Heavy In-flight Vibration Riddle
Goto page 1, 2, 3  Next
raimo.toivio(at)rwm.fi
PostPosted: Sat Oct 01, 2011 11:47 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
All
I have hope-so a nice riddle for you.
Maybe all the answers are useful – let´s collect them all:
Yesterday I took off from a very remote /small /windy (90 degrees 12 knots and gusting MUCH) grass strip. Soon until well over the ground at altitude +500 feet with full power and 2nd fuel pump still on and gears up I felt suddenly let us say medium or more shake and vibration. My immediate reaction was to go around and land immediately but abandoned because wind was so furious and I felt I cannot do that (a succesful landing).
I decided to try to fly to the next possible sensible airfield EFHV which was 10 minutes apart.
Those minutes were long: I put my prob (Airmaster CS) to manual and drived it from fine to coarse, tried all the power settings and also a 2nd fuel filter. Finally I noticed that when prop was in a climb mode (in my case 5400 rpm /Rotax 912S) and MAP around 20 inches I got quite a comfortable flying mode and I headed straight home. My airspeed was w that selection about 110 knots but because of a strong headwind GS was only about 70 knots (wanted to be clearly over the ground at 3000 ft because it was well over sunset and totally dark, yesterday we got sunset around 1600 Zulutime and time was well over 1630 when flying).
So, I pushed home one looooong hour. All the aerodynamics were well. I was a bit worried my engine will separate or so. When trying to push more pwr it was more vibra and when trying to pull less pwr same. I Followed a main highway and decided to land there if feeling so. Cars there with lights are almost like a lighted runway...
Finally landing to the EFTP flawlesly.
Today we had a FHGP (Family Hangar Grill Party). I tried to check my plane as well as I can. I found something. Very small evidence but something anyway. I tried to fix it and had a test run. I elected to go to fly – hey I am a test pilot who else – and She was better than ever!
I managed to do 2 touches and goes when C172 did one with same runway.
140 knots during downwind makes me always happy.
So – dear Ladies and Gentlemen – what was wrong?
It would be nice and very life-useful to hear your opinions or guesses what was wrong.
The Rules: one single guess per person, please.
The Prize: The Best Guess will get a Very Special Xmas Present from Finland!
I will let you know a solution after a week – be patient.
Have a nice weekend and
Cheers, Raimo Toivio
[img]cid:CB52180F6D77475ABFF27BD7CAC0E655(at)Asus[/img]
Europa XS Mono OH-XRT #417
Updated flight hours /landings: 258,3
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
toivio(at)fly.to (toivio(at)fly.to)
www.rwm.fi
 Filesize:  58.84 KB
 Viewed:  18150 Time(s)
 Filesize:  239.8 KB
 Filesize:  109.09 KB
 Filesize:  181.65 KB
 Filesize:  148.6 KB
houlihan(at)blueyonder.co
PostPosted: Sat Oct 01, 2011 12:47 pm    Post subject: Heavy In-flight Vibration Riddle Reply with quote
My wild guess
Part or all of your propeller leading edge protection had come away on one blade.
On 1 October 2011 20:44, Raimo Toivio <raimo.toivio(at)rwm.fi (raimo.toivio(at)rwm.fi)> wrote:
All
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
www.rwm.fi
 Filesize:  58.84 KB
 Viewed:  18146 Time(s)
rambug
PostPosted: Sat Oct 01, 2011 12:54 pm    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Hi Raimo,
Glad to see all turned for the best.
As for the cause of your vibrations, I'm taking a guess for a leaf that wrapped itself onto the leading edge of one of your prop's blades.
I'd say it feels a bit high for it to be at 500' AGL but with a lot of wind, in autumn I guess it would be plausible.
Luc
On Sat, Oct 1, 2011 at 21:44, Raimo Toivio <raimo.toivio(at)rwm.fi (raimo.toivio(at)rwm.fi)> wrote:
All
37500 Lempaala
FINLAND
p [url=tel:%2B358-3-3753%20777]+358-3-3753 777[/url]
f [url=tel:%2B358-3-3753%20100]+358-3-3753 100[/url]
www.rwm.fi
 Filesize:  58.84 KB
Luc Michaud
Europa Monowheel A059
Canadian Registration C-GLOB (in progress)
Montreal, Québec, Canada
zwakie
PostPosted: Sat Oct 01, 2011 2:07 pm    Post subject: Re: Heavy In-flight Vibration Riddle Reply with quote
Wild guess: lost a prop balancing weight?
