Baggage area width @ door?
Tim Olson
PostPosted: Mon Nov 21, 2011 12:36 pm    Post subject: Baggage area width @ door? Reply with quote
Does anyone know the baggage width at the baggage door
area? I know I've measured this in the past to buy
luggage that fits, but I should have documented
it somewhere for future use.
I'm trying to find out if a foldable electric scooter
will fit.
aerosport1
PostPosted: Mon Nov 21, 2011 1:06 pm    Post subject: Baggage area width @ door? Reply with quote
baggage door opening is 20.25" long by 18.5" high
Geoff
Geoff Combs
President
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
jfrjr(at)roadrunner.com
PostPosted: Mon Nov 21, 2011 1:16 pm    Post subject: Baggage area width @ door? Reply with quote
Tim: Just happened to be at the hanger. 38 3/4. at forward door edge and 34 1/2 at aft edge. (with flightline interior coverings). Jay Rowe 40301
will fit.
johngoodman
PostPosted: Mon Nov 21, 2011 1:16 pm    Post subject: Re: Baggage area width @ door? Reply with quote
Don't forget that "corner" that gets in the way....
jeff(at)westcottpress.com
PostPosted: Mon Nov 21, 2011 1:22 pm    Post subject: Baggage area width @ door? Reply with quote
20" ... you have a 12" x 20" rectangle before it starts to angle down
narrower at the bottom
Jeff Carpenter
will fit.
Tim Olson
Thanks Geoff, I'll add that to the page too. I needed the
baggage depth, but I really probably should have asked
for the opening size too. Thanks for sending it!
On 11/21/2011 3:02 PM, Geoff Combs wrote:
Geoff
Geoff Combs
President
614-834-5227p
614-834-5230f
MotoPOD
PostPosted: Sun Nov 27, 2011 11:45 pm    Post subject: Re: Baggage area width @ door? Reply with quote
It's about 36" x 108" and the Yamaha XT-225 fits perfectly. It also fits bicycles, skis, 2x4's, model airplanes, surf boards, golf clubs, deer, ladders, etc. Smile
Belly pod with road bike.
 Filesize:  62.47 KB
 Viewed:  5100 Time(s)
Belly pod and motorcycle attached.
 Filesize:  94.8 KB
Yamaha XT-225 inside the belly pod.
 Filesize:  97.87 KB
