pdwalter(at)bigpond.net.a Guest
Posted: Mon May 22, 2006 11:23 pm Post subject: Retractable |
In read on a web site that a guy in Western Australia is trying to adapt a retratrable undercarraige from a lancair to an RV 10. Not sure how far into this mission he is but if he is sucessfull i'm sure he should be able to squeeze a few more knots out of this thing. Any thoughts ?. As for me I'll just keep working on the empenage.
Paul Walter
Tim(at)MyRV10.com Guest
Posted: Tue May 23, 2006 3:11 am Post subject: Retractable |
Thoughts as requested...
Trade a couple of kts of speed which may save you a few hours of time
over the life of the airplane, for many many hours of design and
building time that could be spent either flying or with the family
or both? Not for me. Also, one of the nicest things about the -10
is that you can own it and fly reasonably fast without the many
maintenance hassles that can come up with a retract system that
will only cost you MORE money, and MORE headaches along the way...
not to mention the occasional possible ger-up landing.
I guess I'm thinking the RV-10 was built as it is for a reason.
If someone wants a retract, they should consider actually building
a retractible kit that was designed for it, or buying a used
Bonanza, which would be an awesome plane
But, isn't that the beauty of homebuilding? He has the ability to
do things that make little sense for numerous reasons, but make
sense for only a couple....and yet he's still fine to do it.
Paul Walter wrote:
| Quote: | In read on a web site that a guy in Western Australia is trying to adapt
Paul Walter
Tdawson(at)avidyne.com Guest
Posted: Tue May 23, 2006 3:36 am Post subject: Retractable |
If retractable gear is so great, how come all Cirrus airplanes and all
Columbias (no slouches in performance) are fixed gear?
TDT
GRANSCOTT(at)AOL.COM Guest
Posted: Tue May 23, 2006 3:54 am Post subject: Retractable |
In a message dated 5/23/06 7:14:06 A.M. Eastern Daylight Time, Tim(at)MyRV10.com writes:
| Quote: | | < FONT style="BACKGROUND-COLOR: transparent" face=Arial color=#000000 size =2>If someone wants a retract, |
Tim,
If one wanted to do this in the US, I think one might want to touch base with an insurance agent to get an idea how much a jury rigge d undercarriage would increase your insurance cost...bet it would come close t o doubling or more rate increase over your normal rate with fixed gear.
Certainly the Bo, Commander, Mooney are good choices in single fan retract GA area but if one wants a retract kit rather than jury rig an RV, it seems to make more sense to buy a retract experimental with some experience...Lance, (Wheeler) Express or the Raven kit. The Raven while a home built is based on a former production aircraft (Piper Comanche) ; so it has some similarity to a production product, this may or may not make any difference in your rates, though.
Patrick
dlm46007(at)cox.net Guest
Posted: Tue May 23, 2006 4:53 am Post subject: Retractable |
Having owned a Cardinal RG for 28 years and 2500 hours I agree with Tim.
Never landed gear up but did have several XCs home with the gear left down
so maintenance could be done at home. Retractable gear benefits are a wash
for the increased maintenance and insurance costs and my gear version was
the final engineering level for the aircraft. A far more beneficial (again
with tradeoffs) was the turbonormalization. Fortunately the 10 is so over
powered by FAR standards that it will not be needed.
ichelva(at)netspace.net.a Guest
Posted: Tue May 23, 2006 5:11 am Post subject: Retractable |
Paul, do you have the website of the alleged Western Australian RV-10 RG builder? I'm only aware of 5 kits (with one flying) in this state.
Indran Chelvanayagam
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Paul Walter
Sent: Tuesday, 23 May 2006 3:22 PM
Subject: Retractable
Posted: Tue May 23, 2006 5:40 am Post subject: Retractable |
Yeah, I didn't even mention the insurance, but it's significant.
When the rates got jacked up about 6 years ago, I remember
retracts were an extreme amount higher than fixed gear.
My guess is you'd be facing at least $2000-3000/year more
in our market if it was retractable.
GRANSCOTT(at)aol.com wrote:
| Quote: | In a message dated 5/23/06 7:14:06 A.M. Eastern Daylight Time,
Tim,
fixed gear.
Patrick
Deems Davis
Posted: Tue May 23, 2006 5:56 am Post subject: Retractable |
I'm suspicious of this rumor. The Lancair IV landing gear is a huge box
structure that would not fit into the RV10 fuse (unless you built on an
additional drag producing box-like structure on the bottom of the fuse
to house it (what's the point?) The 360/Legend gear would require being
mounted into the wing structure with several ribs removed/reengineered.
Then there's the mater of the nose gear, where would you stow it? Not to
mention the significant change that this would produce in the locations
of the wheels and the rotation moments for landing/takeoff and the
almost total rework of the engine mount, exhaust, and induction. There
are better solutions for an RG than the -10.
