		hallert
				 Posted: Sat Oct 01, 2011 12:19 pm    Post subject: 601xl engine out glide ratio |
				Does anyone have any glide data on the zodiac? I have tried some engine idle approaches with my AMD 601 XL and find somewhere around 6:1
 ( about 1000ft/min down at 60 kts) with flap setting not making much difference.
 Ted
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		psm(at)att.net Guest
				 Posted: Sat Oct 01, 2011 2:44 pm    Post subject: 601xl engine out glide ratio |
				Hi Ted,
 I'm in the middle of flight testing my XL and have found only slightly
 better glide performance - perhaps 8:1.  Yours might be a little bit
 worse because of the heavy engine.  This gets you twice - heavier empty
 weight and more forward CG.  My XL is equipped with a Jabiru 3300A
 engine which should weigh about 100 pounds less than the O-200 installed.
 The good news is it is a lot easier to land an airplane with either 8:1
 or 6:1 than the 14:1 or so I got from my Tecnam Echo Super.  That plane
 was difficult to get to come down at all.
 You might do a little bit better if you go slower - perhaps 50 or 55 knots.
 Paul
 Camas, WA
 XL - 17 hours into phase I flight test.
 On 10/1/2011 1:19 PM, hallert wrote:
  Ted
  http://forums.matronics.com/viewtopic.php?p=353714#353714
		hallert
				 Posted: Sun Oct 02, 2011 6:41 am    Post subject: Re: 601xl engine out glide ratio |
				Paul,
 You're right about the engine weight. The other strange behavior I have noticed is that slips have practically no effect on the descent rate unlike
 any other aircraft I have flown. Have you noticed this?
 Ted
				 Posted: Sun Oct 02, 2011 7:05 am    Post subject: 601xl engine out glide ratio |
				Hi Ted,
 I haven't tried slips yet.  The plane drops so nicely with full flaps I
 never thought of slips.
 I have tried to stall my plane and never really got a break.
 I've been spending most of my time working on engine cooling issues and
 flight control problems.  I'm about the start spending some real time
 just flying the plane and trying to get good at landing it.
 The biggest flight control problems have been insufficient trim to trim
 out full flap configuration and a need to hold left rudder to get it to
 fly straight.  I fixed the trim by adding a fixed tab to the motorized
 one.  The rudder "Trim" problem has been fixed by adjusting the rudder
 cables.
 My last change (I hope) is to add a small fin on the bottom rear of the
 fuselage.  I have been unhappy with the yaw stability and hope to
 improve it a little bit.  Especially in turbulence, the nose seems to
 wander from side to side instead of finding a good position and staying
 there.  I can't imagine why Chris built his planes without a vertical
 stabilizer, but this seems like the price for that choice.  I don't know
 of any other planes with this rudder configuration.
 Paul
 On 10/2/2011 7:41 AM, hallert wrote:
  Paul,
  Ted
  http://forums.matronics.com/viewtopic.php?p=353780#353780
				 Posted: Sun Oct 02, 2011 3:10 pm    Post subject: 601xl engine out glide ratio |
				Hi Ted,
 I just took a long look at the Zodiac XL fuselage.  I wanted to consider
 my new fin (which doesn't work) to get some yaw stability.  I also
 considered your comments about slips having little impact.
 The Zodiac XL has a very funny shape.  Because of the flat sides and the
 angle they make to the tail and the way the front of the cabin is shaped
 there seems to be no yaw stability at all built into the fuselage.  When
 you slip there is no significant change in the cross section of the
 fuselage that hits the air flow.  This changes once you get the tail out
 further than the widest point at the cabin center (shoulder area for
 passengers), but that would be a very deep slip indeed.
 I wanted to add some yaw stability, but my first attempt to add a fin on
 the bottom of the fuselage didn't work.  In order to get a significant
 "Height" the fin will hit the ground when the nose is raised.  This
 would be particularly noticeable when doing a full stall landing.
 I took a look around the airport at other planes, and most of them
 (particularly TC'd ones) have an extra fin that goes from the front or
 middle of the fuselage length up to the front of the fixed fin in the
 tail.  I suspect adding such a fin to the XL might give it some
 stability but this looks like it would be a big job.  The top of the
 rear fuselage has very little strength, and this would probably need to
 be beefed up to support air loads to the side of the fuselage.  And, of
 course, the XL design as drawn has no vertical stabilizer at all.
 If you compare the Piper Sport to the Zodiac XL you will see the biggest
 change is in the addition of a vertical stabilizer.  This plane was
 designed by CZAW and appears to use many parts from the Zodiac XL they
 used to sell into the European market.
 I hope somebody else has looked at this with a smarter eye than mine and
 come up with something that works.
 Paul
 Camas, WA
  Paul,
  Ted
		mhubel
				 Posted: Sun Oct 02, 2011 5:32 pm    Post subject: 601xl engine out glide ratio |
				Ted,
      My CH601LX may be a bit different. It is a Jabiru 3300 powered and
 has no wheel covers at this time but otherwise it should  be somewhat
 similar.
