EI clock chime
WRShank(at)spoerrprecast.
PostPosted: Tue Oct 18, 2011 7:25 am    Post subject: EI clock chime Reply with quote
Bob and all, I have a EIectronics Intermational clock that will ground a line when it reaches 0:00. I would like to hook a chime to the line and run it to my audio panel. Other than EI’s tone generator, is there an easy way to do this?
Bill Shank RV6
PostPosted: Tue Oct 18, 2011 7:57 am    Post subject: EI clock chime Reply with quote
"Easy" is difficult to quantify. How handy
are you with the soldering iron? In the
audio systems chapter of the 'Connection
I illustrated a variety of tone generators
that could be adapted to various functions
in the well appointed airplane.
The SIMPLEST solution is an 8-pin PIC
uController with some pretty rudimentary
software. This approach could do about
any sort of 'noise' short of a string
quartet. The schematics I illustrated
are less versatile but can be fabricated
from rudimentary parts.
What would you like to tone to sound like?
Bob . . . [quote][b]
james(at)etravel.org
PostPosted: Tue Oct 18, 2011 8:48 am    Post subject: EI clock chime Reply with quote
Hi Bill,
I used this line from the EI clock, but instead take it to a light on the annunciator panel (design as supplied by another lister here).  It lights up a green 1 x 1/2" or so LED array.
James
On 18 October 2011 16:36, Bill Shank <WRShank(at)spoerrprecast.com (WRShank(at)spoerrprecast.com)> wrote:
Bill Shank  RV6
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
PostPosted: Tue Oct 18, 2011 8:58 am    Post subject: EI clock chime Reply with quote
Bob, I’m thinking a ding dong sound, nothing that would startle you. I will take a look at the Connection tonight. I have no experience soldering boards but would like to learn.
Bill Shank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Tuesday, October 18, 2011 11:54 AM
Subject: Re: EI clock chime
Bob and all, I have a EIectronics Intermational clock that will ground a line when it reaches 0:00. I would like to hook a chime to the line and run it to my audio panel. Other than EIs tone generator, is there an easy way to do this?
PostPosted: Tue Oct 18, 2011 9:10 am    Post subject: EI clock chime Reply with quote
Hi Bill,
James
Bill Shank  RV6
PostPosted: Thu Oct 20, 2011 6:24 pm    Post subject: Re: EI clock chime Reply with quote
Here is a circuit by Forrest M. Mims, III that makes a tone when the input goes low.
https://lh4.googleusercontent.com/-USAZBtVHo64/TqDWOf5qJcI/AAAAAAAAAcU/fBvHVErh8Bs/s439/GatedToneSource.gif
Joe Gores
Joe Gores
peter(at)sportingaero.com
PostPosted: Fri Oct 21, 2011 8:32 am    Post subject: EI clock chime Reply with quote
Joe, that's a circuit I might be interested in for another application,
but I don't see a power line? Can the tone be automatically shut off
after (say) 2 seconds?
Peter
Joe Gores
Joe Gores
http://forums.matronics.com/viewtopic.php?p=355625#355625
Mike Welch
PostPosted: Fri Oct 21, 2011 8:52 am    Post subject: EI clock chime Reply with quote
Peter,
I'm not Joe, he's much smarter than I am, but the "power line" you're looking for is
inside the drawing labelled " ENABLE (Low= Tone) "
Mike W
On Oct 21, 2011, at 11:29 AM, Peter Pengilly wrote:
Joe, that's a circuit I might be interested in for another application, but I don't see a power line? Can the tone be automatically shut off after (say) 2 seconds?
Peter
> Joe Gores
> Joe Gores
PostPosted: Fri Oct 21, 2011 9:16 am    Post subject: EI clock chime Reply with quote
Vcc is the supply line.
On 21 October 2011 17:29, Peter Pengilly <peter(at)sportingaero.com (peter(at)sportingaero.com)> wrote:
[quote]--> AeroElectric-List message posted by: Peter Pengilly <peter(at)sportingaero.com (peter(at)sportingaero.com)>
Peter
-->  AeroElectric-List message posted by: "user9253"<fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)>
Joe Gores
Joe Gores
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
PostPosted: Fri Oct 21, 2011 10:42 am    Post subject: Re: EI clock chime Reply with quote
I am not really smarter than Mike Welch. But I am better looking. Very Happy
The 74LS368 is powered by 5vdc connected to pin 16 (labeled Vcc). As for automatically shutting off the tone after 2 seconds, another circuit is required for that. Perhaps something like this "One-Shot Tone Burst" circuit: http://www.eleccircuit.com/one-shot-timer-use-ic-ne555/
My favorite electronics book is "Engineer's Notebook" purchased in 1980. Although some of the ICs are no longer available. http://www.amazon.com/Forrest-Mims-Engineers-Notebook/dp/1878707035
The circuit that you use depends on the signal source, whether it is steady on or a pulse. I agree with Bob N that a microprocessor will do everything. Its circuit has the smallest parts count, will sense inputs and (if they meet certain conditions) will output the desired signal for the required time period. If one does not have a programmer, buying that will make the project more expensive. And it will take LOTS of time to learn how to program. That cost of time and money can be spread over several projects.
