Why you don't just strap the stick back...
Tim Olson
PostPosted: Thu Nov 17, 2011 4:24 pm    Post subject: Why you don't just strap the stick back... Reply with quote
After Sun-N-Fun, I read some things about proper methods of
tying down that made some real sense. Later, I also wrote
some things too, to pass along the word.
One disturbing thing I see at OSH and other places when I
see RV's tied down, is that many builders simply strap their
stick back with the seatbelt to secure the stick, locking
the ailerons and elevators.
Here's a video that shows exactly why that's a dumb idea.
http://www.youtube.com/watch?v=O-wjtP90d_g
If the above link doesn't work, go to youtube and search for
"Accidental VTOL Takeoff" posted by "MessedUpShet".
On my site, I show my rudder gust lock, with a strap
that holds the stick in the neutral position (both
axis) when I use the seat belt to pull the stick back.
That should help prevent such a thing to some degree.
Another thing that can cause you problems is having the
flaps left down. If you have problems keeping people
from stepping on your flaps, then great, put them down
when boarding and disembarking the plane. But, once
you're ready to leave the plane, put them up, because
in a wind storm, the flaps will work as designed...
They'll create extra drag, to allow the wind to push
your plane harder against it's tiedowns, and by trapping
the air under the wing it can add more lift.
Just some common sense things to pass along regarding
tying down...but the video was a real eye opener for me.
Tim Olson - RV-10 N104CD
philperry9(at)gmail.com
PostPosted: Thu Nov 17, 2011 4:38 pm    Post subject: Why you don't just strap the stick back... Reply with quote
Agreed.  I always thought that was a dumb idea.
I used to get in the sim and set the wind speed dead on the nose at a steady couple of knots above stalling speed.
Back on the stick and you're up.
Back further on the stick and you're up and going backwards.
Then forward on the stick and you're decending and picking up enough speed to creep forward to your original takeoff point.
Fun exercise in the sim.  I don't think it would be nearly as much fun with the turbulence and unpredictable winds in real life.
Phil
On Thu, Nov 17, 2011 at 6:20 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
[quote] --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
http://forums.matronics.com
le, List Admin.
orchidman
PostPosted: Thu Nov 17, 2011 7:17 pm    Post subject: Re: Why you don't just strap the stick back... Reply with quote
Tim,
Do you have a quick link to your page.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
Tim Olson
PostPosted: Thu Nov 17, 2011 8:04 pm    Post subject: Why you don't just strap the stick back... Reply with quote
There are better resources out there than me but here is my gust lock.
http://www.myrv10.com/tips/accessories/control_locks/index.html
And here is a tiedown write up that had the tiedown tips at the bottom.
http://www.myrv10.com/tips/accessories/tiedowns/index.html
On Nov 17, 2011, at 9:17 PM, "orchidman" <gary(at)wingscc.com> wrote:
Tim,
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p=358340#358340
larkrv10(at)yahoo.ca
PostPosted: Sat Nov 19, 2011 8:30 pm    Post subject: Why you don't just strap the stick back... Reply with quote
Phil, I remember the flight instructor I did most of my primary training with (some 34 years ago) was able to hover a C-150. In a very strong steady wind, he would use just the right amount of throttle, and could keep the aircraft off the ground about 2-3 feet. Can't say I have ever tried it myself, nor do I think I could. I can't imagine what an insurance company today would have to say about a stunt like that.
Rick
#40956
Southampton, Ont
--- On Fri, 11/18/11, Phillip Perry <philperry9(at)gmail.com> wrote:
Subject: Re: Why you don't just strap the stick back...
Received: Friday, November 18, 2011, 12:36 AM
Phil
le, List Admin.
le, List Admin.
ollow target=_blank>www.aeroelectric.com
/" rel=nofollow target=_blank>www.buildersbooks.com
ofollow target=_blank>www.homebuilthelp.com
llow target=_blank>http://www.matronics.com/contribution
=nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List
et=_blank>http://forums.matronics.com
pitts_pilot(at)bellsouth.
PostPosted: Sat Nov 19, 2011 8:48 pm    Post subject: Why you don't just strap the stick back... Reply with quote
Take another look at that video. Any large wind would just roll the plane back, not make it fly. I think this video is in the same class as the 'missing wing' video .... both are model airplanes. Doesn't look like an N# on the fuselage side either.
Linn
On 11/19/2011 11:26 PM, Rick Lark wrote: [quote] Phil, I remember the flight instructor I did most of my primary training with (some 34 years ago) was able to hover a C-150. In a very strong steady wind, he would use just the right amount of throttle, and could keep the aircraft off the ground about 2-3 feet. Can't say I have ever tried it myself, nor do I think I could. I can't imagine what an insurance company today would have to say about a stunt like that.
