rain tolerant prop
Goto page 1, 2  Next
Thom Riddle
PostPosted: Sun Sep 11, 2011 2:46 pm    Post subject: rain tolerant prop Reply with quote
I flew the SS to Bob Bean's field around noon today and from there we both flew our Kolbs to D52 Geneseo corn roast. En route we saw a t-storm just to the west of our destination and caught a wee bit of rain on the way. 1/2 hour or so after landing the T-storm moved onto the field so the hosts were magnanimous helping push our Kolbs into their big hangar until the T-storm passed. We had a very good lunch but the turn out was poor due Wx. I checked radar and it looked like a short break before the next one would arrive, so we headed back north to BB's place and flew in the light rain most of the way. with BB's help I topped my tank and headed west back towrd Buffalo with expectations of having to take circuitous route around the second t-storm. Fortunately, it stayed south of my intended route which is good because it was lightening a good bit. Still I had to fly for at least another 1/2 hour in the rain before passing the storm.
As I did my post flight inspection I noticed some deterioration in the outermost 8" or so of the leading edge, which did not surprise me. It was not too bad and I will dress it with a fine file. It is a beautiful Tennessee prop with inlaid leading edge protection which I think is polyurethane, and very very hard. My question is this, if I ever have to replace this prop, which prop has the very best resistance to rain damage? I hope not to fly in the rain on a regular basis, but sometimes it is difficult to avoid.
I do not wish to start a peeing contest between prop fans from different manufacturers, but would like to benefit from personal experience of those who have flown in rain enough with different props to form an educated opinion.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
slyck(at)frontiernet.net
PostPosted: Sun Sep 11, 2011 3:00 pm    Post subject: rain tolerant prop Reply with quote
Great minds.... almost qualifies as a double post - simultaneously.
BB
On 11, Sep 2011, at 6:46 PM, Thom Riddle wrote:
I flew the SS to Bob Bean's field around noon today and from there we.oboteh flew our Kolbs to D52 Geneseo corn roast. En route we saw a t-storm just to the west of our destination and caught a wee bit of rain on the way. 1/2 hour or so after landing the T-storm moved onto the field so the hosts were magnanimous helping push our Kolbs into their big hangar until the T-storm passed. We had a very good lunch but the turn out was poor due Wx. I checked radar and it looked like a short break before the next one would arrive, so we headed back north to BB's place and flew in the light rain most of the way. with BB's help I topped my tank and headed west back towrd Buffalo with expectations of having to take circuitous route around the second t-storm. Fortunately, it stayed south of my intended route which is good because it was lightening a good bit. Still I had to fly for at least another 1/2 hour in the rain before passing the storm.
Thom Riddle
Buffalo, NY (9G0)
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
Truth is what stands the test of experience.
- Albert Einstein
http://forums.matronics.com/viewtopic.php?p=351982#351982
ceengland(at)bellsouth.ne
PostPosted: Sun Sep 11, 2011 4:44 pm    Post subject: rain tolerant prop Reply with quote
Thom Riddle
Buffalo, NY (9G0)
Jabiru 2200A #1574
- Albert Einstein
Metal.
I know you can't really do that, but there you go. Smile
The urethane leading edges on props I've flown on larger planes are
not that hard; you can dent them slightly with your fingernail, but the
dent doesn't remain. I've never seen rain damage on the urethane, but
I've had the wood leading edge erode inboard (toward the hub) of where
the urethane stopped.
FWIW,
rmurrill(at)cox.net
PostPosted: Sun Sep 11, 2011 5:21 pm    Post subject: rain tolerant prop Reply with quote
In the world of Apache and Blackhawk main rotor blades...and most other
helicopters the best urethanes work great in desert sands, but fail rapidly
(a few hours) in heavy rain. Titanium, nickel or stainless abrasion strips
work great in rain, but degrades after a few hundred "brown out"' landings.
If you fly out of Bagram you put urethane tape over the metal abrasion
strips....If you fly out of Ft. Rucker ...no urethane..just the OEM metal
abrasion strip..From my experience, urethane or fiberglass blade tips
operating in rain means regular replacement of the protective tape.
HShack(at)aol.com
PostPosted: Sun Sep 11, 2011 6:01 pm    Post subject: rain tolerant prop Reply with quote
A guy in our club flew a MkIII on floats with over 900 takeoffs & landings [water]; the prop was a Hot Prop [formerly Kiev Prop]. There was no discernable wear on the prop. There is a lot of spray with water operations.
He now has Hot Props on all 3 of his planes.
Hot Prop has a bronze leading edge.
In a message dated 9/11/2011 6:48:55 P.M. Eastern Daylight Time, riddletr(at)gmail.com writes:
h20maule(at)hotmail.com
PostPosted: Sun Sep 11, 2011 6:11 pm    Post subject: rain tolerant prop Reply with quote
warp drive with nickel leading edge is the answer. Period
Thanks,Daniel Myers
Cell: 407 920 7700
SouthEastAmphibs.com
On Sep 11, 2011, at 9:58 PM, HShack(at)aol.com (HShack(at)aol.com) wrote:
[quote] A guy in our club flew a MkIII on floats with over 900 takeoffs & landings [water]; the prop was a Hot Prop [formerly Kiev Prop]. There was no discernable wear on the prop. There is a lot of spray with water operations.
