stratobee
Posted: Tue Sep 20, 2011 5:11 pm Post subject: GO-435 troubles... |
Hi.
My left engine did not develop full power on my way out of Chicago to get to the fly-in and I had to abort, which was really sad after have come all the way from California to join you for the first time. I was devastated. Anyway, two cylinders were down and after I finally found a guy to pull them on the field he saw stuff he didn't like and he wouldn't sign off on just repairing the cylinders. The oil ring had disintegrated and they found metal in the engine. Now, he might be "overreacting", having never worked on Commanders or old engines before, or he might have a point. Nevertheless, regardless of which I'm in a bad pickle - aircraft stuck 1800 miles away from home on an executive field with mostly big jets and the parking pricing of Signature and Atlantic...
I have JimBob and Morris with the ear to the ground and trying to find a solution for me and I'm very grateful for that. But I thought I'd consult the board as well - does anyone know of any GO-435's in decent shape, or known to fly, with papers, or no papers, that could eventually be for sale anywhere reasonably? I need to resolve my situation and get her back home. I fear this could take months and months again if I don't act swiftly and the parking at $30/day will ruin me...
I'm very disheartened at the moment.
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
_________________ Adam |
cschuerm(at)cox.net Guest
Posted: Wed Sep 21, 2011 4:25 am Post subject: GO-435 troubles... |
What happened to 4186B after the gas truck hit it? Should be two good
engines available there.
kitepilot(at)kitepilot.co Guest
Posted: Wed Sep 21, 2011 8:10 am Post subject: GO-435 troubles... |
Probably not what you want to hear but...
Years ago (in my first real flight as a newly minted aircraft owner), I
landed with an engine emergency in Broomfield CO.
It was obvious that the airplane was going to be stranded for weeks.
I explained the situation to the people at Signature and they immediately
gave me a "monthly" that was more of a gift than a rate.
Talk to them, it may be cheaper than buying an engine.
Yet...
ET
PS: Full story at http://kitepilot.com/viking/horror_story.htm
From Alaska: (download the video and play with VLC)
http://www.kitepilot.com/AK/champ-roll-needs-vlc.MPEG
http://www.kitepilot.com/AK/champ-spin-needs-vlc.MPEG
http://www.kitepilot.com/AK/click-here-to-download-Vlc-Media-Player.html
stratobee writes:
Hi.
Adam
http://forums.matronics.com/viewtopic.php?p=352812#352812
stratobee
Posted: Fri Sep 23, 2011 8:22 am Post subject: Re: GO-435 troubles... |
Looks like they'll be able to patch the left engine together after sending pictures to Lycoming of the cam, which is good news. They didn't like the look of it at the shop, but it's been cleared. Engine is getting close to TBO, so it's normal wear.
Hunt still continues - need to replace those 435's sooner rather than later..
andrew.bridget(at)telus.n Guest
Posted: Fri Sep 23, 2011 10:54 am Post subject: GO-435 troubles... |
That *is* good news, Adam. Only this morning I was thinking of you;
concerned about your troubles. Glad things are going the right way for you.
Good stuff!
Andrew
stratobee
Posted: Thu Oct 13, 2011 3:05 pm Post subject: Re: GO-435 troubles... |
In Chicago to pick her up. Did a high speed taxi and run today and all was fine. Just in case, I will be routing south through New Mexico to avoid the grunt of the Rockies for my flight back to California.
tylorhall(at)mac.com Guest
Posted: Thu Oct 13, 2011 3:41 pm Post subject: GO-435 troubles... |
Adam,Let me know when you will be arriving in New Mexico and will come out to the airport.
Tylor Hall
tylorhall(at)mac.com (tylorhall(at)mac.com)
First Fueling Systems, Inc.