Rick
#40956
Southampton, Ont
--- On Fri, 11/18/11, Phillip Perry <philperry9(at)gmail.com> (philperry9(at)gmail.com) wrote:
From: Phillip Perry <philperry9(at)gmail.com> (philperry9(at)gmail.com)
Phil
le, List Admin.
le, List Admin.
Tim Olson
PostPosted: Sat Nov 19, 2011 9:39 pm    Post subject: Why you don't just strap the stick back... Reply with quote
It's from Russia. I originally found it from Flying Magazine.
Regarding the "stunt" with the instructor....I don't really think it's a huge risky endeavor. After all, your ground speed is minimal, so really other than gusts it shouldn't be a big danger. I've landed in 30+kt steady winds and it is fine if it's not too much of a crosswind or gusty...just feels slow
PostPosted: Sun Nov 20, 2011 6:59 pm    Post subject: Why you don't just strap the stick back... Reply with quote
Tim, you are probably right, the hovering was not a huge risk. None the less, I have never attempted it myself. Thinking back, that same instructor used to have me practise precautionary approaches into farmer's field's and we would let the main wheels touch down, and bouncy a bit before we'd lift off again. I guess in a way it was good experience for me. Never have had to actually need that experience though. I wonder if that instructor was a bit of a "cowboy"?
Rck
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Received: Sunday, November 20, 2011, 5:36 AM
Regarding the "stunt" with the instructor....I don't really think it's a huge risky endeavor. After all, your ground speed is minimal, so really other than gusts it shouldn't be a big danger. I've landed in 30+kt steady winds and it is fine if it's not too much of a crosswind or gusty...just feels slow.
Now that said, I think the dangerous part would be the taxi back to the hangar....so I don't think I'll ever hover the RV10....I'd rather not fly in winds with 50+ kts on the ground. If I could take off and land in 20kts and hover at some other airport at 20ft (at) 50kts, sure, I'd love to give that a go. It's just a river of moving air, and airplanes only know airspeed.....same as flying with 70kt tailwinds doesn't make the airplane different. I've had some great trip times with high tailwinds. (and flew the rv10 like a cessna with 50+ kt headwinds.
On Nov 19, 2011, at 10:44 PM, Linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)> wrote:
Linn
Rick
#40956
Southampton, Ont
--- On Fri, 11/18/11, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
From: Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)>
Subject: Re: RV10-List: Why you don't just strap the stick back...
Phil
le, List Admin.
le, List Admin.
http://www.aeroelectric.com">www.aeroelectric.com
"http://www.homebuilthelp.com">www.homebuilthelp.com
http://www.matronics.com/contribution">http://www.matronics.com/contribution
ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
ums.matronics.com">http://forums.matronics.com
rv10flyer
PostPosted: Mon Nov 21, 2011 6:58 am    Post subject: Re: Why you don't just strap the stick back... Reply with quote
It does not matter what position your flaps and elevator are in if your plane is not securely tied to Earth like that one appears.
I will strap my flight controls to prevent damage to them, not to keep the plane from flying on its own. I understand that control position will affect the pull on the ropes/anchors.
If I am aware of 30+ kt winds forecasted, I hope I can hangar it or fly it out in time. If not then I will try to have full fuel, max baggage in front floor area and flaps up. Check wx often when our babies are parked outside.
Wayne G.
coop85(at)verizon.net
PostPosted: Mon Nov 21, 2011 7:48 am    Post subject: Why you don't just strap the stick back... Reply with quote
I agree that a properly tied down aircraft is not going to be able to rotate and thus gain lift regardless of the wind, and this practice is seen far and wide in both experimental and certified aircraft. I found it a bit surprising that there were such strong feelings about how "dumb" this technique was and yet laud the idea of hovering at 2-20 feet in strong winds. I would offer that there is no such thing as a guaranteed strong "steady" wind and a sudden decrease while hovering a little above stall speed at these altitudes would result in a day far more exciting than desired as you are falling nose low into the concrete. I knew a guy while I was in high school that was generous enough to let my fly his C-150. He started hotdogging takeoffs (unbeknownst to me) and would build up some speed then zoom up and then push over as the plane got slow (not much of a zoom in a 150). After he happened across a slight windshear going up one day the plane stalled and he fell sideways into a parked row of airplanes. He walked away, but my free airplane was no longer available. Don't get me wrong, I'm all about doing fun things with the appropriate airplane and conditions, I like to watch a J-3 stop in a matter of feet after landing on a day with a little wind, and for 20 years I was paid to fly anything BUT straight and level so I'll do anything in a airplane right up to the "stupid is as stupid does" point. Just my opinion of course, but I was a little amazed at the combination of ideas and emotions in this thread.
Have a Happy Thanksgiving!
