Bill1200
Joined: 19 Oct 2008 Posts: 111 Location: medford oregon
Posted: Mon Sep 19, 2011 12:30 pm Post subject: Emergency Air Leak update |
First, ultrasonic leak detector....priceless, found the leak in under 5 min.
The leak is where the t-piece fitting joins the bottom of the emergency valve in front cockpit. (see pic). I tried tightening the nut but found it would leak if I tried tightening it too much. I thought either the t-fitting might be cracked or the housing of the valve cracked. So, I took the
t-piece out and found the rubber washer cracked and dry. So, I'm pretty sure that is the source. Housing looks fine, t-fitting not cracked either.
Where do I get new washer? For that matter, probably will get two. Also, I trashed some of the screws that hold the top cover plate down to the inside of the plane, so need more of those as well. Thanks, Bill
323.31 KB |
13454 Time(s) |
75.55 KB |
13454 Time(s) |
Posted: Mon Sep 19, 2011 1:00 pm Post subject: Emergency Air Leak update |
Bill,Change it out for a CJ6 main air valve with SS needle, they don't have any rubber gaskets to go bad and I think (from your photo) it will be a pretty much plug and play operation. I'd like to know myself so I'm willing to send you one to see if it will fit. If it fits, pay me, if not send it back.
Doug
On Mon, Sep 19, 2011 at 1:30 PM, Bill1200 <billdykes52(at)hotmail.com (billdykes52(at)hotmail.com)> wrote:
[quote] --> Yak-List message posted by: "Bill1200" <billdykes52(at)hotmail.com (billdykes52(at)hotmail.com)>
http://forums.matronics.com/viewtopic.php?p=352698#352698
http://forums.matronics.com//files/0919111151a_855.jpg
http://forums.matronics.com//files/0919111220washer_138.jpg
rget="_blank">http://www.matronics.com/Navigator?Yak-List
le, List Admin.
Bill1200
Posted: Mon Sep 19, 2011 2:20 pm Post subject: Re: Emergency Air Leak update |
Doug, not sure I understand. Wouldn't the t-piece still need to be attached to the valve in the same manner?
Posted: Mon Sep 19, 2011 2:49 pm Post subject: Emergency Air Leak update |
Bill,The T fitting is flare, flare, pipe thread. The pipe thread leg threads into the bottom of the valve, no rubber parts needed to seal. I'll try to send you a picture, save a thousand words...........
Best,
Doug
On Mon, Sep 19, 2011 at 3:20 PM, Bill1200 <billdykes52(at)hotmail.com (billdykes52(at)hotmail.com)> wrote:
[quote]--> Yak-List message posted by: "Bill1200" <billdykes52(at)hotmail.com (billdykes52(at)hotmail.com)>
Doug, not sure I understand. Wouldn't the t-piece still need to be attached the valve in the same manner?
http://forums.matronics.com/viewtopic.php?p=352710#352710
le, List Admin.
Posted: Mon Sep 19, 2011 4:07 pm Post subject: Emergency Air Leak update |
Try Jill at M14P. She may have the rubber washer in stock. As for the
screws, they are standard 4 mm screws. I'd suggest replacing them with
4 mm button head Philips screws. Can be either SS or zinc plated.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 9/19/2011 3:30 PM, Bill1200 wrote:
Bill1200
Posted: Mon Sep 19, 2011 4:21 pm Post subject: Re: Emergency Air Leak update |
Thanks Dennis. Do you think a properly fitting o-ring will work?
Doug, from the picture, I don't think the CJ valve will work for me. The top elbow fitting looks like it points directly down over the bottom fitting. My top elbow fitting is directed backwards away from bottom fitting. Don't think there is enough play in the tubing to attach it.
Posted: Mon Sep 19, 2011 4:42 pm Post subject: Emergency Air Leak update |
I would certainly try a metric o-ring. Size it to the original if possible.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 9/19/2011 7:21 PM, Bill1200 wrote:
http://forums.matronics.com/viewtopic.php?p=352726#352726
Bill1200
Posted: Mon Sep 19, 2011 4:46 pm Post subject: Re: Emergency Air Leak update |
Thanks, I'll give it a try tomorrow. Let you know.
Rich Langer
Posted: Tue Sep 20, 2011 2:55 am Post subject: Re: Emergency Air Leak update |
Bill:
What brand and model is your ultrasonic leak detector?
czech6(at)mesanetworks.ne Guest
Posted: Tue Sep 20, 2011 2:58 pm Post subject: Emergency Air Leak update |
I haven't read all this posting but my valve was leaking. NAPA for the closest "o" ring size very fine sand paper, very fine. Put the o ring on a stick spin the stick and sand it till it fits. Haven't leaked since. If this isn't the correct problem, sorry. I'll read further next time.
On Sep 19, 2011, at 6:38 PM, "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net> wrote:
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
Bill1200
Posted: Tue Sep 20, 2011 4:50 pm Post subject: Re: Emergency Air Leak update |
Problem solved. Went to ACE hardware store and bought 3 different sizes of o-rings. Went to hangar and found the one that fit the best. Pressure tested to 5 atm, no leak. Went for flight and re-check, seems good to go.
For the person who wanted to know which leak tester...it is a Miller Speacialty Tools Model6904A, found it on ebay
k7wx
Posted: Wed Sep 21, 2011 4:33 pm Post subject: Emergency Air Leak update |
Rich,
Look for a used Kent Moore J-41416 Accutrak Ultrasonic Leak Detector. Relatively inexpensive and will end up an indispensable item for chasing pneumatic system problems. They are often listed on eBay.
Here is a picture.
Warren Hill
N464TW
17.61 KB |
13319 Time(s) |
Posted: Wed Sep 21, 2011 4:58 pm Post subject: Emergency Air Leak update |
Guys, what ever make of ultrasonic leak detector you buy make sure it has a set of head phones. I bought a Amprobe off Ebay-- $150.00 as I recall, but that was 10 years ago. It works well for me.
Doug
On Wed, Sep 21, 2011 at 5:31 PM, Warren Hill <k7wx(at)earthlink.net (k7wx(at)earthlink.net)> wrote:
[quote] Rich,
Here is a picture.
Warren Hill
N464TW
> --> Yak-List message posted by: "Rich Langer" <rlanger2(at)comcast.net (rlanger2(at)comcast.net)>
> Bill:
> http://forums.matronics.com/viewtopic.php?p=352752#352752
