Posted: Thu Nov 24, 2011 5:42 pm Post subject: electric trim conversion docs?? |
Anyone have pictures or documents on converting one of the older (-4, -6) elevators to electric trim?
I'm contemplating the change on my flying -4 & I'm wondering how much of a hassle it will be to modify the elevator. The elevator is already off the plane for another issue, so the 1st step is already done.
I'm aware of the need to re-balance; I'm more interested in whether I'll need to remove the stiffeners around the current manual trim, & how much structure needs to be fabbed & added for the trim motor.
denis.walsh(at)comcast.ne Guest
Posted: Thu Nov 24, 2011 6:12 pm Post subject: electric trim conversion docs?? |
Charlie, Warren GREtz used to sell a conversion kit. I don't see it on his site and furthermore his site seems defunct.
However as I remember it, it was very simple and didn't require any rebalance at all. He simply mounted the servo motor on the stabilizer deck and used a short flexible link to the old trim tab. I can't remember what the link was perhaps a bowden cable? Hopefully someone will remember.
I liked it better than the old Van's system which had the servo mounted in the elevator (mine is such in an RV 6A).
Denis Walsh
denis.walsh(at)comcast.net (denis.walsh(at)comcast.net)
On Nov 24, 2011, at 6:37 , Charlie England wrote:
[quote] Anyone have pictures or documents on converting one of the older (-4, -6) elevators to electric trim?
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27801 Location: Toledo Washington (KTDO) USA
Posted: Thu Nov 24, 2011 6:46 pm Post subject: electric trim conversion docs?? |
At 06:09 PM 11/24/2011 Thursday, you wrote:
| Quote: | >Anyone have pictures or documents on converting one of the older (-4, -6) elevators to electric trim?
>Thanks,
>Charlie
Hi Charlie,
I just did this very thing on my circa 1994 RV-6, The Flyer. I installed a servo under the fin and ran a short, standard green control cable to the original trim tab and horn. Works GREAT! Attached are some pictures of the retrofit.
Matt
Matt "Red Dawg" Dralle
Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
http://www.mattsrv6.com - Matt's RV-6 Glass Panel & Interior Revitalization Log
Status: 12 Hours Since Purchase - In Albany Oregon Getting Carpet...
156.17 KB |
2075 Time(s) |
121.47 KB |
2075 Time(s) |
117.1 KB |
2075 Time(s) |
109.85 KB |
2075 Time(s) |
112.99 KB |
2075 Time(s) |
_________________ Matt Dralle
Posted: Thu Nov 24, 2011 9:03 pm Post subject: electric trim conversion docs?? |
On 11/24/2011 08:43 PM, Matt Dralle wrote:
>> I'm contemplating the change on my flying -4& I'm wondering how much of a hassle it will be to modify the elevator. The elevator is already off the plane for another issue, so the 1st step is already done.
>> I'm aware of the need to re-balance; I'm more interested in whether I'll need to remove the stiffeners around the current manual trim,& how much structure needs to be fabbed& added for the trim motor.
>> Thanks,
>> Charlie
Hi Charlie,
Matt
Thanks Matt; the trim tab end remains as Van designed it? Do you recall
where you got the short control cable?
at6c(at)bellsouth.net Guest
Posted: Fri Nov 25, 2011 5:42 am Post subject: electric trim conversion docs?? |
Charlie,
Come down and look at mine. Unless your elevator is really different it should be a "relatively" simple conversion. The servo is so light that balance of the elevator my not be effected.
George
On 11/24/2011 7:37 PM, Charlie England wrote: [quote] Anyone have pictures or documents on converting one of the older (-4, -6) elevators to electric trim?
Posted: Fri Nov 25, 2011 6:47 am Post subject: electric trim conversion docs?? |
Thanks; I'll give you a call.
On 11/25/2011 07:39 AM, George Steube wrote: [quote] Charlie,
George
On 11/24/2011 7:37 PM, Charlie England wrote: | Quote: | Anyone have pictures or documents on converting one of the older (-4, -6) elevators to electric trim?
| [b]
