messydeer
Joined: 13 Feb 2006 Posts: 214 Location: Bellingham, WA
Posted: Fri Nov 11, 2011 10:44 am Post subject: antenna connections |
I read through stuff Bob has written about making VHF antennas. Here's how I understand it.
Coaxial cable has a center conductor and outer shield. The connector at the end of the cable connects the shield to the shell of this female connector, which gets screwed onto the male threaded barrel of the antenna mount. This part of the antenna mount is connected to the metal skin, which forms the ground plane.
The inner conductor wire connects to the inner conductor of the antenna mount, which is isolated from the surrounding male threaded barrel and hex portion that mounts inside the aircraft. The inner conductor of the mount is electrically connected to the 3/8" male threaded stud, which is also connected to the adapter, bolt, and antenna whisker.
To install this ebay mount, it looks like I'd remove the 3/8" female threaded hex barrel adapter, star washer, and what looks like an insulating shoulder washer. From the inside of the aircraft, insert the 3/8" male stud through the doubler and skin, then slide the shoulder washer and star washer on from the outside. Tighten the hex barrel adapter over the stud, then the bolt/antenna whisker.
If I've understood it correctly, there wouldn't then be an issue with lock-washer centering, which I didn't understand in the first place.
Dan
90.22 KB |
19712 Time(s) |
97.74 KB |
19711 Time(s) |
_________________ Dan |
Posted: Fri Nov 11, 2011 5:55 pm Post subject: antenna connections |
At 12:44 PM 11/11/2011, you wrote:
There's an article on the materials and process at:
http://aeroelectric.com/articles/Antennas/DIY_Comm_Ant/DIY_Comm.html
I modify the adapter in a lathe to provide
a centering shoulder for the lock-washer.
messydeer
Posted: Fri Nov 11, 2011 6:32 pm Post subject: Re: antenna connections |
Yes, thanks, Bob. I should have mentioned that's where I got most of my info. This ebay mount has a so239 to connect to, which would take a pl259 on the cable end. I'm thinking of getting that mount from ebay and the cable from you. Would you have a pl259 to go onto that? Depending on where I locate the antenna, I might need a 90 on one or both cable ends. If you don't have those, would I be able to send them to you?
Speaking of antenna location, I've heard it's not good to get the xpdr and com antennas closer together than 5', 3', or 22". Could you shed some light on this?
One last thing. The 1/8" SS piano wire (or welding rod?) can be soldered to the bolt with my Kester 44?
Dan
Posted: Fri Nov 11, 2011 9:21 pm Post subject: antenna connections |
At 08:32 PM 11/11/2011, you wrote:
| Quote: | --> AeroElectric-List message posted by: "messydeer" <messydeer(at)yahoo.com>
Yes, thanks, Bob. I should have mentioned that's where I got most of my info. |
Okay, good.
| Quote: | | This ebay mount has a so239 to connect to, which would take a pl259 on the cable end. I'm thinking of getting that mount from ebay and the cable from you. Would you have a pl259 to go onto that? Depending on where I locate the antenna, I might need a 90 on one or both cable ends. If you don't have those, would I be able to send them to you? |
I have rt-angle BNC connectors. Suggest you put
a UHF to BNC adapter on the antenna mount
[img]cid:7.1.0.9.0.20111111231035.01dd8338(at)aeroelectric.com.0[/img]
and use right-angle BNC's to finish up the
task. I can craft cables to your needs.
| Quote: | | Speaking of antenna location, I've heard it's not good to get the xpdr and com antennas closer together than 5', 3', or 22". Could you shed some light on this? |
Most transponder antennas go on the belly and
comm antennas on top. If both are on belly, then
just get them as far apart as possible.
| Quote: | | One last thing. The 1/8" SS piano wire (or welding rod?) can be soldered to the bolt with my Kester 44? |
No, silver solder. Tin lead is too weak and won't flow
to stainless.
10.33 KB |
19677 Time(s) |
messydeer
Posted: Fri Nov 11, 2011 11:09 pm Post subject: Re: antenna connections |
I'll be mounting both xpdr and com antennas on the bottom. I could get 36" between them without a problem.
I looked over silver soldering. Had thought that was an old saying for 'soldering'. Another option would be to get a SS whip antenna, like this from Radio Shack: http://www.radioshack.com/product/index.jsp?productId=2102428&CAWELAID=107599032 It's 102" but has a 3/8-24 fitting. Cutting it down would be no problem, but putting a 45 bend could be. I assume this would be a tube that could kink.
