pnicholson
Posted: Sat Oct 22, 2011 1:39 pm Post subject: Engine Vibration |
While crossing over the field in my nanchang, I proceeded to power back. As I brought the throttle back through 550MP, the engine began to vibrate violently. I powered back up and all was fine... Down again and the vibration returned. It ran rough on the entire approach. It was 8 degrees C so my friend suggested carb ice. I'll be doing a run up tomorrow to see if the problem remains. Does anything else come to the minds of the collective list?
Phil N
N13472(at)aol.com Guest
Posted: Sat Oct 22, 2011 4:36 pm Post subject: Engine Vibration |
Check to see that you did not unlock the primer with you elbow. If it is
open when
you pull the throttle and vacuum builds up it will suck fuel and run very
very rich and rough.
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV
89019
Cell 702-595-2680
cjpilot710(at)aol.com Guest
Posted: Sat Oct 22, 2011 5:57 pm Post subject: Engine Vibration |
Check your primer.
Pappy
In a message dated 10/22/2011 5:39:53 P.M. Eastern Daylight Time, pednicholson(at)gmail.com writes:
| Quote: | --> Yak-List message posted by: pednicholson(at)gmail.com
Phil ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
wlannon(at)shaw.ca Guest
Posted: Sat Oct 22, 2011 6:47 pm Post subject: Engine Vibration |
An unlocked primer is the most likely cause but also check for an intake
leak. If you have an intake drain kit installed (lower 3) check for
cracking around the drain boss welds.
Walt
Posted: Sat Oct 22, 2011 7:46 pm Post subject: Engine Vibration |
After my recent experiences, I can come up with some bad things but stay with simple straight forward ones for now. Do what has been suggested first and let the Zebras sleep for now.
Doc
Sent from my iPad
On Oct 22, 2011, at 9:44 PM, "Walter Lannon" <wlannon(at)shaw.ca> wrote:
An unlocked primer is the most likely cause but also check for an intake leak. If you have an intake drain kit installed (lower 3) check for cracking around the drain boss welds.
Walt