100 Iron St. SE
Albuquerque, NM 87102
505-400-8373 Cell
505-247-3001
505-247-3005 FAX
www.firstfueling.com
On Oct 13, 2011, at 5:05 PM, stratobee wrote:
| Quote: | --> Commander-List message posted by: "stratobee" <adam(at)adamfrisch.com (adam(at)adamfrisch.com)>
Adam
http://forums.matronics.com/viewtopic.php?p=354956#354956
- The --> &n========================<b - &nbs --> ========================
stratobee
Posted: Thu Oct 13, 2011 4:33 pm Post subject: Re: GO-435 troubles... |
I will, Taylor! Probably be Sat.
moe-rosspistons(at)hotmai Guest
Posted: Thu Oct 13, 2011 6:50 pm Post subject: GO-435 troubles... |
Adam,
If you have any problems while in Northern New Mexico call me at (310) 350-4594. I am in Farmington (FMN or N19) and have a truck and trailer with lots of tools and parts.
Best of luck.
Moe Mills
N680RR
> Subject: Re: GO-435 troubles...
jtaddington(at)verizon.ne Guest
Posted: Fri Oct 14, 2011 5:56 pm Post subject: GO-435 troubles... |
Mo, I think I may get John Towner’s battery system approved on a field approval for my “A” model. If it goes through I will let you know how we did it.
Jim A N444BD
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Moe Mills
Sent: Thursday, October 13, 2011 9:48 PM
To: Com
Subject: RE: Re: GO-435 troubles...
Adam,
Best of luck.
Moe Mills
N680RR
> Date: Thu, 13 Oct 2011 17:33:51 -0700
> To: commander-list(at)matronics.com
> --> Commander-List message posted by: "stratobee" <adam(at)adamfrisch.com>
> Adam
> http://forums.matronics.com/viewtopic.php?p=354961#354961
| Quote: | | http://www.matronics.com/Navigator?Commander-List | 01234567890123
stratobee
Posted: Fri Oct 14, 2011 7:41 pm Post subject: Re: GO-435 troubles... |
Thanks Moe!
So far my only troubles have been with money! Credit card and debit cards not accepted at various pit stops as they "exceed daily limit". Funny that - it's my own money on the debit card, but I can't access it! Banks. Eventually had to get into town to get some cash to pay re-fueler. All extremely annoying and time consuming. Tomorrow is a new day and with new daily limits. Let's hope I can get enough fuel to get back.
Moral of story? One can never have too many credit cards. When one goes down, move on to the next.
Posted: Fri Oct 14, 2011 8:16 pm Post subject: GO-435 troubles... |
Adam,How far did you get today?
I was on a trip this week and I called my card company and told them I would be traveling. It seemed to help.
Tylor Hall
100 Iron St. SE
505-400-8373 Cell
505-247-3001
505-247-3005 FAX
Thanks Moe!
Adam
http://forums.matronics.com/viewtopic.php?p=355074#355074
v-man(at)v-man.net Guest
Posted: Fri Oct 14, 2011 9:47 pm Post subject: GO-435 troubles... |
It's possible to get a $5000 daily limit on a debit card at Wells Fargo... I had to do it while traveling too.
Sent from my Samsung smartphone on AT&T
stratobee <adam(at)adamfrisch.com> wrote:
Thanks Moe!
Adam
tfisher(at)commandergroup Guest
Posted: Sat Oct 15, 2011 5:02 am Post subject: GO-435 troubles... |
Every time I went away and pumped more then $3,000.00 of fuel into the hay
burner they would stop the card entirely, I would have to call them after
the rejection of the transaction..."For your own safety" they said.
Tom
Formally C-GISS 680FLP (Mr.RPM)
amg3636(at)hotmail.com Guest
Posted: Sat Oct 15, 2011 5:58 am Post subject: GO-435 troubles... |
My American Express has never failed me yet. Last week I put a $3,100.00 Credit purchase with no problem. However, my next purchase was much smaller and I had to call and tell them I was traveling. No problems after that. I thanked them for looking out for me.
Roland Gilliam AC 500 6291B
[quote] From: tfisher(at)commandergroup.bc.ca
Subject: Re: Re: GO-435 troubles...
