Breeze up the boom tube
rickofudall
PostPosted: Wed Oct 05, 2011 12:39 pm    Post subject: Breeze up the boom tube Reply with quote
Some time back I did an experiment to find the answer to the question of just how much air is flowing back up the boom tube of my Mk III. The post that describes what I did is in the archives, but as a rule of thumb you can figure that whatever your airspeed the air coming back up the boom tube is half that. For example, at an indicated airspeed of 80 mph the draft coming up the boom into the cockpit was 40 mph IAS.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
byoungplumbing(at)gmail.c
PostPosted: Wed Oct 05, 2011 1:03 pm    Post subject: Breeze up the boom tube Reply with quote
Rick Girard
when I built the mkiii. I heat formed a piece of fabric to fit inside the rear of the tube, just ahead of the elevator bell crank. then I glued it in place with polly tack. I then cut small slits in it for the elevator and rudder cables. I think if I was doing it again. I would take one inch of the 6 inch tube, split it to fit it inside the main tube. then glue the fabric to the outside of the 1 inch piece , then slid it in the tail boom tube. that way it would have been removable if the need presented itself. that stops the wind movement, I don't know if it would stop critters or not. I suppose you could do it with some screen wire, then cover that with the fabric, the fabric would create an anti chafe buffer to the screen wire and the boom tube,
Boyd young
mkiii utah
Thom Riddle
PostPosted: Wed Oct 05, 2011 1:17 pm    Post subject: Breeze up the boom tube Reply with quote
Rick,
That is an interesting observation. I have never noticed any reverse airflow up my Slingshot's tail but that does not mean it isn't there. IF that phenomenon is not characteristic of the SS but is for most Kolbs I speculate that it might be caused, or at least influenced by the relative positions of the horizontal stabilizer and boom tube. On most Kolbs the leading edge of the HS is well above the centerline of the boom tube, whereas on the SS it is even with (parallel) with the boom tube. There could be other factors too. I am not even sure what would be an easy way to detect/measure this reverse airflow up my SS tail. If it is dramatic as you say on my SS, I would think it would be obvious to me, but it is not at all. How did you determine the speed of roughly half of forward speed? Is it something I could easily replicate on my SS?
Thom
On Oct 5, 2011, at 4:42 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
[quote]Some time back I did an experiment to find the answer to the question of just how much air is flowing back up the boom tube of my Mk III. The post that describes what I did is in the archives, but as a rule of thumb you can figure that whatever your airspeed the air coming back up the boom tube is half that. For example, at an indicated airspeed of 80 mph the draft coming up the boom into the cockpit was 40 mph IAS.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
rums.matronics.com">http://forums.matronics.com
"http://www.matronics.com/contribution">http://www.matronics.com/contribution
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
PostPosted: Wed Oct 05, 2011 3:00 pm    Post subject: Breeze up the boom tube Reply with quote
Rick,
Thom
i think the direction of wind flow in the boom tube has more to do with the configuration of the cabin area, and whether it has a high or low pressure, this would be determined mostly by how the rear of the cabin is closed in. or lack their of. all things being equal. the air going past the back of the boom tube should pull a negative pressure on the rear of the tube. but if there is a larger negative pressure caused by the cabin enclosure, then the flow would be forward.
boyd young
mkiii ut
David d.
PostPosted: Wed Oct 05, 2011 3:53 pm    Post subject: Re: Breeze up the boom tube Reply with quote
Interesting about the tail draft. I have been trying to figure why my air speed reads about half.
Could this tube draft be causing my air speed to be off?
David d.
Kolb Mark IIIX 582 Blue head
Thom Riddle
PostPosted: Wed Oct 05, 2011 4:11 pm    Post subject: Breeze up the boom tube Reply with quote
Boyd,
You are probably correct. Although I've flown a MkIII several times I've never owned one or flown one enough to get to the point that I notice that sort of thing. All my KOLB ownership experience is in Firestars and the Slingshot, both narrow bodied which have not shown the sucking tail syndrome, at least to a degree sufficient to get my attention.
Thom
On Oct 5, 2011, at 7:02 PM, "b young" <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)> wrote:
[quote] Rick,
Thom
boyd young
mkiii ut
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
rickofudall
PostPosted: Wed Oct 05, 2011 6:22 pm    Post subject: Breeze up the boom tube Reply with quote
I have a Winter ASI for which I made a pitot probe with about 3' of vinyl tube and 2' of aluminum tube. I took it out in my wife's car and stuck it out through the sunroof to calibrate it. Then I positioned it with the probe going back up the boom and went flying. I have lot's of cockpit vents in my Mk III, deliberate and not so and there's no seal at the top of the windscreen. The result is that there's a lot of airflow to create a negative pressure differential in the cabin to suck air in from the boom. That's my theory, anyway.