Marcus
Wayne Gillispie, A&amp;P 5/93, PPC 10/08
Bldr# 40983SB Final assembly, aw cert, transition training with David Maib.
http://forums.matronics.com/viewtopic.php?p=358622#358622
PostPosted: Mon Nov 21, 2011 8:28 am    Post subject: Why you don't just strap the stick back... Reply with quote
Hey all, sorry if I upset anyone with my musings. Like I said, I've never attempted these stunts myself and have managed in 34 years to have never put a small dent in any aluminum. Hopefully I can keep it that way when I get my -10 completed......Rick
--- On Mon, 11/21/11, Marcus Cooper <coop85(at)verizon.net> wrote:
Subject: Re: Re: Why you don't just strap the stick back...
Received: Monday, November 21, 2011, 3:45 PM
fell sidewa!
Marcus
one appears.
ropes/anchors.
outside.
with David Maib.
Lists This Month --
Some AWESOME FREE Gifts!)
Raiser.  Click on
out more about
Gifts provided
              -Matt
Dralle, List Admin.
Forum -
FAQ,
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
robin(at)PaintTheWeb.com
PostPosted: Mon Nov 21, 2011 8:37 am    Post subject: Why you don't just strap the stick back... Reply with quote
Rick,
Maybe your uneventful flying the last third of a century is a partial testament to his training method. At this point I would not belabor his qualifications. Techniques change, we don’t do things the same way we once did in a number of areas, why should flight instruction be any different. I much prefer an instructor that makes sure you can "fly the plane" before he signs you off vs. an uninvolved instructor that does the bare minimum. I have a friend that received his certification after being trained by 3 different instructors over the course of ~125 hours of dual! He didn’t even have basic Comm techniques and was what I considered to be an unsafe pilot because there seemed to be no method to his training even after all those hours. I insisted we fly together for probably another 15 hours just to force him into the use systems that added consistency to his flying technique. It was hard to break him of those bad habits. Ultimately finances forced him out of flying which is likely a good thing for all concerned.
I would probably prefer your cowboy over most of the instructors currently training on my field right now.
Slightly off topic… I was selling a beautiful Turbo Lance II with a near zero time engine & turbo, club seating for 6 etc… A successful young business man in my town wanted to buy it. He was a 200 hour pilot talking about taking his family and a friends family places. While it was an easy sale I found another buyer with lots of experience in make & model. The original buyer was pissed but I did not want to be the guy that sold this nice young family an aircraft that wiped out two local families. It was so obvious to me that he could get over his head in short order and there would be another local tragedy. Please note I am not "that guy" that has to sell his RV engine separate from the airframe to avoid personal liability. This situation just reeked of calamity. I am still happy with my decision even if it left some hard feelings.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark
Sent: Sunday, November 20, 2011 6:56 PM
Rck
--- On Sun, 11/20/11, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
From: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
To: "rv10-list(at)matronics.com (rv10-list(at)matronics.com)" <rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
Regarding the "stunt" with the instructor...I don't really think it's a huge risky endeavor. After all, your ground speed is minimal, so really other than gusts it shouldn't be a big danger. I've landed in 30+kt steady winds and it is fine if it's not too much of a crosswind or gusty...just feels slow.
On Nov 19, 2011, at 10:44 PM, Linn Walters <pitts_pilot(at)bellsouth.net> wrote:
Linn
Rick
#40956
Southampton, Ont
Phil
On Thu, Nov 17, 2011 at 6:20 PM, Tim Olson <Tim(at)myrv10.com> wrote:
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
le, List Admin.
le, List Admin.
ollow target=_blank>www.aeroelectric.com/" rel=nofollow target=_blank>www.buildersbooks.comofollow target=_blank>www.homebuilthelp.comllow target=_blank>http://www.matronics.com/contribution=nofollow target=_blank>http://www.matronics.com/Navigator?RV10-Listet=_blank>http://forums.matronics.comllow target=_blank>http://www.matronics.com/contribution
5
6
7
8
9
5
6
7 ==============[/b][/quote] sts This Month --[/b][/quote] And Get Some AWESOME FREE Gifts!)[/b][/quote] ick on[/b][/quote] t[/b][/quote] d[/b][/quote] aeroelectric.com">www.aeroelectric.com[/b][/quote] http://www.buildersbooks.com">www.buildersbooks.com[/b][/quote] .homebuilthelp.com">www.homebuilthelp.com[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] b>[/quote] bsp;   -Matt Dralle, List Admin.[/b][/quote] ==============[/b][/quote] V10-List Email Forum -[/b][/quote] >[/b][/quote] :p>[/b][/quote] /o:p>[/b][/quote] tor?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] ==============[/b][/quote] bsp; - MATRONICS WEB FORUMS -[/b][/quote] :p>[/b][/quote] tp://forums.matronics.com[/b][/quote] ==============[/b][/quote] bsp; - List Contribution Web Site -[/b][/quote] e> bsp;   -Matt Dralle, List Admin.[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] ==============[/b]/" rel=nofollow target=_blank>www.buildersbooks.com[/quote]8