Date: Sat, 15 Oct 2011 05:59:56 -0700
--> Commander-List message posted by: "Tom Fisher" <tfisher(at)commandergroup.bc.ca>
Tom
Posted: Sat Oct 15, 2011 7:38 am Post subject: GO-435 troubles... |
My wife reminds me the wells fargo is indeed $25,000 for the debit… I’m digitally challenged ( enough to fly even a commander for an hour or two )
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Roland Gilliam
Sent: Saturday, October 15, 2011 8:56 AM
To: commander list
Tom
johntowner(at)centralairs Guest
Posted: Sat Oct 15, 2011 11:50 am Post subject: GO-435 troubles... |
Hello Adam "aka stratobee"
My e-mail to the chat page does not always work but I hope this gets through to you. I am an old Commander guy that loves Commanders and I have read many of your postings. I have much compassion and respect for what you have been through and I wish I could help but I have followed many of the postings and in my opinion you have received some excellent advice from the TCFG gear engine guys. As for your credit card deli- ma I can certainly relate. Just my 2 cents worth, get a AX card and if you communicate with AX they will work with you (we currently pay for all of our fuel nightly with our AX card and they have been very good to work with). Take care and if there is anything I can help you with you e-mail me direct for sometimes my e-mails do not go through (old age setting in). Oh! and if you want any Bob Hoover videos I can send you some, from 1996-2000 I got to ferry Hoov's aircraft between air show and of course that was much fun) Take care, fly safe and all the best.
RESPECTFULLY,
John Towner
Central Air
MKC Kansas City
On 10/14/2011 10:41 PM, stratobee wrote: [quote] | Quote: | --> Commander-List message posted by: "stratobee" <adam(at)adamfrisch.com> (adam(at)adamfrisch.com)
Thanks Moe!
Adam
| [b]
Posted: Sat Oct 15, 2011 3:54 pm Post subject: GO-435 troubles... |
Jim,
I would really appreciate that.
Moe
Date: Fri, 14 Oct 2011 20:54:36 -0500
.ExternalClass .ecxshape {;} .ExternalClass p.ecxMsoNormal, .ExternalClass li.ecxMsoNormal, .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:"Times New Roman";} .ExternalClass p.ecxMsoEnvelopeReturn, .ExternalClass li.ecxMsoEnvelopeReturn, .ExternalClass div.ecxMsoEnvelopeReturn {margin-bottom:.0001pt;font-size:12.0pt;font-family:Arial;font-weight:bold;} .ExternalClass a:link, .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass span.ecxMsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass p {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:"Times New Roman";} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:"Courier New";} .ExternalClass span.ecxEmailStyle20 {font-family:Arial;color:blue;font-weight:normal;font-style:normal;text-decoration:none none;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.ecxSection1 {page:Section1;}
Jim A N444BD
To: Com
Adam,
Best of luck.
Moe Mills
N680RR
Posted: Sat Oct 15, 2011 4:10 pm Post subject: GO-435 troubles... |
Adam,
Sorry to hear about the credit card delima.
Some time ago I landed and taxied up to the fuel island. It was after hours and the weather wasn't too good. What appeared to be a father and son team walked over and said theat the pumps were inop, and that the older of the two had trid both of his cards with no sucess. I stuck one of my cards in the slot and proceeded to pump 150+ gallons in my Commander. I then told them that if they would give me some cash that I would use my card and pump some fuel into their bird. The father then proceeded to tell me that "we never carry any cash" in a somewhat smug manner. The only thing that I could think of to say was "sorry I can't help you". Sometimes cash is still king. Some of the smaller mom and pop operations still give a minor discount for cash or will give you the fleet rate. My standard line is "lookey here, things are a little tight now, what is the cheapest way I can get some fuel and get out of here".
Moe
N680RR
| Quote: | From: adam(at)adamfrisch.com
Date: Fri, 14 Oct 2011 20:41:20 -0700
Thanks Moe!
Adam
-= --> http://www.matronics.com/Navigator?Commander-List
_=====================
_=====
Posted: Sat Oct 15, 2011 5:15 pm Post subject: GO-435 troubles... |
UP date on travels of Adam,He stopped at KAEG here in New Mexico just before Lunch today.
We had lunch. And he proceeded on westward. In search of lower priced AVGAS.
He has an Ipad with the chart bag software that shows the fuel prices all along the way.
Tylor Hall
| Quote: | Adam,
Moe
N680RR
href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List
622.86 KB |
12640 Time(s) |
