biovail2001(at)yahoo.com Guest
Posted: Mon Sep 19, 2011 7:49 pm Post subject: Stiff slider on RV9 |
Your description of opening from the inside is typical and that is how I open mine. From the outside you may choose to install a tab made out of aluminum angle mouted to the side skirt and canopy frame on each side. This gives you leverage to lift and slide your canopy rearward.
Steve Koziol
N424JK
180+ hrs
Sent from my Verizon Wireless BlackBerry
| | - The Matronics RV9-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV9-List |
emduiven(at)chaffee.net Guest
Posted: Wed Sep 21, 2011 8:51 am Post subject: Stiff slider on RV9 |
Dick:
I put small grips on each side of the canopy, near the aft end, and use them to push up on the canopy when it is shut all the way. I also found a little dry lubricant on the nylon slide helps as well. Best to not shut canopy all the way - keep aircraft in a hanger.
Mike Duiven - N711ED
emduiven(at)chaffee,net
CollegiatePeaksTrailRun.org Webmaster
RotaryBuenaVistaCO.org Webmaster
PrairiePoet.org Webmaster
CountryClubofGreenValley.org Webmaster
(719) 221-1947
(719) 395-8349
jofrap1(at)juno.com Guest
Posted: Wed Sep 21, 2011 10:05 am Post subject: Stiff slider on RV9 |
Hi
What I did was run a small cable from the slide on the canopy rail to the canopy handle as you unlatch the canopy the handle pulls the cable and lifts the rear of the canopy always works without any fuss. If interested I can take some foto's next time I am at the airport.
Joe
payaremchuk(at)gmail.com Guest
Posted: Wed Sep 21, 2011 10:33 am Post subject: Stiff slider on RV9 |
Joe, that sounds fantastic! ...should be standard issue!
please post pics or put them on VAF if you can?
thx
Perry the stuck slider victim # 243
On Wed, Sep 21, 2011 at 11:02 AM, jofrap1(at)juno.com (jofrap1(at)juno.com) <jofrap1(at)juno.com (jofrap1(at)juno.com)> wrote:
[quote]Hi
Joe
Posted: Thu Sep 22, 2011 6:41 am Post subject: Stiff slider on RV9 |
Here are some foto's sort of discriptive.
280.53 KB |
12029 Time(s) |
234.22 KB |
12029 Time(s) |
243.13 KB |
12029 Time(s) |
268.39 KB |
12029 Time(s) |
397.43 KB |
12029 Time(s) |
280.53 KB |
12029 Time(s) |
retasker(at)optonline.net Guest
Posted: Thu Sep 22, 2011 7:57 am Post subject: Stiff slider on RV9 |
The pictures are very interesting. But did you forget one? There are two copies of "Picture 160" and no "Picture 162".
Dick Tasker
jofrap1(at)juno.com wrote:
[quote] Here are some foto's sort of discriptive.
Posted: Thu Sep 22, 2011 12:49 pm Post subject: Stiff slider on RV9 |
Hi
I hope the foto's are helpful. I took these this morning here in the rain.
160 twice was a mistake but these are the best angles for clarity, 162
163 and 164 are slightly different angles, 165 shows the canopy opening.
If there are any questions I'll be glad to answer as best I can.
Joe N884EF
Posted: Thu Sep 22, 2011 2:01 pm Post subject: Stiff slider on RV9 |
Can you please attach photo 162. It was not included in the original email.
Looks very interesting. How long did it take you to do this?
Thanks, Dick Tasker
[quote] Hi
Joe N884EF
Posted: Fri Sep 23, 2011 4:26 am Post subject: Stiff slider on RV9 |
Hi
Attached is 162.
301.11 KB |
12017 Time(s) |
Posted: Fri Sep 23, 2011 7:11 am Post subject: Stiff slider on RV9 |
This is very clever!
The way I see and interpret the pictures I now see how it works. The main question I have is: Does the cable ever get in the way when opening or closing the canopy? It looks like you have it
captured for a part of its length but the rest is free hanging. I realize that when it is closed it is pretty much taut, but how about when you are sliding the canopy back? Do you have a small
pulley in the part on the rear bulkhead area or is it just a bolt or other sliding surface?
Thanks, Dick Tasker
[quote] Hi
Attached is 162.
Posted: Fri Sep 23, 2011 9:49 am Post subject: Stiff slider on RV9 |
Hi
The system works very well, there is a small loop at the rear of the baggage compartment,
the size of the loop is determined by the lenght of the guide tube. I have never been bothered by it as it is well out of the way. When the canopy is closed the wire is pulled all the way but not tight. Not a very diffcult mechanism only a couple parts to make, there is a small pulley don't ask where I got it (junk pile). The most difficult thing to assemble is the pulley with its location and all the little washers and screws that must be assembled all at once, my fingers don't work all that well anymore.
Joe N399EF