Marcel Zwakenberg
Europa XS TG || 912ULS || PH-SBR
klinefelter.kevin(at)gmai
PostPosted: Sat Oct 01, 2011 3:41 pm    Post subject: Heavy In-flight Vibration Riddle Reply with quote
I would guess something wrong with one carburator.
Kevin
On 10/1/11, Luc Michaud <rambug(at)gmail.com> wrote:
Hi Raimo,
Luc
On Sat, Oct 1, 2011 at 21:44, Raimo Toivio <raimo.toivio(at)rwm.fi> wrote:
> All
> Yesterday I took off from *a very* remote /small /windy (90 degrees 12
> I
> knots
> it
> are
> I
> what
> was wrong.
> Finland!
> [image: Europa A2A-ala2OK]
> 37500 Lempaala
> FINLAND
> p +358-3-3753 777
> f +358-3-3753 100
> toivio(at)fly.to
> www.rwm.fi****
ward.t(at)xtra.co.nz
PostPosted: Sat Oct 01, 2011 5:35 pm    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Raimo,
My guess it was some propeller imbalance caused by either a stone strike and a little dent in the propeller or sometime small left on one of the propellers, insect or bug 'finished off' on a propeller.
If I am only allowed one guess it would be an insect come bug of some type from Finland.
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
On 2/10/2011, at 12:38 PM, Kevin Klinefelter <klinefelter.kevin(at)gmail.com> wrote:
Kevin
> Hi Raimo,
> Cheers,
> Luc
>> All
>> I
>> knots
>> it
>> are
>> I
>> what
>> was wrong.
>> Finland!
>> 37500 Lempaala
>> FINLAND
>> p +358-3-3753 777
>> f +358-3-3753 100
>> toivio(at)fly.to
>> www.rwm.fi****
jimpuglise(at)comcast.net
PostPosted: Sat Oct 01, 2011 6:37 pm    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Troy, my guess is that you had a mid-air with a Finnish mosquitoe.  That would be plenty to unbalance your prop.
Jim Puglise
A283
Sent: Saturday, October 1, 2011 9:22:58 PM
Subject: Re: Heavy In-flight Vibration Riddle
--> Europa-List message posted by: Tim Ward <ward.t(at)xtra.co.nz>
Raimo,
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
--> Europa-List message posted by: Kevin Klinefelter <klinefelter.kevin(at)gmail.com>
Kevin
> Hi Raimo,
> Cheers,
> Luc
>>  All
>> I
>> knots
>> it
>> are
>> I
>> what
>> was wrong.
>> Finland!
>> 37500 Lempaala
>> FINLAND
>> p +358-3-3753 777
>> f +358-3-3753 100
>> toivio(at)fly.to
>> www.rwm.fi****
PostPosted: Sat Oct 01, 2011 11:04 pm    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Raimo,
Could have been a missing or loose propeller spinner hub bolt?
Angus Ward,
Tim’s son
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
email; ward.t(at)xtra.co.nz
Sent: Sunday, October 02, 2011 8:44 AM
Subject: Heavy In-flight Vibration Riddle
All
[img]cid:9CA73177CC4F48149E2846DEF2B4FE9F(at)OwnerPC[/img]
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
www.rwm.fi
 Filesize:  58.84 KB
 Viewed:  18118 Time(s)
stephan(at)scassel.se
PostPosted: Sun Oct 02, 2011 1:25 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Hi Raimo,
Very happy that everything vent ok.
Your story sounds very familiar:
Two years ago I had a serious prop failure with my WoodComp SR2000.
One blade stopped due traverse drive failure. This blade had 6-8 degrees (or even more) different pitch compared
with the other two. Must say that I was extremely happy that it was not during an English Channel crossing.
I found out that the travers drive that had collapsed, had no grease on. Totally dry! It was the travers drive behind the control unit (stop-switch).
When I disassembled the prop, the grease on each prop-blade connection to the hub has become very hard.
I talked to Jiri, at WoodComp, and they told me that I should use another grease as they also have found out that the original grease
was not good (in fact very bad)
Every WoodComp SR2000 users should:
1. Disassemble the prop every 200 hours or less and grease all connections. Use Aero Shell 7 (according to WoodComp)
2. Every annual grease the travers drive. Use Molicote (according to WoodComp).
3. Every annual grease the gear box . Use plenty of Vaseline (according to WoodComp)
Now and then clock the time between fine and coarse. It should not take more then 15 seconds. WoodComp say that you can accept
30 seconds but I think that is too much. My prop has now 12 seconds and I will suspect the servo motor or need for new grease when it
takes more then 15-17 seconds.