ACS has one for about $20, but I thought I read someone say it didn't have the standard fitting, which seems odd. I'll have to check with them.
Posted: Sat Nov 12, 2011 7:40 am Post subject: antenna connections |
At 01:09 AM 11/12/2011, you wrote:
That will be plenty . . .
| Quote: | I looked over silver soldering. Had thought that was an old saying
for 'soldering'.
Soldering is a generic term for joining two metals (which
may be alloys) with a dissimilar third metal (which can
also be an alloy).
Welding is the jointing of the first two metals
by melting a similar metal into the surface of the two.
Soldering DISSOLVES a molecular layer of the two bases
into a fluid third without actually melting the bases.
Brazing is a form of soldering. We commonly
think of "solder" as being that legacy tin/lead stuff
for wiring, copper roofing and stained glass windows.
There are in fact an infinite number of solders tailored
by alloy and flux to achieve a useful melting point, ability
to 'wet' the base metals and structural strength.
Legacy tin/lead won't wet stainless and is too soft. Some
common silver solders contain phosphorous (Sil-Fos)
and I think should be limited to copper/brass fittings
like in refrigerators. The other silver alloys are fine
but can have widely different flow-temperatures. A local
weld shop probably has some choices and data that
gives the melting points.
| Quote: | Another option would be to get a SS whip antenna, like this from
Radio Shack:
http://www.radioshack.com/product/index.jsp?productId!02428&CAWELAID7599032
No, it's a solid rod. Good idea actually. I may
update my article to include this option. You can
cut it to length by grinding a 'break notch' all
the way around the rod . . . then round it off for
safety. Save the remaining cut-off. That can be
used to build more antennas where silver soldering
is not a prohibition. In fact, the tip end of the
antenna has the 'safety ball' on it . . . this would
become prime antenna stock. Just tailor the hole in
the base-bolt to be a few thousandths of an inch
oversized to allow silver solder to flow into the
hole and around the base of the antenna rod.
To bend, heat the bend location with your torch
to at least dull red and then pull around a radius
held in your vise . . . a piece of pipe or some such.
Don't bend too far. You can always bend more but it's
a real bear to 'unbend'.
The area heated will be tarnished after you finish
the bend but it can be polished up again with some
fine sandpaper.
| Quote: | ACS has one for about $20, but I thought I read someone say it
check with them.
Don't know what a 'standard' fitting would be but
the Radio Shack part is about the same price
and you can probably pick it up locally. Better
yet, it provides enough material for at
least 3 comm antennas.
messydeer
Posted: Mon Nov 14, 2011 7:54 am Post subject: antenna connections |
At 09:23 AM 11/14/2011, you wrote:
Thanks, Bob
I'll prolly get that antenna from RS. I had read some about antennas
being 'tuned', so any 22" long one would work?
Yes, that's total length from top of mounting surface to
tip of antenna . . . so that includes height of the mount.
| Quote: | Also heard something about different resistance in either the
connectors or the antenna. Do I need to be concerned about that?
No. There ARE connectors designed for minimizing
"impedance bumps" at the joints for the popular
feed line impedances . . . but that's of no
significance to our task.
messydeer
Posted: Mon Nov 14, 2011 8:19 am Post subject: Re: antenna connections |
Goodie
I know suggested I get a UHF-BNC adapter and that you have BNC right angle connectors. I just noticed the seller of these mounts also has a UHF right angle adapter. Would you have a straight UHF connector for the cable, or should I stick with plan A and get a straight UHF-BNC adapter?
22.25 KB |
19625 Time(s) |
messydeer
Posted: Mon Nov 14, 2011 9:08 pm Post subject: Re: antenna connections |
K.
Got the RS antenna. My only initial anal concern was the weight at .20" diameter at the 22" mark. It tapered down to less than 1/8", but that was near the end of the original 120". I've seen some com antennas listed as 0.15" thick, so I gained 1.5 oz.
I bent it at ~8" to about 40 degrees after heating it with a propane/air torch. Used a little $10 HF tubing bender. It wanted to also put another bend real close to the base, but the bender config would have made that real tough, so I increased the bend to 68 degrees at the original location.
I ran a scotchbrite roloc over it to get the discoloration out, which was fairly easy to do. Will this area be as stain resistant as the other areas? When I got my EGT probes, the bayonets were welded to hose clamps. Around the welded area there was rust.