In a message dated 9/11/2011 6:48:55 P.M. Eastern Daylight Time, riddletr(at)gmail.com (riddletr(at)gmail.com) writes:
PostPosted: Sun Sep 11, 2011 6:50 pm    Post subject: rain tolerant prop Reply with quote
Thom Riddle
Done a lot of rain flying in the MKIII, to the point several coats of Aerothane paint have been eroded off the leading edge of the wings and tail section over the years and hours.
My prop is a Warp Drive 3 blade tapered with 15" nickle steel leading edges.
Most of my rain flying has been in British Columbia, Yukon Territory, and Alaska.
I destroyed a new GSC two blade wooden prop in a matter of minutes in Florida.
My Jim Culver two blade wooden prop with polyurethane leading edges worked pretty good, but did not have near the endurance, in rain, that the Warp Drive has.
Morgan, UT
PostPosted: Sun Sep 11, 2011 7:03 pm    Post subject: rain tolerant prop Reply with quote
John, all my flying is water flying. That's the best testament I can give to warp. How many of us fly in rain anyways?
Daniel Myers
Cell: 407 920 7700
> Thom Riddle
Morgan, UT
Thom Riddle
PostPosted: Mon Sep 12, 2011 3:28 am    Post subject: rain tolerant prop Reply with quote
Thanks, guys. That is what I was looking for. For now, I'll dress my prop edge and continue with it but know what I'll do if/when I continue to wear out this one in rain.
I need to do some better sealing around the SS canopy too if rain flying becomes a habit. I did not get soaked but did get moist in a few select places. Flip over canopies are more prone to leaks at the leading edge than MkIII windshields with doors on the side.
Thom
On Sun, Sep 11, 2011 at 11:00 PM, Daniel Myers <h20maule(at)hotmail.com (h20maule(at)hotmail.com)> wrote:
[quote]--> Kolb-List message posted by: Daniel Myers <h20maule(at)hotmail.com (h20maule(at)hotmail.com)>
Daniel Myers
Cell: [url=tel:407%20920%207700]407 920 7700[/url]
On Sep 11, 2011, at 10:48 PM, <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
> --> Kolb-List message posted by: <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
>> Thom Riddle
> john h
> mkIII
> Morgan, UT
le, List Admin.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Richard Pike
PostPosted: Mon Sep 12, 2011 4:09 am    Post subject: Re: rain tolerant prop Reply with quote
Thom, I'm sure that the Warp is the toughest, but if you don't want to buy a new prop, you might try the Powerfin plastic prop tape, it works quite well and is not expensive. I'm sure it would go over your urethane leading edge and work ok, since it works ok on my IVO.
Richard Pike
MKIII N420P (420ldPoops)
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
neilsenrm(at)gmail.com
PostPosted: Mon Sep 12, 2011 5:09 am    Post subject: rain tolerant prop Reply with quote
Thom
Warp Drive makes a very durable prop but may not be as efficient as you existing prop. John Williamson had a Jabaru with a Warp Drive prop on his Kolbra and it wasn't a happy combination. Others seem to do well with their Jabarus on Kolbs using other props so I have to wonder if the Warp Drive might a poor choice for the Jabiru.
Rick Neilsen
Redrive VW Powered MKIIIC
On Mon, Sep 12, 2011 at 7:24 AM, Thom Riddle <riddletr(at)gmail.com (riddletr(at)gmail.com)> wrote:
[quote]Thanks, guys. That is what I was looking for. For now, I'll dress my prop edge and continue with it but know what I'll do if/when I continue to wear out this one in rain.
rickofudall
PostPosted: Mon Sep 12, 2011 6:18 am    Post subject: rain tolerant prop Reply with quote
Thom, Two suggestions to make your prop more rain tolerant. The first is from a fellow I met at the Arlington Air Show a number of years ago. He was flying a wood prop on his Varieze. His solution to rain erosion was to first flatten the leading edge of the blade to about 1/4" wide, then build it back up with JB Weld and re-contour. He said it provided excellent protection. The second is a source of propeller tape. Pegasus Auto Racing supply sells .011" thick urethane tape in 2" wide X 100' rolls that is suitable for helicopter blades. $9.99. https://www.pegasusautoracing.com/productselection3.asp?Product=3323
If you want clear tape they have .008" thick, too. A 2" X 108' roll is $19.99. https://www.pegasusautoracing.com/productselection3.asp?Product=3155
Good folks to deal with.
Rick Girard
On Mon, Sep 12, 2011 at 7:59 AM, Rick Neilsen <neilsenrm(at)gmail.com (neilsenrm(at)gmail.com)> wrote:
Thom
Rick Neilsen
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
willuribe(at)aol.com
PostPosted: Mon Sep 12, 2011 12:03 pm    Post subject: rain tolerant prop Reply with quote
I have flown my FireStar II in the rain with an IVO prop with no damage.
