Aluminium Fuel Tube
ward.t(at)xtra.co.nz
PostPosted: Wed Sep 21, 2011 2:01 am    Post subject: Aluminium Fuel Tube Reply with quote
Tony,
See attachment in fixing the aluminium pipe supplied by me.
It is purposely too long to allow for different fittings.
Position the “cobra” first with your splash moulding.
Don’t forget to reinforce the skin behind the cobra moulding with 3 layers of Bid to prevent deforming skin in hot temperatures (Aussie)
Cut it, the pipe, gradually back , a little at a time until you have the correct fit.
The rubber piping at each end allows for mistakes.
Once it is joined up then do the lay ups to the wall for the cobra.
Puts some blue foam at the back of the cobra to allow for the shape and expansion.
Cheers,
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
email; ward.t(at)xtra.co.nz
Owner_Ward.vcf
Download
 Filename:  Owner_Ward.vcf
 Filesize:  183 Bytes
 Downloaded:  299 Time(s)
Europa_-_ALUMINUM_FUEL_FILLER_PIPE.doc
Download
 Filename:  Europa_-_ALUMINUM_FUEL_FILLER_PIPE.doc
 Filesize:  24.5 KB
 Downloaded:  303 Time(s)
grahamsingleton(at)btinte
PostPosted: Wed Sep 21, 2011 2:54 am    Post subject: Aluminium Fuel Tube Reply with quote
Tony
Tim's aluminium elbow is highly recommended, it stops a lot of the fuel smell in the cockpit, but make sure all the molding flash is carefully cut off the Cobra so that the rubber tube jopints sit snuggly and seal to the Cobra, and the tank stub
Graham
To: tonyrenshaw268(at)optusnet.com.au; europa-list(at)matronics.com
Sent: Wednesday, 21 September, 2011 10:56:45
Subject: Aluminium Fuel Tube
Tony,
Cheers,
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
tonyrenshaw268(at)gmail.c
PostPosted: Fri Sep 23, 2011 7:21 am    Post subject: Aluminium Fuel Tube Reply with quote
Thanks to Tim and Graham for help regarding cutting down the Fuel Filler Tube cover and Tims Aluminium pipe.
Reg
Tony Renshaw
On Wednesday, September 21, 2011, GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
> Tony
> Graham
From: Tim Ward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)>
To: tonyrenshaw268(at)optusnet.com.au (tonyrenshaw268(at)optusnet.com.au); europa-list(at)matronics.com (europa-list(at)matronics.com)
Subject: Europa-List: Aluminium Fuel Tube
Tony,
> Position the cobra first with your splash moulding.
Dont forget to reinforce the skin behind the cobra moulding with 3 layers of Bid to prevent deforming skin in hot temperatures (Aussie)
Cheers,
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
email; ward.t(at)xtra.co.nzhttp://www.matronics.com/Navigator?Europa-List
; http://forums.matronics.com
-Matt Dralle, List Admin.
