100% stop
rlborger(at)mac.com
PostPosted: Mon Oct 24, 2011 1:17 pm    Post subject: 100% stop Reply with quote
Paul,
I realize this answer is a bit tardy, but I have been all wrapped around the axle on other issues and never got around to an answer.
I have a suggestion for your 100% throttle stops. They are called "spring plungers" in the McMaster-Carr on-line catalog. Here is a picture of a set:
From RIGHT to LEFT: Spring Plunger and Mounting Base, Spring Plunger partially screwed into the Mounting Base, Spring Plunger fully screwed into the Mounting Base, Mounting Base turned 180ş showing the ball end of the Spring Plunger. The black thing is the Adjusting Wrench.
I have not actually installed them yet, but I plan to give them a try once I get the W/B issues associated with the tri-gear conversion sorted out and things are running again.
The plan is to establish the 100% point. Then installing one of these things one each side of the throttle plate so that the throttle hits the stop-ball at 100%. Then a good push should advance the throttle through the spring plunger balls and on to 115%.
These things come in a wide variety of shapes and sizes. Go to http://www.McMaster.com/ and they are about 1/3 of the way down the main contents page under "Fabricating" -- "Clamping and Positioning"
Good luck.
Blue skies & tailwinds,
Bob Borger
http://www.europaowners.org/N914XL
Europa XS, Short Wing, Intercooled Rotax 914
rlborger(at)mac.com
Cel: 817-992-1117
On Jun 1, 2009, at 3:30 PM, europa(at)pstewart.f2s.com wrote:
Has anyone got any pics of cunning ways to make a 100% throttle stop for the
914?
Paul
 Filesize:  1.23 MB
 Viewed:  6175 Time(s)
frans(at)privatepilots.nl
PostPosted: Tue Oct 25, 2011 4:58 am    Post subject: 100% stop Reply with quote
On 10/25/2011 11:30 AM, PHILLIPS I wrote:
Hi guys
I used a stainless steel throttle plate that's easy to to make and fit
and with no moving parts to jam or break,
Same here. Works perfect, and doesn't add any unnecessary weight and
complexity.
Frans
rlborger(at)mac.com
PostPosted: Tue Oct 25, 2011 5:13 am    Post subject: 100% stop Reply with quote
Ivor & Frans,
A Picture please!
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
> Hi guys
Same here. Works perfect, and doesn't add any unnecessary weight and complexity.
Frans
Trevpond(at)aol.com
PostPosted: Tue Oct 25, 2011 6:22 am    Post subject: 100% stop Reply with quote
Me too, a plate is the way to go!
Trev
G-LINN
In a message dated 25/10/2011 14:13:26 GMT Daylight Time, rlborger(at)mac.com writes:
--> Europa-List message posted by: Robert Borger <rlborger(at)mac.com>
Ivor & Frans,
A Picture please!
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
--> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl>
> Hi guys
Frans
the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
klinefelter.kevin(at)gmai
PostPosted: Tue Oct 25, 2011 7:56 am    Post subject: 100% stop Reply with quote
I made a plate out of 1/16" phenolic sheet that mounts under the cover plate. The screw holes are elongated to make it adjustable. The throttle lever only touches the phenolic, so it feels smooth.
Kevin
On Tue, Oct 25, 2011 at 7:19 AM, <Trevpond(at)aol.com (Trevpond(at)aol.com)> wrote:
[quote] Me too, a plate is the way to go!
Trev
G-LINN
In a message dated 25/10/2011 14:13:26 GMT Daylight Time, rlborger(at)mac.com (rlborger(at)mac.com) writes:
--> Europa-List message posted by: Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)>
Ivor & Frans,
A Picture please!
Bob Borger
3705 Lynchburg Dr.
Cel: [url=tel:817-992-1117]817-992-1117[/url]
--> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)>
> Hi guys
Frans
arget="_blank">http://www.matronics.com/Navigator?Europa-List
ttp://forums.matronics.com
rlborger(at)mac.com
PostPosted: Tue Oct 25, 2011 9:24 am    Post subject: 100% stop Reply with quote
Ivor,
OK, went back to the e-mail and waited long enough for the picture to download this time.
Thanks!
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
On Oct 25, 2011, at 11:13 AM, PHILLIPS I wrote:
Hi Bob
Picture is included in my first post,
regards
ivor
ptag.dev(at)tiscali.co.uk
PostPosted: Wed Oct 26, 2011 3:37 am    Post subject: 100% stop Reply with quote
Hi! Guys
Same for me no problems in 900 hours with two different engines .......just
added a turbo gate to the one I used for the Jabiru 6 original .engine for
the 914 Rotax.
If it ain't broke don't fix it .and if it's complicated it will break as
sure as "eggs is eggs".
Bob Harrison G-PTAG .
