Bing Carb Failure
Richard Pike
PostPosted: Fri Oct 28, 2011 4:05 pm    Post subject: Bing Carb Failure Reply with quote
Happened yesterday, RANS S-7, pilot landed, put the airplane away, went inside. Came back 2 hours later, 2 or 3 gallons of gas on the floor.
One of the float pins came out and the gas ran out the bottom of the float bowl. Engine is a 912ULS, serial # is 5648894, carb serial # is 072585, this engine has approx 150 hours.
The pin is not knurled, it is just pressed into the bottom of the float bowl. Since a lot of the people on this list use the 912, thought it would be of interest.
 Filesize:  53.24 KB
 Viewed:  21556 Time(s)
 Filesize:  60.36 KB
 Filesize:  56.75 KB
 Filesize:  44.88 KB
 Filesize:  51.17 KB
 Filesize:  50.21 KB
 Filesize:  54.88 KB
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Thom Riddle
PostPosted: Fri Oct 28, 2011 4:52 pm    Post subject: Re: Bing Carb Failure Reply with quote
Thanks for the heads up, Richard. Of all the Bing 64 and 94 carbs I've taken apart I've never seen any indication that these pins were in any way loose. There is another pin, which acts as a hinge pin for the floats, that goes through the light gage ss part(11) that the float bears on. This other pin is knurled on one end so that it stays seated firmly in the cast metal part of the carb body. The pin I am referring to is labeled 12 in the attached image.
It appears that the pin that fell out of one of the floats in your photo was due to a manufacturing defect. The float (item 10 in attached image) comes with these pins permanently installed, or so they should be.
 Filesize:  70.57 KB
 Viewed:  21547 Time(s)
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
PostPosted: Fri Oct 28, 2011 5:20 pm    Post subject: Bing Carb Failure Reply with quote
be of interest.
Richard Pike
Richard P/Gang:
The carb is designed to prevent the float pivot pin from being able to come
out as long as the float bowl is attached to the carb. It is Murphy proof.
The front of the float bowl is considerably more narrow than the rear
portion. This is the part of the float bowl that the float bowl bail slides
over and into its locked position.
Can't remember for sure because it has been many years since I had a two
stroke Bing carb apart, but believe the float bowl and float pivot pin is
similarly designed.
Richard Pike
PostPosted: Fri Oct 28, 2011 7:18 pm    Post subject: Re: Bing Carb Failure Reply with quote
be of interest.
Richard Pike
Richard P/Gang:
similarly designed.
You are correct, the two stroke is the same design, the float pivot pin cannot come out as long as the float bowl is in place. But this is a totally different pin, and it is not knurled, it is tapered where it goes into the float bowl. I concur with Thom's assessment that this was a bad part. On the other hand, it would be something easy to check, by dropping the float bowl and giving it the wiggle test.
Richard Pike
Kingsport, TN 3TN0
PostPosted: Fri Oct 28, 2011 7:35 pm    Post subject: Bing Carb Failure Reply with quote
Richard Pike
Sorry, I misunderstood which pin you were talking about.
I think you are talking about the float guide pin. That would ruin your day
is if came loose.
Wonder if the remaining float would work well enough to get back on the
ground with a little power.
Murphy never rests. First time I have heard of this particular problem.
This gent's problem happened on the ground, I assume. Or maybe it happened
in the air and he didn't realize it until he discovered the fuel needle was
not sealing. ????
Richard Pike
PostPosted: Sat Oct 29, 2011 5:02 am    Post subject: Re: Bing Carb Failure Reply with quote
is if came loose.
not sealing. ????
He realized it when he went back out into his hangar and found several gallons of gas all over the floor under his airplane. Picture 015 shows that it was one of the two pins that are seated into the bottom of the float bowl and the floats slide up and down on them. Surprisingly it looks from the picture that the end that goes into the float is slightly rounded but that's all, not knurled or anything. Still unclear when it came out, he had taken off from an airport about 15 miles away and flown home, landed and taxied in. His strip is smoother than mine, but still somewhat bumpy. When he pushed it into the hangar there was no gas smell or evidence of leakage, so I would assume it came out right at the end of taxiing in, and whatever fuel began to leak wasn't enough to attract attention. I know this pilot well, he is mechanically very sharp and does not tolerate anything unusual. Very fortunate that he did not turn the fuel valve off, or the failure would probably not have manifested itself by all that fuel leaking out the hole in the bottom of the bowl. Don't know if or how the engine would have run on the next startup, but if it didn't run bad enough to attract notice, things could have gone very badly.