Deems Davis # 406
Fuse
http://deemsrv10.com/
Posted: Tue May 23, 2006 6:13 am Post subject: Retractable |
Taildragger retract . . .
TDT
3edcft6(at)cox.net Guest
Posted: Tue May 23, 2006 6:47 am Post subject: Retractable |
It's my understanding that in a 200 mph airplane, if you can do retracts
with out adding too much weight, the best you are going to see is 15
knots. From what I have heard, you are very lucky to get that. It
seems until you have a plane that files closer to 300 mph, retracts
aren't worth the trouble.
Chris W
KE5GIX
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
One stop wish list for any gift,
from anywhere, for any occasion!
http://thewishzone.com
Posted: Tue May 23, 2006 8:05 am Post subject: Retractable |
Paul - any chance of pointing us to the website you mentioned? As far as I'm
aware, there are only 5 RV10 kits (one flying) in Western Australia. Would
be good to contact another builder, especially if he's making serious mods.
Might also be able to post some photos on the list!
Paul Walter
jim(at)CombsFive.Com Guest
Posted: Tue May 23, 2006 8:34 am Post subject: Retractable |
Van was asked the same question at Oshkosh. His comment was to put a gear handle on the panel with some lights. Move the handle and the lights indicate gear position. You can't see them anyway, just pretend they are up (or down).
Jim Combs
Date: 2006/05/23 Tue AM 07:10:59 EDT
Subject: Re: Retractable
Trade a couple of kts of speed which may save you a few hours of time over the life of the airplane, for many many hours of design and building time that could be spent either flying or with the family or both? Not for me. Also, one of the nicest things about the -10 is that you can own it and fly reasonably fast without the many maintenance hassles that can come up with a retract system that will only cost you MORE money, and MORE headaches along the way...
I guess I'm thinking the RV-10 was built as it is for a reason. If someone wants a retract, they should consider actually building a retractible kit that was designed for it, or buying a used Bonanza, which would be an awesome plane. But, isn't that the beauty of homebuilding? He has the ability to do things that make little sense for numerous reasons, but make sense for only a couple....and yet he's still fine to do it.
Posted: Tue May 23, 2006 9:07 am Post subject: Retractable |
That's brilliant! Maybe I'll put in a noise generator wired into the
audio system, so when the wheels go down you hear the gear motor and the
rush of disturbed air . . .
TDT
Posted: Tue May 23, 2006 9:32 am Post subject: Retractable |
If you can add engine noises, it could be something you
sell to current non-flying builders. They they won't
wear out their lips making the engine noises themselves
when they sit in their half-built planes. Then,
add a small vibrator from an old reclining chair...
TDT
jjessen
Posted: Tue May 23, 2006 9:38 am Post subject: Retractable |
Tim, could you also add an intermittent, random failure of one of the
indicator lights, just for yucks! Would appreciate it. I miss suspense of
seeing 3-green.
John J
LloydDR(at)wernerco.com Guest
Posted: Tue May 23, 2006 10:04 am Post subject: Retractable |
But for the retract, you would have to have the bass box to simulate the
thump from the door going up and closing!
Dan
mark(at)macomb.com Guest
Posted: Tue May 23, 2006 10:39 am Post subject: Retractable |
I helped Van attach the wings to his sailplane one day and observed a
gear light on the dash. I asked if the flight engineer was supposed to
report "One Green" during the landing checklist.
TDT
Posted: Tue May 23, 2006 1:10 pm Post subject: Retractable |
Just think you wouldn't be spending $30+ per hour for fuel either just to land where you took off from (Most of the time!)
Jim C
Do nOT archive.
Kellym
Posted: Tue May 23, 2006 2:01 pm Post subject: Retractable |
Or, you could just buy a 20 yr old Mooney 201, miss all the great
building experience, choice of avionics experience, spend about the
same money, go the same speed, on 2-4gph less(have a 4 cyl engine with
cheaper overhaul) and have real operating gear....oh, and you lose one
cabin door, need ~2000 ft runways instead of 1000 ft and can't climb
as fast..........choices, choices.
Quoting John Jessen <jjessen(at)rcn.com>:
seeing 3-green.
John J
KCHD |
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Wed May 24, 2006 5:26 am Post subject: Retractable |
I really agree with Tim Olson on this one. Having owned a used
Bonanza for a few years, I am really looking forward to annual
inspections with no retractable gear worries. Expensive, heavy,
complex, and you always have a moment of "will it, or won't it come
down" when you lower the gear for landing. Don't get me wrong, the
Bonanza is an awesome airplane, but less complexity and similar
performance are very attractive to me now. The building experience is
icing on the cake.
David Maib
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
