Some success at last
Goto page Previous  1, 2, 3
Richard Pike
PostPosted: Sun Nov 27, 2011 9:31 pm    Post subject: Re: Some success at last Reply with quote
jbhart(at)onlyinternet.ne wrote:
<snip> It seems that if one trimmed out for this condition, a different aileron and rudder trim would be required when piloting from the right or left seat. And again it seem like it would be different when carrying a passenger. Have you noticed that is the case with your aircraft?
Jack B. Hart FF004
Winchester, IN
Yes. My trim tab on the right aileron is adjustable, and I set it different when I am solo vs carrying a passenger.
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
pj.ladd(at)btinternet.com
PostPosted: Mon Nov 28, 2011 3:24 am    Post subject: Some success at last Reply with quote
Hi,
trimming out for passenger/no passenger in the Xtra is simply achieved by
applying the patented John Hauck method.
Take a bungee. Anchor one end to the base of the passengers seat near the
door. Take 2 turns around the stick and anchor the free end to the same
place. Use a length of bungee such that there is tension applied
The amount of trim required to take the weight off the stick to compensate
for varying passenger load is simply adjusted by sliding the loop of bungee
up or down the stick to increase or decrease the tension.
I have used this ever since John brought the system to my attention when I
first acquired my Xtra and it has worked like a charm.
Good luck
Pat
PostPosted: Mon Nov 28, 2011 8:25 am    Post subject: Some success at last Reply with quote
Richard & Pat,
If you have retrimmed your aircraft in roll for carrying a passenger and in
level flight, what change is there in rudder pedal pressure and the ball or
string slip indicator when flying with no passenger?
Jack B. Hart FF004
Winchester, IN
Richard Pike
PostPosted: Mon Nov 28, 2011 3:07 pm    Post subject: Re: Some success at last Reply with quote
Richard & Pat,
Jack B. Hart FF004
Winchester, IN
My trim tab is not big enough, so I am pushing with the left foot no matter what I do. Winter project: new trim tab.
Richard Pike
Kingsport, TN 3TN0
PostPosted: Tue Nov 29, 2011 5:45 am    Post subject: Some success at last Reply with quote
string slip indicator when flying with no passenger?>>
Hi Richard.
not enough to notice. She will trim out to fly no hands for some minutes.
After that she can be kept reasonably straight with rudder only for a
while. Certainly long enough to sort out a map. Not perfect but as with so
many other things attaining that last few per cent is the difficult bit and
I for one won`t bother to refine things any further.
Cheers
Pat
Frankd
PostPosted: Tue Nov 29, 2011 8:31 am    Post subject: Re: Some success at last Reply with quote
Hi Guys,
great suggestions about the Bungee to trim for a passenger, thanks!
Its fog time here in San Jose, but yesterday it cleared up in Hollister about 11.00AM and was calm and the airport was empty, so I went up for an hour. I have two trim questions.
1/ I agree with John H about the prop wash on the tail for which I have to put in Right rudder to compensate for. I topped up with a tad too much oil and the left side of the rudder and top of the left HS was spattered. How big is your trim tab , John? two rib bays long but how wide? 3 inches??
I think that will help eliminate yaw and right rudder input.
2/ I added an aerodynamic elevator trim tab and it works wonderfully. But I still find that my M3X is unstable in pitch, ie, I cannot take my hands off the stick for long as it will start to either dive or climb, depending on the power setting and trim setting, and will not recover by itself. Is there a way to set up the plane so that it will fly hands off? (in pitch)
Any suggestions are appreciated.
FrankD
PS, My engine is now running well, max CHTs around 310 Deg F, and oil temps around 200, with EGT's below 1400.
Now I'm trying to get the radio noise eliminated!
M3 Xtra, Jabiru 2200,
8Hrs logged, Hollister Ca.
PostPosted: Tue Nov 29, 2011 10:13 am    Post subject: Some success at last Reply with quote
FrankD
Frank D/Kolbers:
Here are some pics with a spare rudder trim tab I made. Same, same what I
have on my MKIII, except I rounded the corners more than depicted on this
piece. This was also the first tab I tested, which covered 3 rib bays, and
moved adverse yaw the opposite direction in the same amount as it flew
without a trim tab. After I cut it one rib bay and to the dimensions
indicated below, it flew with the ball centered and feet off the rudder
pedals.
Dimensions are marked on the trim tab, but in case you cannot read them,
here they are:
Width: 14 3/4"
Length: 1 7/8" to the bend (35 degrees) with a 3 1/8 trailing edge.
Short side is riveted to the ribs with large flange aluminum fabric rivets.
I use aluminum rivets (hardware store quality) for anything that is not
structural because they are much easier to remove when it comes time to
change a component.
 Filesize:  89.33 KB
 Viewed:  7210 Time(s)
 Filesize:  134.69 KB
Dana
PostPosted: Tue Nov 29, 2011 3:00 pm    Post subject: Some success at last Reply with quote
Pitch stability is primarily a matter of CG. If the CG is aft, the airplane will not be stable in pitch. Get too far aft of the neutral point and the aircraft becomes violently unstable.
I took a different approach. When I bought my Ultrastar, letting go of the stick meant a nose dive. I added elevator trim tabs to get the trim speed to about 40mph (reasoning that it _might_ be survivable an elevator cable or something broke). I also have a bungee to pull more nose down trim, up to a cruise speed of approximately 55 mph.
-Dana
Shaw's principle: Build a machine that a fool can use, and only a fool will want to use it.
PostPosted: Wed Nov 30, 2011 3:31 am    Post subject: Some success at last Reply with quote
Now I'm trying to get the radio noise eliminated!>>
Let the list know how you get on with that. Please
Pat
PostPosted: Sun Dec 04, 2011 5:45 pm    Post subject: Some success at last Reply with quote
Richard G/Kolbers:
Don't know if Richard got this email or not, with a couple photos of my
rudder trim tab.
However, this particular rudder trim tab design has fixed adverse yaw on a
lot of MKIII and MKIIIx aircraft, to include the newest iteration of the
MKIIIx I tested several years ago. Before the rudder trim tab was
installed, that was the most God awful feeling airplane I have ever flown.
After rudder trim tab installation, this MKIIIx flew just like a Kolb.
If you haven't tried the trim tab on the critter you are trying to tame,
tape one on with duct tape and go fly.
 Filesize:  89.33 KB
 Viewed:  7125 Time(s)
 Filesize:  134.69 KB
Richard Pike
PostPosted: Thu Dec 08, 2011 6:05 am    Post subject: Re: Some success at last Reply with quote
John Hauck wrote:
Richard G/Kolbers:
rudder trim tab.
<snip>
Yep, thanks. I'll try one about 1 1/2" longer, and 1 1/2" wider and see what happens.
Richard Pike
Kingsport, TN 3TN0
Page 3 of 3
