klondike(at)megalink.net Guest
Posted: Wed Sep 21, 2011 5:41 pm Post subject: bungee cord tool-install only |
Paul-- not for removal. I simply put tape around the pin so there would not
be any "sharp" edges and pry'd it off with a large screwdriver.
Fritz
mtherr(at)yahoo.com Guest
Posted: Wed Sep 21, 2011 6:27 pm Post subject: bungee cord tool-install only |
| Quote: | I changed my nosewheel bungee once with a simple threaded rod as a tool. I had a Soob
Engine with the radiator mounte 4 inches from the firewall.
I inserted a threaded rod on top of gear leg. Then put a nut and screwed it down to the top plate (notice tat my top plate uses two bolts -- only one removed to accomodate the threaded rod). Then removed second bolt and disasembled the bottom bearing. Finally, unscrewed the rod using vise grip on it.
Reverse procedure to install the new bungee.
Michel