Richard Pike
Kingsport, TN 3TN0
byoungplumbing(at)gmail.c
PostPosted: Sat Oct 29, 2011 9:31 am    Post subject: Bing Carb Failure Reply with quote
ok if the float guide pin, (mounted in the bottom of the float bowl, at 1
end only) came out, then the float needle would not get the proper
pressure to seal,,,,,, my next question is where did the pressure in the
fuel system come from to continue to flow gas up to the carb and on the
floor?
boyd
WhiskeyVictor36(at)aol.co
PostPosted: Sat Oct 29, 2011 12:56 pm    Post subject: Bing Carb Failure Reply with quote
Boyd
He said it was a Rans-S7. I think they have high wing tanks. Gravity let fuel down to carb. He said owner did not turn off the gas valve.
Bill Varnes
In a message dated 10/29/2011 1:31:47 P.M. Eastern Daylight Time, byoungplumbing(at)gmail.com writes:
--> Kolb-List message posted by: "b young" <byoungplumbing(at)gmail.com>
floor?
boyd e ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
Jason Omelchuck
PostPosted: Sat Oct 29, 2011 5:26 pm    Post subject: Re: Bing Carb Failure Reply with quote
There are pictures attached to this report. Look at them if you get a chance. From looking at the pictures the guide pins, are inserted into holes that are drilled all the way through the float bowl. When the pin falls out, there is just a hole in the bottom of the float bowl for the fuel to drip out.
floor?
boyd
PostPosted: Sat Oct 29, 2011 5:44 pm    Post subject: Bing Carb Failure Reply with quote
to drip out.
Do you have a url for the report?
Jason Omelchuck
PostPosted: Sun Oct 30, 2011 7:26 am    Post subject: Re: Bing Carb Failure Reply with quote
I am talking about Richards report of the incident right here in this very thread you are posting in. I realize that some people might not have access to the pictures or might not bother to look at them. But if you do, it clears up all confusion about what pin it is and the fact that when the pin comes out there is just a hole in the bottom of the float bowl.
to drip out.
PostPosted: Sun Oct 30, 2011 7:59 am    Post subject: Bing Carb Failure Reply with quote
Jason/Gang:
Thanks for the info. I missed it first time around.
I don't normally follow the Kolb BBS, but receive the antiquated email Kolb
List. That is why I missed the photos of the float bowl.
Just pulled the float bowls a couple days ago, before Rev posted the
problem. In the future when I pull the float bowls, I'll make sure the
guide pins are still secure.
Richard Pike
PostPosted: Sun Oct 30, 2011 2:10 pm    Post subject: Re: Bing Carb Failure Reply with quote
Got this update this morning from Dean Vogel at Lockwood Aviation:
"We have seen that issue with the float bowls before. I have – for a while now – included the checking of that detail in the Maintenance training class when we go through the carburetors. The only solution is to replace the float bowl."
On the other hand, since this is East Tennessee, and we do things our own way - the owner reamed the hole a hair larger, packed it with JB Weld, and drove the pin in FIRMLY.
Will keep ya posted...
Richard Pike
Kingsport, TN 3TN0
Thom Riddle
PostPosted: Sun Oct 30, 2011 2:22 pm    Post subject: Bing Carb Failure Reply with quote
"The only solution is to replace the float bowl."
If you are selling Bing parts, that is the only way Smile.
Thom
Richard Pike
richard (at) bcchapel(dot)org
Kingsport, TN 3TN0
Now faith is the substance of things hoped for, the evidence of things not seen.
Hebrews 11:1
http://forums.matronics.com/viewtopic.php?p=356353#356353
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