Clearance under my Sonex TD is ~19" at the planned location of the antenna. Vertical for the antenna is ~13", giving me 6" ground clearance. I also just bought that base connector off eBay.
This has been the type of project I really like. Doing something simple and saving money. $22 for the antenna, $5 for the mount, $2 for the BNC-UHF adapter at Frys. That compares to over $65 just for the antenna at ACS, which still needs more bending to go on the belly. Thanks, Bob!
290.5 KB |
19595 Time(s) |
Posted: Tue Nov 15, 2011 8:36 am Post subject: antenna connections |
At 11:08 PM 11/14/2011, you wrote:
K.
Yup, that's called sifting through the options and
evaluating the trade-offs. But it IS a robust antenna.
This brings up another point. That antenna is not
very compliant . . . I.e. it's stiff. Make sure you've
got a robust doubler on the belly surface.
| Quote: | I bent it at ~8" to about 40 degrees after heating it with a
Sounds like a reasonable trade off . . .
| Quote: | I ran a scotchbrite roloc over it to get the discoloration out,
Heating a material to a ductile state does not change
it's alloy. If it was 'stainless' to begin with, it's
still stainless.
| Quote: | Clearance under my Sonex TD is ~19" at the planned location of the
belly. Thanks, Bob!
Pleased that you've been able to adapt the simple-ideas
for one recipe and craft one of your own. You could
take the scraps of antenna left over and craft two
more to offer to others here on the list. By the time
you've made the third one, you'll be way down on the
learning curve and more of an authority on that idea
than I am, I've only made the one you see in the article.
raymondj(at)frontiernet.n Guest
Posted: Thu Nov 17, 2011 12:53 am Post subject: antenna connections |
SNIP
> still stainless.
SNIP
Greetings Bob,
While you are correct that heating a stainless alloy doesn't change the
alloy, there are other issues associated with stainless that are worth
considering when it has been heated. The 2 that come to mind are
passivating and changes in the structure at the ends of the heated
section (in welding it is referred to as the heat affected zone).
Without knowing the the alloy or the manufacturing process it is hard to
predict, but if something unexpected occurs, it may be attributable to
the bending process.
Raymond Julian
Kettle River, MN
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
messydeer
Posted: Thu Nov 17, 2011 7:22 am Post subject: Re: antenna connections |
Just for kicks, I started looking for some silver solder. RS has some for $7 http://www.radioshack.com/product/index.jsp?productId=2062717 It has 2% Ag, no P. Most of the other ones I found were in the 2-4% range. Rosin core seems like it would be easier. Will this solder work?
Posted: Thu Nov 17, 2011 2:23 pm Post subject: antenna connections |
Just for kicks, I started looking for some silver solder. RS has some for $7 http://www.radioshack.com/product/index.jsp?productId 62717 It has 2% Ag, no P. Most of the other ones I found were in the 2-4% range. Rosin core seems like it would be easier. Will this solder work?
I should have been a bit more specific. "Solder" comes
in a LOT of flavors and not all sliver bearing solders
are intended to be structural.
The solders used for electronics are not intended to
make up highly stressed joints. Silver is included in
these solders to make them more friendly to the task.
We know, for example, that solder makes a joint by
DISSOLVING some portion of the metals to be joined
into the melt.
WAAAAAyyyy back when, some premium electronics device
like Tektronix scopes used terminal strips that were
ceramic moldings with a sliver alloy bonded into
the notches like this:
[img]cid:.0[/img]
These were popular with other high-end product of the
vacuum tube era. One was well advised to use a silver
bearing solder to make up joints on these terminals
to avoid "washing" the sliver off the ceramic and
breaking the bond. Many a 'scope I've opened from
that era had a small quantity of suitable solder
stashed somewhere inside by the factory.
This sort of solder would be useful in making up
joints on any silver-plated terminal.
But when you're sticking things together that
are highly stressed, it's a different kind of
sliver solder that has more like 40% or more silver
and melts at temperatures far above that produced
by your soldering iron. Avoid "refrigeration" solder
with phosphorous in it (sil-fos) as it is specific
to joining of high pressure copper plumbing.
The durn stuff is not cheap and you only need
a gram or so. It might be that you'd want to
drop by a weld shop and get it brassed (or
silver soldered if they have it in stock).
