Weight of Hartzell 2 bld
acs(at)acspropeller.com.a
PostPosted: Fri May 19, 2006 1:06 am    Post subject: Weight of Hartzell 2 bld Reply with quote
Sorry Deems, the chart info didn't reproduce correctly. Short answer 50lbs approx.
John 40315
Deems Davis
PostPosted: Fri May 19, 2006 3:24 am    Post subject: Weight of Hartzell 2 bld Reply with quote
Thanks John
50lbs approx.
John 40315
LessDragProd(at)aol.com
PostPosted: Fri May 19, 2006 9:02 am    Post subject: Weight of Hartzell 2 bld Reply with quote
50 pounds?  That's it?  Is this the best the RV-10 list can do?
I am willing to say that the Hartzell 80" diameter blended airfoil propeller and spinner assembly weighs at least 65 pounds ready to bolt ontothe engine.
The Hartzell 72" diameter propeller and spinner assy with 7666-4 blades weighs 56 pounds.
The Hartzell 80" diameter propeller and spinner assy weighs 66 pounds.
I would suggest that the blended airfoil blades are not significantly lighter than the standard aluminum blades.
Is someone on the RV-10 list actually willing to weigh their Hartzell blended airfoil propeller and spinner assembly to provide a REAL weight?
Jim Ayers
In a message dated 05/19/2006 4:25:46 AM Pacific Daylight Time, deemsdavis(at)cox.net writes:
--> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net>
Thanks John
50lbs approx.
John 40315
brinker(at)cox-internet.c
PostPosted: Fri May 19, 2006 9:45 am    Post subject: Weight of Hartzell 2 bld Reply with quote
          &nbs p;  I've got an 80" CS still in the box I'll try to weigh it this weekend if I have time and let you know.
Randy
JSMcGrew(at)AOL.COM
PostPosted: Fri May 19, 2006 10:22 am    Post subject: Weight of Hartzell 2 bld Reply with quote
Mine weighed in at 57 lbs.
Jim McGrew
40134
In a message dated 5/19/2006 11:07:43 A.M. Mountain Daylight Time, LessDragProd(at)aol.com writes:
< FONT style"BACKGROUND-COLOR: transparent" faceArial color#000000 size 2> 50 pounds?  That's it?  Is this the best the RV-10 list can do?
I am willing to say that the Hartzell 80" diameter blended airfoil propeller and spinner assembly weighs at least 65 pounds ready to bolt ont othe engine.
Jim Ayers
Thanks John
John Dunne wrote:
Sorry De ems, the chart info didn't reproduce correctly. Short answer
50lbs approx.
John 40315
Jim "Scooter" McGrew
jsmcgrew(at)aol.com
bcondrey(at)cox.net
PostPosted: Fri May 19, 2006 12:48 pm    Post subject: Weight of Hartzell 2 bld Reply with quote
I just weighed mine - 53.6 lbs. That is a new Hartzell 2 blade blended
airfoil prop as ordered from Vans and delivered from Hartzell. Does not
count any spinner/backplate related hardware - just the prop w/blades and
hub as delivered.
Bob #40105
Subject: Re: Weight of Hartzell 2 bld
Date: Fri May 19 - 10:02 AM
propeller
and spinner assembly weighs at least 65 pounds ready to bolt onto the
engine.
weighs 56 pounds.
Jim Ayers
Thanks John
bgill1(at)charter.net
PostPosted: Fri May 19, 2006 2:15 pm    Post subject: Weight of Hartzell 2 bld Reply with quote
OK you got my curiosity up... Went down and unboxed mine (std from Vans)
and it weights in at 53.5 - again out of the box - no spinner or other
attachments. I used the wife's bathroom scales so use the info at our
own risk Smile
Byron #40253 finishing & FFW
PostPosted: Fri May 19, 2006 6:35 pm    Post subject: Weight of Hartzell 2 bld Reply with quote
Hartzell 80" diameter blended airfoil propeller.
Around 54 pounds bare.
Around 57 pounds with spinner installed.
That is impressive.
Jim Ayers
PS this is not sarcasm.
The Hartzell 2 blade 80" diameter propeller assembly used on the Harmon Rocket 2 weighs 66 pounds.
PostPosted: Sat May 20, 2006 7:36 am    Post subject: Weight of Hartzell 2 bld Reply with quote
    Weighed my 80" c/s Hartzel complete with spinner assembly on a pair of digital bath scales and got 56.0 pounds exactly on three different weigh-in's on the same scales. Letting the scales recalibrate on each weigh-in.
Randy
