aerobiz1(at)gmail.com Guest
Posted: Mon Sep 12, 2011 6:49 am Post subject: Compression |
Hi Bobby,
This sounds all too familiar. Â From memory, my Jab manual says that you need to pull the cylinders if the reading is 60/80 or less, but I would strongly suggest doing the test again but on a warm engine before getting too excited.
Cheers
Martin
On Tue, Sep 13, 2011 at 12:31 AM, <BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net)> wrote:
List,
I just finished a differential compression check of my 3300 for it's Conditional Inspection.
It has 125 hrs and has been broken in correctly and oil changed regularly.
3 cylinders have dropped to the low 60's over 80. #3, 4 & 5 are down from the mid 70's. #3 was below 70 at last conditional but now I have two more following suit. The #3 & 4Â are not the hottest cylinders but #5 is second hottest. Engine was cold for 2 days at time of check. At this rate I don't know if it will make Top OH.
The compression is being lost through the rings as it can be heard thru the oil dipstick tube. Has anyone had a similar problem and is there any thing I can do about it. I am going to add Marvel Mystery to the fuel but I think that would be just a band aid on a more serious problem. How low should the compression get before I get alarmed??
Bobby Paulk
601 XL N131BP
Jabiru 3300 S/N 1141
ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
tp://forums.matronics.com
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
Garth
Posted: Mon Sep 12, 2011 7:33 am Post subject: Compression |
From my experience, when doing both leakdown and compression checks, engine temperature can make a significant difference. Jabiru says "warm to hot" for a leakdown test where the max 25% drop would apply. You may not have an issue at all.
Garth
From: "BobbyPaulk(at)comcast.net" <BobbyPaulk(at)comcast.net>
To: jabiruengine-list-digest(at)matronics.com
Sent: Monday, September 12, 2011 10:31:19 AM
Subject: Compression
#yiv439981971 p {margin:0;} #yiv439981971 p {margin:0;} #yiv439981971 p {margin:0;}
List,
3 cylinders have dropped to the low 60's over 80. #3, 4 & 5 are down from the mid 70's. #3 was below 70 at last conditional but now I have two more following suit. The #3 & 4 are not the hottest cylinders but #5 is second hottest. Engine was cold for 2 days at time of check. At this rate I don't know if it will make Top OH.
Bobby Paulk
601 XL N131BP
ist" rel=nofollow target=_blank>http://www.matronics.com/Navigator?JabiruEngine-List
et=_blank>http://forums.matronics.com
BARRY CHECK 6
Posted: Mon Sep 12, 2011 9:14 am Post subject: Compression |
Bobby:
MMO - Not to the fuel, but in to the CYLINDER. Remove the plug, squirt MMO all over the inside of the cylinder (about 1 oz per cylinder) and let it sit over night. If luck is on your side you may just free up some sticky rings.
If you want to add some MMO to the oil - - - ONE HOUR BEFORE AN OIL CHANGE. DO NOT RUN WITH MMO MORE THAN THAT.
You will see a cleaning of all internal parts.
MMO in the fuel is pretty much wasted. The ratio of fuel is so high and the flow rate so fast that it really does nothing. Been there - Done that.
Barry
On Mon, Sep 12, 2011 at 10:31 AM, <BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net)> wrote:
List,
Bobby Paulk
601 XL N131BP
pete(at)usjabiru.com Guest
Posted: Mon Sep 12, 2011 10:12 am Post subject: Compression |
Bobby,
Before you start adding mysterious additives please do what the manual says and warm up your engine thoroughly before the compression check. The engine should be as hot as practical to work with. We can take any engine cold and get very inconsistent compression results!
Pete Krotje
Jabiru USA Sport Aircraft, LLC
931-680-2800
www.usjabiru.com
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of FLYaDIVE
Sent: Monday, September 12, 2011 12:12 PM
To: jabiruengine-list(at)matronics.com
Subject: Re: Compression
Bobby:
Barry
List,
Bobby Paulk
601 XL N131BP
| Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution |
0123456789 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List | 0 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List | 1 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List | 2 | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List | 3
zeprep251(at)aol.com Guest
Posted: Mon Sep 12, 2011 1:08 pm Post subject: Compression |
Bobby,
Sometimes you can get the pressures up by slowly taking the piston over top center a few degrees and then bringing it back up to tdc WHILE HOLDING THE PROP FIRMLY THROUGH THIS MOTION!! It made a big difference on my Continental O200;s and IO470's
G.Aman
BobsV35B(at)aol.com Guest
Posted: Mon Sep 12, 2011 2:15 pm Post subject: Compression |
Good Afternoon Bobby,
The Comparative Compression Check has been proven to have many faults. So many such that Continental Motors now recommends that when the Compression gets below the ancient 75 percent rule, further investigation be used before a cylinder is pulled.
They specify that the valves be looked at via a Borescope. If the coloring is equal all the way around. The valves are not being "burned" and can remain in service.
In your case where you feel there is a ring problem, They recommend that oil consumption be monitored. As long as such consumption is normal (Whatever that is?) the engine is OK.
CMC recommends that no cylinder be removed on strictly a low compression number.
See Continental Service Bulletin SB03-3.
My take is that the same principles will apply to the Jabiru.
Happy Skies,
Old Bob
Stearman N3977A
Downers Grove, IL
LL22
In a message dated 9/12/2011 4:08:23 P.M. Central Daylight Time, zeprep251(at)aol.com writes:
| Quote: | Bobby,
G.Aman
-----Original Message-----
To: jabiruengine-list-digest <jabiruengine-list-digest(at)matronics.com>
Sent: Mon, Sep 12, 2011 11:11 am
#AOLMsgPart_1_79a14479-9575-491a-9f92-315c8cc51652 td{color: black;} #AOLMsgPart_1_79a14479-9575-491a-9f92-315c8cc51652 p { margin: 0; } #AOLMsgPart_1_79a14479-9575-491a-9f92-315c8cc51652 td{color: black;} #AOLMsgPart_1_79a14479-9575-491a-9f92-315c8cc51652 p { margin: 0; } #AOLMsgPart_1_79a14479-9575-491a-9f92-315c8cc51652 td{color: black;} #AOLMsgPart_1_79a14479-9575-491a-9f92-315c8cc51652 p { margin: 0; }
List,
Bobby Paulk
601 XL N131BP
Posted: Mon Sep 12, 2011 2:22 pm Post subject: Compression |
HMMM---
One more thing Bobby,
I should have mentioned that the Borescope inspection should include looking at the cylinder wall to check for scratches which may indicate a broken ring.
Happy Skies.
Old Bob
AKA
Bob Siegfried
Ancient Aviator
In a message dated 9/12/2011 5:15:55 P.M. Central Daylight Time, BobsV35B(at)aol.com writes:
| Quote: | Good Afternoon Bobby,
Happy Skies,
Old Bob
Stearman N3977A
Downers Grove, IL
LL22
| Quote: | Bobby,
G.Aman
List,
Bobby Paulk
601 XL N131BP