Rick
On Wed, Oct 5, 2011 at 4:14 PM, Thom Riddle <riddletr(at)gmail.com (riddletr(at)gmail.com)> wrote:
Rick,
Thom
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
rickofudall
PostPosted: Wed Oct 05, 2011 6:25 pm    Post subject: Breeze up the boom tube Reply with quote
Yes, if you have no static source hooked up to your ASI (and assuming you need one, my little Winter that I used for testing doesn't have a static port).
Rick Girard
On Wed, Oct 5, 2011 at 6:53 PM, SS568 <david(at)paulowniatrees.com (david(at)paulowniatrees.com)> wrote:
--> Kolb-List message posted by: "SS568" <david(at)PaulowniaTrees.com>
David d.
http://forums.matronics.com/viewtopic.php?p=354136#354136
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Richard Pike
PostPosted: Wed Oct 05, 2011 7:01 pm    Post subject: Re: Breeze up the boom tube Reply with quote
No hard data, but in the winter the cold air coming out the boom tube opening was freezing me. I cut a round piece of foam with slots for the cables and stuck it in the tube at the front end and it improved things immeasurably.
For what it's worth...
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
David d.
PostPosted: Thu Oct 06, 2011 3:36 am    Post subject: Re: Breeze up the boom tube Reply with quote
I found this site that has a simple way of testing the ASI.
http://www.n56ml.com/airspeed_calibration/
This is with plane in the hangar and the static air is very static. My instruments have their static airs tied together and a plastic tube runs up to a disc up near the pitot tube. What is the significance of this static air as opposed to just using cabin air? Can that disc be defective or stopped up perhaps?
David d.
Thom Riddle
PostPosted: Thu Oct 06, 2011 3:56 am    Post subject: Breeze up the boom tube Reply with quote
Thanks, Rick. Simple solution if you have a have a spare ASI.
Thom
On Wed, Oct 5, 2011 at 10:20 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
[quote]I have a Winter ASI for which I made a pitot probe with about 3' of vinyl tube and 2' of aluminum tube. I took it out in my wife's car and stuck it out through the sunroof to calibrate it. Then I positioned it with the probe going back up the boom and went flying. I have lot's of cockpit vents in my Mk III, deliberate and not so and there's no seal at the top of the windscreen. The result is that there's a lot of airflow to create a negative pressure differential in the cabin to suck air in from the boom. That's my theory, anyway.
Rick
Rick,
Thom
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Ozarkflyer
PostPosted: Thu Oct 06, 2011 9:01 am    Post subject: Re: Breeze up the boom tube Reply with quote
"Breeze up the boom tube......sucking tail syndrome"? Sounds like a Monty Python episode.
zeprep251(at)aol.com
PostPosted: Thu Oct 06, 2011 4:06 pm    Post subject: Breeze up the boom tube Reply with quote
I flew my Firestar fully enclosed in zero degree weather,taped every opening I could find closed,using construction paper and silver tape around the spar carry thru and piped in heat via scat tube from the cooling shroud .Then is when I first discovered the cold draft roaring up the boom tube.Plugging that really did more than the addition of heat from the engine.The primary source of heat with my system was passive solar,and you could survive with that.I started going south for the winter after that.
G.Aman MK3C Firestar 2
Dana
PostPosted: Fri Oct 07, 2011 3:16 pm    Post subject: Breeze up the boom tube Reply with quote
The water manometer described in your link is a good way to calibrate an ASI... engineers have used water manometers in wind tunnels for years.
Cabin air is notoriously NOT at static pressure. Open a vent, pressure goes up. Bad door seal, pressure may go down. Open a window or slip the plane, who knows?
Your plastic disk is an external static air source. It's generally placed on the side of the fuselage, parallel to the airflow, often in pairs to cancel any effects from yaw.
-Dana
"If you're not a liberal at 20, you have no heart. If you are not a conservative when you're 30, you have no head."-- Winston Churchill
Thom Riddle
PostPosted: Sun Oct 09, 2011 10:41 am    Post subject: Re: Breeze up the boom tube Reply with quote
This summer weather in October was waaay too good not to fly, so I flew to Bob Bean's place and landed on his "mature grass" airstrip. No Brakes Required!
Enroute, I stuck my hand back under the rear seat and felt a light breeze, nothing like I think the wide body Kolbs get. It was a little cool to have my forward vents open so this slight breeze was with a bit of negative cabin pressure (presumably) because the aft vents were open in exhaust mode. By the time I got close to BB's place it was warm enough to open the forward vents, which I did. With this bit of positive pressure, I stuck my hand back under the rear seat and the air felt completely static to me.
My conclusion is that in MY slingshot, the breezy boom tube phenomenon is minimal and then only without forward vents open. Other Kolb types or even other slingshots may have a different experience.
After landing at BB's he gave me the grand tour of his brand new pole barn, just finished yesterday except for the garage door. Then we cranked up both the Kolbs and flew about 10 miles NW of his place to have lunch at Abe's Log Cabin restaurant, a very short walk from a very nice two runway grass airstrip, called Ridge Road West. After lunch we departed on our separate ways.
What a glorious October day for flying it was here in western New York.
 Filesize:  229.58 KB
 Viewed:  13726 Time(s)
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
