Electric flaps
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List
alan99gill(at)yahoo.co.uk
PostPosted: Mon Sep 12, 2011 8:57 am    Post subject: Electric flaps Reply with quote
Hi all again
Have a person that has purchased a second hand Pulsar Series 1, 582 trigear. He wants to know if anyone has converted the flap control from hand operated to ELECTRIC flap.
Any photo, diagram and material used would be very useful.
Thanks again
Alan Gill
UK Pulsar Squadron Support.
- The Matronics Pulsar-List Email Forum -
http://www.matronics.com/Navigator?Pulsar-List
otto(at)otamat.com
PostPosted: Mon Sep 12, 2011 9:11 am    Post subject: Electric flaps Reply with quote
Hi Alan,
I have electric flaps on my Pulsar III. I am away from the plane now, but I can oblige with the build manual instructions, if OK.
Please advise.
regards
otto
On 12/09/2011 17:56, Alan Gill wrote: [quote] Hi all again
Thanks again
Alan Gill
w7ikt(at)fly-web.us
PostPosted: Mon Sep 12, 2011 10:58 am    Post subject: Electric flaps Reply with quote
I converted to electric flaps with a linear actuator. Shortened the flap handle and put it between the seats. Actuator behind seats pules flap handle with a cable.
I'm in Ohio on a trip for September and plane is in TX to no pictures now.
God Bless
Bob Heiser
On 9/12/2011 11:56 AM, Alan Gill wrote: [quote] Hi all again
Thanks again
Alan Gill
briana(at)xtra.co.nz
PostPosted: Mon Sep 12, 2011 11:53 am    Post subject: Electric flaps Reply with quote
Alan,
I built mine with electric flaps. Shortened the flap handle and installed it inside the centre console. It is operated by a linear actuator behind the seat, and a cable around a pulley mounted on the end of the flap handle. This arrangement sounds very similar to Bob Heiser. The pulley gives a 2:1 mechanical advantage, reducing the pull needed by the actuator.
I can sent some photos and a description, but can't include attachments on this list. If you email me privately I can respond.
Brian
jerry(at)craftworks.biz
PostPosted: Mon Sep 12, 2011 2:52 pm    Post subject: Electric flaps Reply with quote
BRIAN AND ALL, I ALSO HAVE ELECTRIC FLAPS BUT I DID IT BACK IN THE DAYS
(1993) BEFORE THERE WAS A PULSAR GROUP, WHEN YOU HAD TO INVENT SOMETHING. I
WAS IN THE GARAGE LOOKING AT MY GARAGE DOOR OPENER AND DECIDED THAT WAS HOW
I COULD MAKE IT WORK, SO I TOOK A 12 VOLT DRILL AND CUT OFF THE BATTERY AND
WIRED IT INTO A SWITCH ON MY STICK AND USED LIMIT SWITCHES AND A PIECE OF
ALL THREAD AND LIKE YOU SHORTENED UP THE HANDLE SO IT WOULD FIT UNDER THE
CENTER CONSOLE. 14 YEARS AND 1,200 HOURS AND AT LEAST A THOUSAND LANDINGS
AND STILL WORKS GREAT. THE DRILL MOTOR IS MOUNTED BEHIND THE SEAT. I HAD
TO MAKE A MOUNT FOR THE MOTOR AND INSTALL A BEARING THAT WOULD TAKE THE LOAD
OF THE FLAPS SO WITH A LITTLE TINKERING I'VE NEVER HAD TO FOOL WITH IT. I
THINK THAT GRAND TOTAL OF MONEY SPENT ON MATERIALS...$100? JERRY
-----ORIGINAL MESSAGE-----
[MAILTO:OWNER-PULSAR-LIST-SERVER(at)MATRONICS.COM] ON BEHALF OF BRIAN ANDERSON
SENT: MONDAY, SEPTEMBER 12, 2011 3:52 PM
TO: PULSAR-LIST(at)MATRONICS.COM
SUBJECT: RE: PULSAR-LIST: ELECTRIC FLAPS
--> PULSAR-LIST MESSAGE POSTED BY: BRIAN ANDERSON <BRIANA(at)XTRA.CO.NZ>
ALAN,
I BUILT MINE WITH ELECTRIC FLAPS. SHORTENED THE FLAP HANDLE AND INSTALLED IT
INSIDE THE CENTRE CONSOLE. IT IS OPERATED BY A LINEAR ACTUATOR BEHIND THE
SEAT, AND A CABLE AROUND A PULLEY MOUNTED ON THE END OF THE FLAP HANDLE.
