grosseair(at)comcast.net Guest
Posted: Mon Sep 19, 2011 5:42 pm Post subject: Using the shield as conductor |
My audio panel (PS 8000) does not have a pin for "Mic Key Lo" but my com
radio (Garmin 430W) requires one. The Garmin install manual says to use
a connection to the audio panel ground lug. "Mic Audio Hi and Mic Audio
Lo" are in a 2 conductor shielded cable. The Garmin shows a 3 conductor
cable with one wire connected to the ground lug on the audio panel .The
shield is grounded at the audio panel. Is there any reason I can't
connect a wire to the radio end of the shield and use it for the "Mic
Key Lo" input on the 430? It would save me from having to redo the cable
and I can't think of any reason it wouldn't work.
John Grosse
Posted: Mon Sep 19, 2011 6:59 pm Post subject: Using the shield as conductor |
com radio (Garmin 430W) requires one. The Garmin install manual says
to use a connection to the audio panel ground lug. "Mic Audio Hi and
Mic Audio Lo" are in a 2 conductor shielded cable. The Garmin shows a
3 conductor cable with one wire connected to the ground lug on the
audio panel .The shield is grounded at the audio panel. Is there any
reason I can't connect a wire to the radio end of the shield and use
it for the "Mic Key Lo" input on the 430? It would save me from
having to redo the cable and I can't think of any reason it wouldn't work.
Works good . . . lasts a long time . . .
tim2542(at)sbcglobal.net Guest
Posted: Mon Sep 19, 2011 7:38 pm Post subject: Using the shield as conductor |
On 9/19/2011 6:37 PM, John Grosse wrote:
<grosseair(at)comcast.net>
it for the "Mic Key Lo" input on the 430? It would save me from having
John Grosse
John, you simply tie (tee) into the Com audio low. Use the same method
you use for tying the shields together ala' BK's web site if you like.
Worked fine for me with a 430W and a different PSE audio panel.
Posted: Mon Sep 19, 2011 7:58 pm Post subject: Using the shield as conductor |
On 9/19/2011 8:34 PM, Tim Andres wrote:
<tim2542(at)sbcglobal.net>
> work.
> John Grosse
Sorry John I didnt read your mssg well. I see now you know what to do,
just had a question on how to do it.....
