rockford67
Posted: Fri Sep 30, 2011 6:04 pm Post subject: Cabin Heat |
Hey Pulsar owners,
Got home excited to get moving on bringing my Pulsar to a flying state. Hard is it was, this meant removing the engine to change out the firewall for stainless amongst other things. I got the engine out yesterday and found much to my dismay, that cabin heat was being pulled directly from the airflow passing from inside the cowl through the rads! In other words, if there was an exhaust leak co2 would be blown directly into the cockpit. Not good.
Since I'm in this deep, I may as well fix everything I can. So I'm looking for ideas how any one else has done this.
Chris
PS. I guess we can't upload photos here... I'll post the identical message on Yahoo and see if I can get some photos up too.
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pulsar-List |
sonja.englert(at)juno.com Guest
Posted: Sat Oct 01, 2011 6:39 am Post subject: Cabin Heat |
That is the standard arrangement for Pulsars. It has worked very well for me. Inspect your exhaust for cracks before every flight, bring a CO detector and close the cabin heat if there is CO.
Sonja
____________________________________________________________
57-Year-Old Mom Looks 25
Mom Reveals Free Wrinkle Trick That Has Angered Doctors!
http://thirdpartyoffers.juno.com/TGL3131/4e8725e66801194ce04st06duc
barryjedwards(at)lineone. Guest
Posted: Sat Oct 01, 2011 11:41 am Post subject: Cabin Heat |
My cabin heat comes from a small (6" square) aluminium heat exchanger (radiator) in the cockpit with a small fan attached to it (computer type fan). The heat exchanger is fed directly from the main engine coolant flow with a 5/8" take off point just before the main rad. and a return just after it. When i want heat I just turn the fan on. It doesn't make the cockpit hot but it is sufficient in a UK winter to make flying a pleasure not a pain! I tried taking hot air from the exhaust can but really didn't like the idea that much and it let a lot of noise into the cockpit too.
Barry
G-XPXP 912 tail-dragger 19 years old and 999.45hrs
Sent: Saturday, October 01, 2011 3:04 AM
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Subject: Cabin Heat
--> Pulsar-List message posted by: "rockford67" <cphorsten(at)yahoo.ca (cphorsten(at)yahoo.ca)>
Hey Pulsar owners,
Chris
http://forums.matronics.com/viewtopic.php?p=353682#353682
http://www.matronnbsp; the Web href="http://forums.matronics.com">http://forums.matronics.com
_p; generous bsp; href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
408.12 KB |
4967 Time(s) |
