Transponder antennas
harley(at)AgelessWings.co
PostPosted: Tue Oct 25, 2011 6:15 am    Post subject: Transponder antennas Reply with quote
Now that I'm finally finished with construction, and in the process of getting the instruments and engine installed, I decided yesterday to collect all the little bags of pieces and parts that I've acquired over the years to see what I have, and what I may need.
In the process, I found that I have two transponder antennas. Apparently, one I got from RST when I bought the antenna set for my Long EZ from him, and the other came with the Microair transponder. They are slightly different, and is there any reason to believe that one is better than the other?
Jim Weir's (at least I THINK RST supplied it. It's been too many years ago! <G>) is simply a straight aluminum rod, threaded on one end. It comes with tab type connectors and grommets (to isolate it from the ground plane) that mount between the nuts for the wires to attach.
The other one was made by TED Manufacturing of Kansas for Microair, looks more "professional" and already terminates in a BNC connector. The other end has a ball tip, and although not magnetic appears too hard and shiny to made of aluminum. I believe it is stainless steel. The antenna is solidly mounted through the center of the BNC connector, isolated from the outside by a plastic sleeve.
The Microair unit did not come with a ground plane (I guess they assume I have a metal aircraft), but the RST unit did. So, I'll be using the RST ground plane plate (it's a 5-1/2 inch diameter octagon) with either one.
They are both EXACTLY the same length (tip to connector), So, the questions...
In identical location installations, which one might prove to be better as a transpoder antenna in a Long EZ? Does the ball tip do anything other than not poking out an eye? Is the stainless a worse application for the antenna than the aluminum one? Is the "professionally" manufactured unit with the antenna mounted directly to, but isolated from, the BNC connector a more robust mounting.
Or doesn't it make any difference (since many of you simply use a bolt)?
Harley Dixon
Long EZ N28EZ
www.agelesswings.com
PostPosted: Tue Oct 25, 2011 9:38 am    Post subject: Transponder antennas Reply with quote
Depends on what you call "better". From a performance perspective,
there is probably no observable difference.
Your plastic airplane drives a requirement for
adding a ground plane under the antenna. Whether
you fabricate one or use the RST part makes no
difference. The TED product is probably more robust
and makes a cleaner interface with the feed line.
So a plan to pick the best of parts from two
antennas in search of the most elegant solution
is sound.
Could you photograph the RST product and post
the picture to the list?
I searched the 'net for a picture and/or references
to the RST transponder antenna and stumbled across this
entry by Jim Wier:
I'm starting my Oshkosh forum writing and I need to know if anybody has a spare
commercial transponder antenna -- the kind with a BNC connector on one end and a
little chrome BB on the other end, mounts in a single hole. I had three or four
of them and have given them away over the years to folks that needed one.
Beg, borrow, steal, or buy. Your choice. Happy to reciprocate some day when
YOU need something. I'll be happy to send a SASbox if that is your preference.
Jim
It does give one pause to wonder why he wasn't installing
one of his own antennas . . . or it may well be that
the antenna you have didn't come from RST. In any
case, I'd like to see it . . . or if you have no
plans to use it, might I have it?
Bob . . . [quote][b]
PostPosted: Tue Oct 25, 2011 10:42 am    Post subject: Transponder antennas Reply with quote
Since there is functionally no difference between the two antennas, sure, you can have the "RST" unit, Bob...I'll use the TED antenna (it looks more professional!)...and fabricate a new ground plane plate for it.
Now you've got me wondering. If it was not from RST, then I have no idea where else I would have got that aluminum antenna from...it was on a shelf at my hangar with the parts that I did get from RST that I didn't use (nav antenna and some BNC connectors and cable)...and the octagon ground plane was with it. BTW...now that I've had it in my hand, the grommet is fiber, not rubber.
I'll send the ground plane along with it...where do you want me to send them?
Here's two pictures of the front and back of it that I just took a few minutes ago (I assembled it...the small parts all came in a small plastic bag...the ground plane was separate):
[img]cid:part1.09010702.04080703(at)agelesswings.com[/img][img]cid:part2.05080503.04060901(at)agelesswings.com[/img]
What do you plan to do with it?
Harley
is sound.
entry by Jim Wier:
Jim
 Filesize:  25.5 KB
 Viewed:  3094 Time(s)
 Filesize:  20.69 KB
PostPosted: Wed Oct 26, 2011 6:21 am    Post subject: Transponder antennas Reply with quote
Actually, the pictures will suffice.
Yeah, that makes sense. It needs to be mechanically
rigid.
I published a similar configuration in the 'Connection way
back when. It would be interesting to know who made it.
In any case, the pictures are great. I'll probably add them
to the photo album on the website.
I would have photographed it and then put it into the collection
of curiosities . . . but I have plenty of those laying around!
PostPosted: Wed Oct 26, 2011 7:00 am    Post subject: Transponder antennas Reply with quote
Well, then...if anyone else here wants it, just drop me a line. Just pay for the postage...I am talking about the one in the pictures, not the TED unit, which I will be using.
Harley