Joe
[/u]
Joe Gores
grosseair(at)comcast.net
PostPosted: Fri Oct 21, 2011 10:47 am    Post subject: EI clock chime Reply with quote
I believe "ENABLE" is the ground and "Vcc" is 5VDC. When your clock goes
"low" it connects to ground and makes the circuit to activate the tone.
John Grosse
Michael Welch wrote:
Peter,
Mike W
PostPosted: Fri Oct 21, 2011 11:15 am    Post subject: EI clock chime Reply with quote
Thanks for that! If I were to put a pot in place of the 220 resistor would I be able to adjust the volume? Also if I wanted to drive a 600 ohm load - ie an aircraft audio system - would I increase the value of all the resistors by a factor of 75, or would that affect the frequency of the output?
Is the actuated by the down going edge, or because there is a potential difference between enable and Vcc? We used to call that  ac or dc coupled, not sure if that's the correct use of those terms?
Peter
On 21/10/2011 18:12, James Kilford wrote: [quote] Vcc is the supply line.
Peter
Joe Gores
Joe Gores
MS -
e -
PostPosted: Fri Oct 21, 2011 11:22 am    Post subject: EI clock chime Reply with quote
I've found the datasheet for the 74LS368 here, looks like they require only a 5v supply and input voltage, and so I guess only output 5v also - not sure how that will drive my audio panel ...
Peter
Peter
Joe Gores
Joe Gores
MS -
e -
Mike Welch
PostPosted: Fri Oct 21, 2011 11:23 am    Post subject: EI clock chime Reply with quote
John,
Got it!! Thanks for the explanation. Nice easy circuit.
Mike Welch
On Oct 21, 2011, at 1:10 PM, John Grosse wrote:
I believe "ENABLE" is the ground and "Vcc" is 5VDC. When your clock goes "low" it connects to ground and makes the circuit to activate the tone.
John Grosse
> Peter,
> Mike W
PostPosted: Fri Oct 21, 2011 11:48 am    Post subject: Re: EI clock chime Reply with quote
Re: Gated Tone Source
I would not change the value of any component unless you intend to change the tone frequency. The speaker could be replaced with a pot. And a capacitor between the pot and the aircraft audio system will block DC. Bob's advice is needed here.
Joe
Joe Gores
Mike Welch
PostPosted: Fri Oct 21, 2011 11:54 am    Post subject: EI clock chime Reply with quote
Joe,
Henry Waxman, (D) Ca is better looking than me!! See;
http://costonscomplaint.blogspot.com/2011/05/rep-henry-waxman-scaring-seniors-again.html
hahahahaha
Joe Gores
walter.fellows(at)gmail.c
PostPosted: Fri Oct 21, 2011 12:43 pm    Post subject: EI clock chime Reply with quote
I have been trying to unsubscribe to the list. I follow the instructions by hitting the execute button and it tells me that I don't need to take any other action to unsubscribe. Nevertheless I keep receiving the emails. Please unsubscribe me.
On Fri, Oct 21, 2011 at 12:48 PM, user9253 <fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)> wrote:
--> AeroElectric-List message posted by: "user9253" <fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)>
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=355678#355678
le, List Admin.
#avg_ls_inline_popup{position:absolute;z-index:9999;padding:0px;margin:0px;overflow:hidden;wordWrap:break-word;color:black;font-size:10px;text-align:left;line-height:130%;}#avg_ls_inline_popup div{border-width:3px;border-style:solid;padding:3px;padding-left:8px;padding-right:8px;-moz-border-radius:5px;-webkit-border-radius:5px;}#avg_ls_inline_popup .red{border-color:#D20003;;background-color:#F5D4C1;;}#avg_ls_inline_popup .orange{border-color:#F57301;;background-color:#FFD3B0;;}#avg_ls_inline_popup .yellow{border-color:#EAA500;;background-color:#FEEFAE;;}#avg_ls_inline_popup .green{border-color:#00A120;;background-color:#C3E5CA;;}
PostPosted: Fri Oct 21, 2011 1:32 pm    Post subject: EI clock chime Reply with quote
Bob, working on the two tone generator in the ‘Connection, what is the resistor that is between the two timers? Is it 220k ?
Bill Shank RV6