THIS ARRANGEMENT SOUNDS VERY SIMILAR TO BOB HEISER. THE PULLEY GIVES A 2:1
MECHANICAL ADVANTAGE, REDUCING THE PULL NEEDED BY THE ACTUATOR.
I CAN SENT SOME PHOTOS AND A DESCRIPTION, BUT CAN'T INCLUDE ATTACHMENTS ON
THIS LIST. IF YOU EMAIL ME PRIVATELY I CAN RESPOND.
BRIAN
mortweaver(at)sbcglobal.n
PostPosted: Tue Sep 13, 2011 12:31 pm    Post subject: Electric flaps Reply with quote
Alan - I have a Pulsar XP (similar cabin dimension specs to Rotax 582 powered Pulsar Series I). I found a way to very simply retrofit to electric flaps using Fergelli 2 In. linear actuator. The actuator mounts in control stick tunnel, no intermediate cables or pulleys and no need to tear up seat bottom during retrofit process. I can provide pictures and my telephone number for assistance.
Dave Weaver N912GR
--- On Mon, 9/12/11, otto souta <otto(at)otamat.com> wrote:
Subject: Re: Electric flaps
To: pulsar-list(at)matronics.com
Date: Monday, September 12, 2011, 12:10 PM
Hi Alan,
Please advise.
regards
otto
Hi all again
Thanks again
Alan Gill
el=nofollow target=_blank>http://www.matronics.com/Navigator?Pulsar-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
fgilmer(at)twlt.net
PostPosted: Tue Sep 13, 2011 1:46 pm    Post subject: Electric flaps Reply with quote
David could you post the pictures to the group. I have an XP and would like to see how you setup the electric flaps.
If you have something you can email then send it to my email address of fgilmer(at)twlt.net
thanks Fred Gilmer
From: owner-pulsar-list-server(at)matronics.com [mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of David Weaver
Sent: Tuesday, September 13, 2011 3:30 PM
Dave Weaver N912GR
Hi Alan,
Please advise.
regards
otto
Hi all again
Thanks again
Alan Gill
el=nofollow target=_blank>http://www.matronics.com/Navigator?Pulsar-Listet=_blank>http://forums.matronics.comllow target=_blank>http://www.matronics.com/contribution
CYard52306(at)aol.com
PostPosted: Tue Sep 13, 2011 11:32 pm    Post subject: Electric flaps Reply with quote
In a message dated 13/09/2011 21:32:00 GMT Daylight Time, mortweaver(at)sbcglobal.net writes:
Dave
I am currently using a linear actuator but it is large heavy and cumbersome, do you have the model number and lb force rating, is the two inch stroke the best fit.I have enclosed a picture of miy fitting.
Regards Cy
G-PLSA 912
 Filesize:  1.12 MB
 Viewed:  11643 Time(s)
 Filesize:  1.12 MB
 Filesize:  1.12 MB
PostPosted: Wed Sep 14, 2011 9:35 am    Post subject: Electric flaps Reply with quote
Thank you otto. Your build manual instruction would assist me.
Regardfs ...> Alan
Sent: Monday, 12 September 2011, 18:10
Hi Alan,
Please advise.
regards
otto
Thanks again
Alan Gill
http://www.matronics.com/Navigator?Pulsar-Listhttp========================
otto(at)otamat.com
PostPosted: Fri Sep 16, 2011 5:09 am    Post subject: Electric flaps Reply with quote
Hi Alan,
please give me a few days, I have to get the scanner going.
regards
otto
On 14/09/2011 18:31, Alan Gill wrote: [quote] Thank you otto. Your build manual instruction would assist me.
Regardfs ...> Alan
From: otto souta <otto(at)otamat.com> (otto(at)otamat.com)
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Hi Alan,
Please advise.
regards
otto
Hi all again
Thanks again
Alan Gill
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List All times are GMT - 8 Hours