[img]cid:tie_8CE3F9DD0A160B8_A6C_25416[/img]
 Filesize:  21.8 KB
 Viewed:  14675 Time(s)
Thom Riddle
PostPosted: Mon Sep 12, 2011 12:38 pm    Post subject: rain tolerant prop Reply with quote
Thanks, Richard. I took a fine file to the leading edge urethane and smoothed it out easily and quickly. It was not damaged as much as I first thought. I'll get some Power Fin plastic tape and try it out as sacrificial material.
Thom
On Mon, Sep 12, 2011 at 8:09 AM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
[quote] --> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Thom, I'm sure that the Warp is the toughest, but if you don't want to buy a new prop, you might try the Powerfin Plastic prop tape, it works quite well and is not expensive. I'm sure it would go over your urethane leading edge and work ok, since it works ok on my IVO.
Richard Pike
Now faith is the substance of things hoped for, the evidence of things not seen.
Hebrews 11:1
http://forums.matronics.com/viewtopic.php?p=352018#352018
le, List Admin.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Thom Riddle
PostPosted: Mon Sep 12, 2011 1:19 pm    Post subject: rain tolerant prop Reply with quote
Thanks for the additional suggestions.
Will,
What rpm is your prop turning and what is its diameter? The reason I ask is that my Jabiru was turning about 2900 rpm (direct drive) while trying to get home fast in the rain. This is about 150 rpm more than my normal cruise. Only the outermost 6-7 inches of the 64" prop showed any damage. At 2900 RPM and air speed of 90 mph. The tips were moving thru the air at about 640 mph and the inner most point of the damage it was about 520 mph. At speeds less than that, the TN prop leading edge seems fine.
In the future, when flying in the rain, I will consider slowing down to 65 mph and 2400 rpm which will mean the tip speed is about 520 mph.
Thom
On Mon, Sep 12, 2011 at 4:00 PM, <willuribe(at)aol.com (willuribe(at)aol.com)> wrote:
 Filesize:  21.8 KB
 Viewed:  14665 Time(s)
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
PostPosted: Tue Sep 13, 2011 5:43 am    Post subject: rain tolerant prop Reply with quote
Thom,
It is a 62" 3 blade IVO Prop and in the picture the EIS is showing 6330 RPMs
Will Uribe
FireStar II
El Paso, TX
But next month I will be working in Tonowanda, NY
Thom Riddle
PostPosted: Tue Sep 13, 2011 6:00 am    Post subject: rain tolerant prop Reply with quote
Will,
Based on your numbers, assuming you have 2.58:1 gearbox and you are flying at 65 mph airspeed, then your prop tip speed is about 517 mph under those conditions. Based on your data and mine (admittedly small sample) about 520 mph or thereabouts seems to be the limit of at least composites before rain begins to cause damage.
Thom
On Tue, Sep 13, 2011 at 9:41 AM, <willuribe(at)aol.com (willuribe(at)aol.com)> wrote:
[quote] Thom,
Will Uribe
FireStar II
El Paso, TX
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Dennis.Kirby(at)kirtland.
PostPosted: Tue Sep 13, 2011 6:18 am    Post subject: rain tolerant prop Reply with quote
<< I'll get some Power Fin plastic tape and try it out as sacrificial material. Thom >>
Thom R - Where can you get Powerfin tape these days? I thought the company went out of business.
Dennis Kirby
Mark-3, 912ul
Sandia Park, NM
PostPosted: Tue Sep 13, 2011 6:45 am    Post subject: rain tolerant prop Reply with quote
Thom
Without the protection of the nickle steel leading edge, rain will eat up a Warp Drive solid carbon fiber prop blade.
In the old days, WD was limited to a 12" steAel edge. During my first flight to Alaska, in 1994, I ended up flying in hours of very heavy rain. When I landed at Arlington, WA, a gent named Bob, that worked for WD, told me to fix the erosion with JB Weld or I was going to blow a steel edge off. Rain had erroded a couple inches inboard of the steel edge, plus was trying to lift the inboard end of it. Did a field expedient repair on the airfield with avgas, a plastic picnic knife, and some sandpaper.
Today, WD has the technology to use 15" nickle steel leading edges. This takes care of that small area that was not protected by the old 12" edges.
Morgan, UT
Thom Riddle
PostPosted: Tue Sep 13, 2011 7:45 am    Post subject: rain tolerant prop Reply with quote
Denis,It did go out of business but someone bought them out and started selling them again, about a year ago or perhaps a little longer. I have not checked in recent months so don't know if they are still afloat. Google should tell you.
Thom
On Tue, Sep 13, 2011 at 10:15 AM, Kirby, Dennis Civ USAF AFMC AFNWC/EN <Dennis.Kirby(at)kirtland.af.mil (Dennis.Kirby(at)kirtland.af.mil)> wrote:
Dennis Kirby
Mark-3, 912ul
Sandia Park, NM
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Goto page 1, 2  Next
Page 1 of 2
