EnclosedTrailering
KeysFox
PostPosted: Wed Oct 12, 2011 7:02 am    Post subject: EnclosedTrailering Reply with quote
Lloyd
I have a trailer like the one Kitfox had built for factory aircraft
transport many years ago. It is Eight foot 6 inch wide. Mine is 27 long
inside and is a little taller than the Kitfox unit so I can have room to
camp out in it over night if I wanted and carry equipment. It is a tight
fit with 2" wall studs. The wall studs need to be 2 inch or 1 1/2 inch
thick or the opening is too small, so you may need a custom builder. Pace,
Wells Cargo etc don't want to build trailers with thin corner studs
because they break bouncing down the road. I installed gussets or knees at
the corners on the last two studs to solve that problem.
Later i bought a smaller used trailer that had been built for a Kitfox so
I could keep a secong plane at a second home. It turned out to be 9 feet
wide which makes loading MUCH easier. Being 9' wide has not been a problem
for me. I have a lot of experience towing larger boats and 10 foot wide
boats are very common trailer rigs along coastal states without any
permits. If i were to build another it wouyld be 9' wide with 1 1/2 inch
wall studs, closely spaced for strength and with a one piece roof. Roof
joints leak because the trailer flexes some bouncing down the road. The
first trailer has a one piece roof and does not leak. The second has maybe
6 seams and IT LEAKS despite all the RV roof sealer I have tried.
Torsion axles allow the trailer bed to be lower than springs. This is an
advantage because the ramp incline is shallow. I pull mine in by hand
without a winch most of the time, and I'm a 64 year old 170 lbs weakling.
Both trailers have 12 volt winches for when I need them. Make sure you can
get load range E tires and wheels or figure on blowing tires frequently.
Trailer buiders have recommended soft 3500 lb rated axles for about 7,000
lb gross to avoid a ride that's harsh on the plane.
Grove style gear is too wide to allow loading nose forward. Gear can't get
past fenders inside. When loaded tail first, the engine end wants to
bounce around too much on its gear so I end up using heavy rubber bungees
and straps to float mounts to dampen the bouncing. I use chain straps over
the tires like you see sometimes on car tires when a car is on a trailer.
This helps prevent the plane from moving forward with hard braking or from
moving sideways. Of couse the walls have padding to prevent wing damage.
And the Kitfox braces that help support the wings forward and aft are
important or the fuselage can bend ahead of the tail or the connection of
the rear spar to cabin can be damaged. Off load all fuel you can before
trailering to get weight out of the wing.
I'm the only one I know who uses a small tail wheel trailer to move the
Kitfox maybe 3/4 mile from my house thru a back gate into one of my home
airports. The tail wheel is strapped in a "socket" on the deck of the
small trailer. This makes swinging the wing easy because the tail is
elevated into nearly flying position. And makes siphoning more fuel out of
wing tanks easier than with tail down. I roll the plane into both trailers
using the small tailwheel trailer and snap the small trailer hitch onto a
ball mounted to the floor of the big trailer. This helps keep the plane in
position. A support under the tail spring takes some load off of that
spring. Most folks who trailer their Kitfoxes find this to be important.
I have probably towed my Kitfox IV with Rotax 912 75,000 miles inside the
trailers so far without any significant problems.
There are lots of additional details that might be helpful but this gets
the conversation started. My cell is 443-480-1023. I'm retired, have the
plane in the Grand Canyon area now and am happy to chat anytime or e-mail.
Beware that I Only check e-mail every few days while touring.
Bob Jones
443-480-1023
<7suds(at)chartermi.net>
BJ,
I am looking to build an enclosed trailer for my Kitfox 5 sometime in the
future, would love to hear any insight and suggestions you might have for
me
from your trailering experiences.
Lloyd C
Northern Mi
KF 5 912 IVO IFA
B Jones
N154K
443-480-1023
kitfox555(at)sbcglobal.ne
PostPosted: Thu Oct 13, 2011 5:44 pm    Post subject: EnclosedTrailering Reply with quote
I also built one, What I did is, got a old boat trailer and welded up a level floor put plywood down and made side and top by bending 3/4 EMT welding it all together I made it the widest that Cal. will allow 8'6" then put sheet metal and riveted to the EMT. Put down carpet and a C channel that is for the tail wheel ride in with a stop at the end. Then I came up with a Mount for under the tail wheel assemble and is pinned to the rail to support the tail section with a mount that goes sideways from the tail to hold it in place . Then I made Ty downs for in front and back of each wheel to ratchet down to keep it in place. I have wing stabilizer's to hold the wing. A must when you travel. The back, I made a door /ramp to push it in. Then I painted (with Mcbean permission) a large logo of Kitfox. I have had it for 21/2 years now, I take it to airshows. We can sleep in it when the plane is out. we also take it to the desert and it is my hanger at the airport. I hope this inspires you to build one too
Jerry Evans
KitfoxII
Magalia Calif.
N582'er'
kitfox 555
--- On Wed, 10/12/11, bjones(at)dmv.com <bjones(at)dmv.com> wrote:
Subject: RE: Re: EnclosedTrailering
Date: Wednesday, October 12, 2011, 7:59 AM
--> Kitfox-List message posted by: bjones(at)dmv.com (bjones(at)dmv.com)
Lloyd
Bob Jones
443-480-1023
[quote] --> Kitfox-List message posted by: "Lloyd & Lorrie Cudnohufsky"
<7suds(at)chartermi.net (7suds(at)chartermi.net)>
BJ,
me
Lloyd C
Northern Mi
KF 5 912 IVO IFA
 Filesize:  4.1 KB
 Viewed:  3442 Time(s)
 Filesize:  4.53 KB
 Filesize:  2.85 KB
 Filesize:  3.79 KB