      I show a best glide of 65 mph IAS with a sink rate of about 700
 feet per min for about a 8:1 ratio. This is at gross, while I have not
 measured it carefully, I think it is about 500-600 feet per min sink
 rate with no passenger and part fuel.  I have not tried it with the prop
 stopped, that would probably increase the ratio a bit.
      I find that at gross and a 75 mph IAS, I can see a sink rate of
 1000 feet per min with full flaps and almost 1500 in a slip plus flaps.
 I do find that slips should not be done below 70 mph IAS or one can have
 poor aileron control.
      I also did run out of trim at full flaps and have put in a spring
 on the elevator to neutralize its weight. This made the trim range just
 make it to full flaps.
      I believe you said that you had observed a tendency to roll to one
 side when near stall. I originally had that problem. It turned out that
 trailing edge of the right wing was a few mm too low. There had been a
 measurement error that propogated through construction. This may have
 nothing to do with your observations but it might be worth checking.
      While I agree that this is not as stable as a high wing plane, I
 have not found it to be unusually unstable. I don't find it to be too
 much different from a PA24 (Piper Comanche) I once had. The PA24 was
 very unforgiving if you let it drift on its own.
 Mark Hubelbank
 Ch601XL-B
 Jabiru 3300
 Sensenich adj prop
 Rotec TBI-40-3
 145 Hours airframe
  _________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
		hallert
				 Posted: Mon Oct 03, 2011 6:36 pm    Post subject: Re: 601xl engine out glide ratio |
				Paul and Mark,
 Thanks for your inputs. I too have insufficient up trim when flying by
  myself but with a passenger and less fuel it has just enough. I also had to
 "trim" the rudder by adjusting the cables to center the ball in cruise. Have
  not noticed the yaw instability you mention Paul. Seems much better than
 an Allegro which I flew 6 years ago that seemed totally unstable in yaw.
 Ted
				 Posted: Mon Oct 03, 2011 7:57 pm    Post subject: 601xl engine out glide ratio |
				Hi Ted,
 Rather than unstable, I would call the yaw behavior of the XL astable.
 It will stay where you put it, but it won't find the best position in
 yaw, i.e. it won't straighten itself out.  If you kick the ruder the yaw
 position will change and stay in the new position.  If it were unstable
 it wouldn't stay in any position but would constantly wander around.
 I think this also explains your comment about slips not doing any good
 to adjust landing approaches.  Moving the tail from about 2 feet left of
 center to the same amount right of center doesn't really change the
 cross-section presented to the relative wind.  There just isn't anything
 significant on the plane that is lined up with the vertical axis while
 moving forward.  It is only when the tail displacement exceeds the
 widest part of the fuselage (the shoulder area for passenger and pilot)
 that the cross section changes.
 I have been really miserable over this "Feature" since I discovered it a
 week or two ago.   At first I wanted to add some sort of vertical fin to
 fix the problem but after an attempt to do this I decided I just don't
 have the engineering skill needed for a change this big.  Today I added
 a bump on the top/front of the engine cowl in the correct position to
 help line up the nose with the runway on landing.  I haven't yet tried
 out the new feature.  The rains have started here in the Pacific NW rain
 forest and I have no clue when there will be sufficient flying weather
 for the test.
 Paul
 XL in flight test.
 On 10/3/2011 7:36 PM, hallert wrote:
  Paul and Mark,
  Ted
  http://forums.matronics.com/viewtopic.php?p=353970#353970
		PatrickW
  Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
				 Posted: Tue Oct 04, 2011 7:44 am    Post subject: Re: 601xl engine out glide ratio |
				Would this improve crosswind landing behavior?
 - Pat
				 Posted: Tue Oct 04, 2011 8:37 am    Post subject: 601xl engine out glide ratio |
				Hi Pat,
 I don't think so.
 The B-52 had cross-wind landing gear that allowed the plane to land with
 a crab while the wheels went straight down the runway.  That seems like
 a different think from the XL.
 The XL will fly somewhat sideways with the wings level, but the wheels
 always point in the same direction as the nose of the plane.  This seems
 to me to make it more difficult to get the wheels going down the runway
 while landing.  You still need to tip the wings into the wind to get it
 flying straight down the runway in a crosswind.   A crab will only help
 you, in this case, if you have engine power to pull the plane to the side.
 I could easily be wrong about this question.  I still have a lot of
 testing to do to be sure of anything.
 Paul
 XL in phase I flight test.
		hallert
				 Posted: Tue Oct 04, 2011 4:13 pm    Post subject: Re: 601xl engine out glide ratio |
				Paul,
 Does your nosegear have a detent (notch  that a pin on the strut drops into when weight is released)? This for me basically locks the rudder when in flight. I only need to push right rudder on climb out.
 Ted
				 Posted: Tue Oct 04, 2011 4:30 pm    Post subject: 601xl engine out glide ratio |
				Hi Ted,
 Yes I do.  However, it doesn't seem to center properly.  I need to kick
 the rudder pedal to get the plane to fly straight forward.  If you look
 at the geometry of the rudder and the fuselage side in front of the
 rudder you may see that there is a bit of play in the rudder position
 before it actually moves the tail one way or another.
 Paul
 On 10/4/2011 5:13 PM, hallert wrote:
  Paul,
  Ted
  http://forums.matronics.com/viewtopic.php?p=354065#354065