Here's an example of a 'hard' solder
http://tinyurl.com/7t7ypah
If it's a process you want to be able to do
in the future, then investing in a small chunk
of solder will give you a joining process that
can be accomplished with hardware store torches.
You'll also need flux. A borax based paste that
melts and looks water clear as the joint flows
and cools to look like a layer of glass. Chips
away easily.
43.19 KB |
19504 Time(s) |
Posted: Thu Nov 17, 2011 2:32 pm Post subject: antenna connections |
the alloy, there are other issues associated with stainless that are
worth considering when it has been heated. The 2 that come to mind
are passivating and changes in the structure at the ends of the
heated section (in welding it is referred to as the heat affected
zone). Without knowing the the alloy or the manufacturing process it
is hard to predict, but if something unexpected occurs, it may be
attributable to the bending process.
Absolutely. Heating and bending any structural piece gives
rise to potential changes in the metal's performance.
I've heard of brazed pieces failing outside the joint
because the nature of the material changed due
to heating for joining.
In this case, we were discussing the appearance of
a lightly stressed part . . . buffing off the corrosion
products from heating and the risks are low. But your
point is well taken! Thanks!
messydeer
Posted: Thu Nov 17, 2011 6:27 pm Post subject: Re: antenna connections |
Thanks for the silver solder info, Bob.
What would be wrong with using a 3/16 or 1/4" rod of aluminum instead of SS and cut threads on the end? It's much easier to bend and a 2' piece of it from ACS is cheaper than a cup of coffee. It wouldn't fit into the 3/8-24 mount, but an adapter from a short piece of 3/4" rod aluminum could be made. Drill and tap one end for 3/8-24 and the other to fit the rod. You could even taper the adapter into a cone shape.
Posted: Fri Nov 18, 2011 6:53 am Post subject: antenna connections |
Excellent question!
Unlike steel, aluminum has a 'service life' at
any stress level. Non-ferrous (no iron) materials
have a stress-to-cycles curve that goes all the
way down to zero stress. This means that the thing
is going to break sometime at what ever stress
level you choose to operate it.
Wings and things on aluminum airplanes are very
lightly stressed so that their service lives are
many times greater than the expected lifetime of
the machine. Yet, pieces of aluminum routinely
crack and fail. Sometimes it blows big holes out
of the cabin walls of airliners!
Steels are pretty cool in this regard. Once you
drop below a certain stress level for that particular
alloy, the service life becomes unlimited. I used
to wonder at the legacy policy of allowing an engine
to be 'certified' with only 75 or so hours on the
test stand. But 75 hours at 2400 rpm is over ten
million stress cycles on parts. If something doesn't
break in that period of time, probability of breaking
beyond this test interval is low.
Getting back to our antenna, you'll find that the
little whisker of metal 'hums' in the breeze of aero-
dynamic turbulence around the fuselage. Unless it's
a very robust aluminum part, you'll probably find that
the comm system performance becomes severely degraded
when the antenna departs the airplane.
For that reason, "whisker" style antennas have always
been made from steels . . . although from a radio
frequency performance perspective, we'd like to have
better conducting materials. This is why the 'shark fin'
antennas can offer incrementally better performance.
Their less robust, high performance materials are
enclosed in an RF transparent housing to protect them
from effects of air flow.
messydeer
Posted: Fri Nov 18, 2011 7:11 am Post subject: Re: antenna connections |
Yeah, that sounds familiar about aluminum. On the other hand, I've found some antennas made out of aluminum.
The DM C63-Series antennas are VHF communication antennas designed for high mechanical strength with machine tapered aluminum alloy radiating elements.
http://www.aircraftspruce.com/catalog/avpages/c63_2.php
Is there anything different about this type of antenna compared to the one I'd suggested, outside of a streamlined base?
4.06 KB |
19433 Time(s) |
LynnCole(at)foxvalley.net Guest
Posted: Fri Nov 18, 2011 8:24 am Post subject: antenna connections |
| Quote: | Getting back to our antenna, you'll find that the
The humming that you refer to is due to vortex shedding (the most
famous example of vortex shedding is the failure of the Tacoma
Narrows Bridge). The antenna on my car (steel) has a spiral wrap
around it. That trips the boundary layer so that only very short
stiff lengths of the antenna can vibrate. The vibrations where the
wrap is on one side of the antenna cancel the vibrations where the
wrap is on the other side. Without the wrap the entire antenna,
which is very limber, vibrates as a unit, and it can achieve some
large amplitudes.
Lynn Cole
