Cowl Install
Phil(at)ReliantAir.com
PostPosted: Mon Oct 17, 2011 8:33 am    Post subject: Cowl Install Reply with quote
Gary, finally working on installing the new cowling on my Grumman. Some questions
<![if !supportLists]>- <![endif]>Do you put the plexiglass cover over the landing light as it is on the original cowl, or do you leave it off?
<![if !supportLists]>- <![endif]>On the powerflow exhaust do you align the muffler with the longitudinal axis or angle it slightly outboard?
<![if !supportLists]>- <![endif]>Do you cut the cowling in such a way as to be able to remove the right hand side of the bottom cowling without removing the muffler? I assume that to do that you fabricate a plate to close the slot and maintain integrity of the cowl.
Phil Kelsey
ReliantAir
From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of Gary Vogt
Sent: Thursday, October 06, 2011 13:45
Subject: Re: Short-stack Powerflow exhaust - aerodynamic cover for it?
Hi Pete,
I've made 3 different fairings that fit behind the short stack. The short one worked the best. Plus, it fits up snug behind the pipe so it closes the hole created when you cut out the exit ramp. I can have Dave make you one for $100 with shipping. You'll need to do some trial and error on the mounting to get the least drag.
My 77 Cheetah would true out at about 140 knots. That's running over redline. McCauley prop. Stock exhaust. It was light too. One radio. One GPS. No VOR. But, even with ported and polished cylinders and the HC mod, a loaded Tiger would out climb it.
Lots of drag. I buried the comm antennas, got rid of the VOR antennas and steps.
I restored a 77 Cheetah a few years back. He did everything to that plane. With a New LyCon engine and Sensenich prop, he could true at 142 knots at 2800 RPM with the steps and VOR antennas.
Gary
Sent: Thursday, October 6, 2011 7:32 AM
Subject: Short-stack Powerflow exhaust - aerodynamic cover for it?
Hi Gary: My plane has the short stack Powerflow exhaust. I think it's kinda draggy up there and was wondering if you ever made some covering for it that reduced it's airflow 'signature' (parasitic drag). The oil vent tube also is kinda draggy down there.
Just wondering where you found speed improvements on the Cheetah by reducing parasitic drag. Thank you!
-- Pete Kuhns
N27161, '79 Cheetah
GEZ, Shelbyville, IN
Email scanned by PC Tools - No viruses or spyware found.
(Email Guard: 7.0.0.26, Virus/Spyware Database: 6.18280)
http://www.pctools.com
teamgrumman(at)yahoo.com
PostPosted: Mon Oct 17, 2011 8:11 pm    Post subject: Cowl Install Reply with quote
1. The plexiglass goes between landing light housing and the cowling.
2. Good question. Actually, it needs to go just slightly in. Normally, I make it parallel to the longitudinal axis as a rule.
3. Cut the opening to the end of the ramp. You don't need to fill the opening. The airflow is out of the cowling. If it were an issue, I'd make you fill the hole behind the nose strut.
You can add another nut plate if you like to attach the open ends to the firewall.
Did you see the template I sent out for the cutout?
Gary
On Oct 17, 2011, at 9:30 AM, "Phil Kelsey" <Phil(at)ReliantAir.com (Phil(at)ReliantAir.com)> wrote:
- Do you put the plexiglass cover over the landing light as it is on the original cowl, or do you leave it off?
- On the powerflow exhaust do you align the muffler with the longitudinal axis or angle it slightly outboard?
- Do you cut the cowling in such a way as to be able to remove the right hand side of the bottom cowling without removing the muffler? I assume that to do that you fabricate a plate to close the slot and maintain integrity of the cowl.
Phil Kelsey
ReliantAir
From: owner-teamgrumman-list-server(at)matronics.com (owner-teamgrumman-list-server(at)matronics.com) [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of Gary Vogt
To: [url=mailto:teamgrumman-list(at)matronics.com]teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)[/url]
Hi Pete,
Gary
From: Pete Kuhns <pkuhns(at)gmail.com (pkuhns(at)gmail.com)>
-- Pete Kuhns
N27161, '79 Cheetah
PostPosted: Tue Oct 18, 2011 5:13 am    Post subject: Cowl Install Reply with quote
Gary thanks for the info. I know I saw that template in my email at one time, can’t find it now. Could you resend it to me?
Phil
From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of Gary L Vogt
Sent: Monday, October 17, 2011 23:59
Subject: Re: Cowl Install
Gary
Phil Kelsey
ReliantAir
To: teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
Hi Pete,
Gary
-- Pete Kuhns
N27161, '79 Cheetah
(Email Guard: 7.0.0.26, Virus/Spyware Database: 6.18530)
PostPosted: Tue Oct 18, 2011 7:35 pm    Post subject: Cowl Install Reply with quote
Phil,
Sure, no problem.
Here is the template.
Sent: Tuesday, October 18, 2011 6:10 AM
Subject: RE: Cowl Install
Phil
Subject: Re: TeamGrumman-List: Cowl Install
Gary
Phil Kelsey
ReliantAir
Hi Pete,
Gary
-- Pete Kuhns
N27161, '79 Cheetah
 Filesize:  25.11 KB
 Viewed:  2359 Time(s)