This is very important !! If the hub connections is not greased well enough, the travers drive will be overloaded and will sooner or later collapse.
WoodComp has excellent HTML based document how the maintain the prop.
Best regards,
Stephan
LN STE Kit 556
grahamsingleton(at)btinte
PostPosted: Sun Oct 02, 2011 1:27 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
PostPosted: Sun Oct 02, 2011 8:02 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
All
I have got plenty of good guesses via list and also direct.
Some of you have hoped I will not publish them with their names and do not worry I wont´t.
Graham – I /we got an empty message from you – please retype it – I am sure it will be a good info.
One of you have guessed the problem was because a broken de-icing rubber in the prop blade. That´s good but unfortunately my Europa is so far still missing de-icing systems totally. They would be soon very useful in Finland.
No one has so far found a reason for my vibra.
So there are still a possibility to get an Xmas packet from Finland.
I quarantee the shipment will be worth of making a good guess.
Tips:
- the reason was off /on or black /white –type and very easy to repair; it was fixed in seconds.
- when finally found it was not invisible at all.
Go On!
Cheers, Raimo OH-XRT
Sent: Saturday, October 01, 2011 10:44 PM
All
[img]cid:E62DD82B7A9B4CC3A62102CC0167144D(at)Asus[/img]
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
www.rwm.fi
 Filesize:  58.84 KB
 Viewed:  18098 Time(s)
gregoryf.flyboy(at)comcas
PostPosted: Sun Oct 02, 2011 9:28 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Here is a guess.
The rubber equalizing tube connecting the carbs had vibrated off..
Greg
PostPosted: Sun Oct 02, 2011 9:30 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
fklein(at)orcasonline.com
PostPosted: Sun Oct 02, 2011 9:46 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Raimo...I'm asking for a clue...by any chance, did you have a cat onboard during this event?...Fred
On Oct 2, 2011, at 8:58 AM, Raimo Toivio wrote:
[quote] All
stranfaer(at)btinternet.c
PostPosted: Sun Oct 02, 2011 9:53 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Raimo
My guess was the fuel filler cap left off?
Yes I have done this!
Rgds
David the other one
Sent from the iPad of David Joycewww.eastmidsspas.com
On 2 Oct 2011, at 18:43, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
[quote]Raimo...I'm asking for a clue...by any chance, did you have a cat onboard during this event?...Fred
All
yck.laurens(at)gmail.com
PostPosted: Sun Oct 02, 2011 10:07 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
perhaps one of the carb vent small tube disconnected ?
regards
yannick LAURENS
F PSCZ
PostPosted: Sun Oct 02, 2011 10:41 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Raimo,
Two thoughts.
Fuel starvation with the fuel pumps not turned on for take off?
Hannah
Tim daughter
Tim Ward12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
Ph 64 3 3515166
Mob 0210640221
On 3/10/2011, at 4:58 AM, "Raimo Toivio" <raimo.toivio(at)rwm.fi (raimo.toivio(at)rwm.fi)> wrote:
[quote] All
Tips:
Go On!
To: [url=mailto:europa-list(at)matronics.com]europa-list(at)matronics.com (europa-list(at)matronics.com)[/url]
All
<Europa%20A2A-ala2OK[1].png>
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
www.rwm.fi
PostPosted: Sun Oct 02, 2011 10:42 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Raimo,
The other is carb heat left on for take off?
Toby,
Tim's other son
Fendalton,
Christchurch,  8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
[quote] All
Tips:
Go On!
All
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
www.rwm.fi
PostPosted: Sun Oct 02, 2011 11:54 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
choke spring
Kevin
On 10/2/11, Tim Ward <ward.t(at)xtra.co.nz> wrote:
Raimo,
Toby,
Tim's other son
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
On 3/10/2011, at 4:58 AM, "Raimo Toivio" <raimo.toivio(at)rwm.fi> wrote:
> All
> worry I wont´t.
> Finland.
> Tips:
> Go On!
> From: Raimo Toivio
> All
> what was wrong.
> Finland!
> 37500 Lempaala
> FINLAND
> p +358-3-3753 777
> f +358-3-3753 100
> toivio(at)fly.to
> www.rwm.fi
europapa
PostPosted: Sun Oct 02, 2011 1:41 pm    Post subject: Re: Heavy In-flight Vibration Riddle Reply with quote
Don t want to thing about x-mes jet but nice game.
A spark plug connector went of?
Happy flying
Juergen
Page 1 of 3
