation |
Tim:
I don't know the answer to your question for certain, but here's my guess:
In flight the forces want to move the flaps up. I presume the force goes up as the speed goes up. At 0 deg that force has to be held by the actuating rod. At -3 the flaps bump up against the aft spar, so the actuating rod doesn't carry that load anymore. e.g., the limitation is to prevent over-stressing the flap actuating mechanism.
Others' guesses?
RV-10 QB |
