Dynon OAT probe location
chris Sinfield
PostPosted: Fri Oct 28, 2011 9:46 pm    Post subject: Dynon OAT probe location Reply with quote
Hi all
I was going to put the Dynon OAT probe in the LH cabin air intake .
Any issues with that location
Chris
psm(at)att.net
PostPosted: Sat Oct 29, 2011 1:50 am    Post subject: Dynon OAT probe location Reply with quote
Hi Chris,
I didn't bother installing my temperature probe anywhere. I suppose it
might be nice as a conversation piece with your passenger, but for
navigation purposes the GPS seems to do just fine at "Computing" ground
speed.
You don't want the probe to be hit with direct sun light. In your case
I guess it depends on how far in the cabin air intake system you put
it. If it is far enough away from the air input to avoid sun light then
perhaps it would not work at all if you close off the cabin air flow -
as I have done for winter operations.
Good luck,
Paul
Camas, WA
On 10/28/2011 10:46 PM, chris Sinfield wrote:
Hi all
Chris
http://forums.matronics.com/viewtopic.php?p=356246#356246
jaybannist(at)cs.com
PostPosted: Sat Oct 29, 2011 4:59 am    Post subject: Dynon OAT probe location Reply with quote
Chris,
That seems the ideal location to me. Here is a photo of mine.
Jay
--> Zenith601-List message posted by: "chris Sinfield" <chris_sinfield(at)yahoo.com.au (chris_sinfield(at)yahoo.com.au)>
Hi all
Chris
" target="_blank">http://www.matronics.com/Navigator?Zenith601-List
 Filesize:  138.74 KB
 Viewed:  6520 Time(s)
jeffrey_davidson(at)earth
PostPosted: Sat Oct 29, 2011 6:38 am    Post subject: Dynon OAT probe location Reply with quote
Chris,
That is a popular location and works well. Mine is under the fiberglass saddle on the tail. It is in the open air and still not in direct sunlight. That works well too but the wires are longer.
Jeff D
zman601xl(at)aol.com
PostPosted: Sat Oct 29, 2011 6:39 pm    Post subject: Dynon OAT probe location Reply with quote
nickhelsper(at)gmail.com
PostPosted: Sat Oct 29, 2011 6:49 pm    Post subject: Dynon OAT probe location Reply with quote
I installed one in a little aluminum tube that stuck out of the bottom of the wing stub.  I filled the end of the tube with flox, and drilled a hole in the front of the tube, so that the free airstream could get to the probe.  I think the cabin air vent would work nice too.
-nick
On Sat, Oct 29, 2011 at 9:36 PM, <zman601xl(at)aol.com (zman601xl(at)aol.com)> wrote:
