AIRSPEED INDICATOR MARKINGS
sam.marlow
PostPosted: Sun May 21, 2006 1:08 pm    Post subject: AIRSPEED INDICATOR MARKINGS Reply with quote
Where do we get the range markings for the airspeed indicator? Did most
of you mark your own instruments?
Tim(at)MyRV10.com
PostPosted: Sun May 21, 2006 1:59 pm    Post subject: AIRSPEED INDICATOR MARKINGS Reply with quote
Depends on what you get for instruments. You can actually
order UMA instruments like the airspeed indicator, all premarked
for the RV-10. On an EFIS you'd input them yourself.
Dick Sipp
PostPosted: Sun May 21, 2006 6:27 pm    Post subject: AIRSPEED INDICATOR MARKINGS Reply with quote
They are listed at the top of page 22 of the Final Inspection and Flight
Test Chapter.
In MPH:
Bottom of white arc.......60 indicated stall with full flaps
Top of white arc............100 max speed with full flaps
Bottom of green arc......70 approx indicated stall without flaps
Top of green arc...........180 max structural cruise speed
Blue line.........................144 maneuvering speed
Yellow arc......................180-230 caution range calm or light
turbulence only
Red line.........................230 maximum permissible speed under any
condition
There's lots of other critical stuff in this chapter. I can't recall for
sure what part of the kit this section came with.
Dick Sipp
40065
Tim(at)MyRV10.com
PostPosted: Sun May 21, 2006 7:16 pm    Post subject: AIRSPEED INDICATOR MARKINGS Reply with quote
And remember that these are in MPH, so if you're using strictly
KTS like I am, you'll need to do the math and convert these:
1 mph = .8689755962687 kts an hour
Test Chapter.
In MPH:
turbulence only
condition
for sure what part of the kit this section came with.
Dick Sipp
40065
sam.marlow
PostPosted: Mon May 22, 2006 3:22 am    Post subject: AIRSPEED INDICATOR MARKINGS Reply with quote
Thanks!
Richard Sipp wrote:
[quote]--> RV10-List message posted by: "Richard Sipp" <rsipp(at)earthlink.net> (rsipp(at)earthlink.net)
They are listed at the top of page 22 of the Final Inspection and Flight Test Chapter.
In MPH:
Yellow arc......................180-230 caution range calm or light turbulence only
Red line.........................230 maximum permissible speed under any condition
There's lots of other critical stuff in this chapter.  I can't recall for sure what part of the kit this section came with.
Dick Sipp
40065
sam.marlow
Thanks!
Tim Olson wrote:
--> RV10-List message posted by: "Tim Olson" <Tim(at)MyRV10.com> (Tim(at)MyRV10.com)
--> RV10-List message posted by: Sam Marlow <sam.marlow(at)adelphia.net> (sam.marlow(at)adelphia.net)
