N519RV (40250) just received it's airworthiness today.
Ray.R.Doerr(at)sprint.com
PostPosted: Mon May 22, 2006 10:05 am    Post subject: N519RV (40250) just received it's airworthiness today. Reply with quote
             N519RV (40250) just received it’s airworthiness today from Chuck Morris (DAR).  I have a IO-540-D4A5 that was rebuilt by America’s Aircraft Engines with the Silver Hawk EX fuel injection.  My engine data plate was replace with one from America’s Aircraft Engine which says Experimental IV, but I still manage to get a 25 hour fly off with the Hartzell blended airfoil prop.  The only thing the DAR found was that when the rudder cables are left slack, they tend to rest on the top surface of the 2nd last bulkhead ( the one in which the cables run in the center of), so he suggested that I put a split hose over the top of the bulkhead so when the cables won’t rub against the bulkhead.  First flight is schedule for Friday May 26th at K34 around 04:00pm.</ p>
Thank You
Ray Doerr
GRANSCOTT(at)aol.com
PostPosted: Mon May 22, 2006 10:18 am    Post subject: N519RV (40250) just received it's airworthiness today. Reply with quote
Great news, Ray, enjoy your first flight!!! You earned it.  Finish ing must be in the air...my buddy John got his pink slip Sunday morning...Whitma n Tail Wind...building a plane from drawing!
Ray all the best,
Patrick
Do Not archive
jjessen
PostPosted: Mon May 22, 2006 10:50 am    Post subject: N519RV (40250) just received it's airworthiness today. Reply with quote
Mr. Doerr!  Absolutely enjoy!
John Jessen
  ~328 (a few years behind you)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Doerr, Ray R [NTK]
Sent: Monday, May 22, 2006 11:03 AM
Subject: N519RV (40250) just received it's airworthiness today.
Thank You
Ray Doerr
Tim(at)MyRV10.com
PostPosted: Mon May 22, 2006 11:34 am    Post subject: N519RV (40250) just received it's airworthiness today. Reply with quote
That's awesome news! We should keep a list of design-related
squaks that the various inspectors come up with. That way
future builders can possibly take the precautions sooner and
not only have easier inspections, but safer planes.
Glad you also got the 25 hour flyoff. I'm at about 70 hours
now with no real issues. Good luck on the first flight!
surface of the 2^nd last bulkhead ( the one in which the cables run in
flight is schedule for Friday May 26^th at K34 around 04:00pm.
Thank You
*Ray Doerr*
flysrv10(at)gmail.com
PostPosted: Mon May 22, 2006 1:12 pm    Post subject: N519RV (40250) just received it's airworthiness today. Reply with quote
Good luck and be careful!
On 5/22/06, Doerr, Ray R [NTK] <Ray.R.Doerr(at)sprint.com> wrote:
N519RV (40250) just received it's airworthiness today from
Chuck Morris (DAR). I have a IO-540-D4A5 that was rebuilt by America's
plate was replace with one from America's Aircraft Engine which says
the cables won't rub against the bulkhead. First flight is schedule for
Thank You
Ray Doerr
bbollaert(at)comcast.net
PostPosted: Mon May 22, 2006 4:02 pm    Post subject: N519RV (40250) just received it's airworthiness today. Reply with quote
Hello Ray:
Congrats Ray on the sign off ! I have the same IO-540-D4A5 as i think Tim does & many others (any web cams at K34?) anyway have a great time on the 26th .
Brian Bollaert
#20400
jjessen
PostPosted: Mon May 22, 2006 4:23 pm    Post subject: N519RV (40250) just received it's airworthiness today. Reply with quote
Yeah, this is what was happening to me.  You send a note and get the contents stripped out.  Anyone else having this problem?
John Jessen
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of brian bollaert
Sent: Monday, May 22, 2006 4:59 PM
Subject: Re: N519RV (40250) just received it's airworthiness today.
Thank You
Ray Doerr
Checked by AVG Free Date: 5/22/2006
RoxIanMike(at)msn.com
PostPosted: Wed May 24, 2006 4:53 pm    Post subject: N519RV (40250) just received it's airworthiness today. Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Congrats!!!!!!!!!!!!!!!
