Rotax EASA AD
frans(at)privatepilots.nl
PostPosted: Mon Nov 21, 2011 8:03 am    Post subject: Rotax EASA AD Reply with quote
Hi everyone,
I came aware of a recent AD concerning the Rotax engines.
Something about certain faulty crankshafts installed in 912's and 914's,
serious enough to warrant an emergency AD for certified airplanes.
Before I attempt to find out if my engine could have this faulty
crankshaft, does anyone know if there is a list with engine serial
numbers / years of built, that could possibly have this faulty crankshaft?
It would be great if I would not have to dig out the crankshaft to find
out whether it is ok or not, and don't have to worry about it at all.
Maybe there is such a list but the art of managing paperwork is not my
best developed area, so forgive me if I asked for the obvious.
Frans
goff
PostPosted: Mon Nov 21, 2011 8:17 am    Post subject: Re: Rotax EASA AD Reply with quote
Frans,
The EASA notification is misleading in that it only refers to certified engines because EASA only deal with certified aircraft. If you go to the Rotax website you can download the Rotax Alert Service Bulletin (Mandatory) that lists ALL the offending ENGINE numbers. Apparently only about 200 crankshafts were dodgy and they are all more recent, being numbers which start with 6.
Hope this helps.
Goff
ps I'm also going to try and attach a pdf of the bulletin. Never done this before so fingers crossed.
d05094.pdf
 Filename:  d05094.pdf
 Filesize:  199.05 KB
 Downloaded:  254 Time(s)
max8992
PostPosted: Mon Nov 21, 2011 9:13 am    Post subject: Rotax EASA AD Reply with quote
Hi Frans and Goff,
Here it is... Not that recent as mine is 6.811.381 built in 2002...
Max Cointe
F-PMLH TriGear Kit #560
912ULS Airmaster 400 hours
-----Message d'origine-----
De : owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] De la part de goff
Envoyé : lundi 21 novembre 2011 17:17
À : europa-list(at)matronics.com
Objet : Re: Rotax EASA AD
Frans,
start with 6.
Hope this helps.
Goff
http://forums.matronics.com/viewtopic.php?p=358634#358634
http://forums.matronics.com//files/d05094_507.pdf
ASB-912-059.pdf
 Filename:  ASB-912-059.pdf
 Filesize:  199.05 KB
 Downloaded:  226 Time(s)
Max8992
Europa XS #560 F-PMLH
PostPosted: Mon Nov 21, 2011 11:05 am    Post subject: Rotax EASA AD Reply with quote
Whoops. My engine is uncomfortably close with 6772973, but still outside
the range!
Thanks for the document (and the others also thanks for the info)!
Frans
