Halogen bulbs with wig wag circuitry....failure mode
PostPosted: Fri Sep 09, 2011 3:19 pm    Post subject: Halogen bulbs with wig wag circuitry....failure mode Reply with quote
I have H7604 lamps in my wing tips that aid landing and traffic
recognition. They are controlled by a solid state switcher that is
either OFF-ON-PULSED. ( I do not know the turn-on ramp characteristics..)
They fail in less than 10 hrs of operation. Interesting both seem to
fail nearly at the same time. The "pulse" mode for traffic
recognition is the major use.
My ignorant guess is that halogen bulbs do not like to be pulsed or
ramped up too quickly during pulse mode. If the rapid power ramp up
is the primary cause, I am wondering if an appropriate choke
(induction) would slow that ramping down and return normal life to
these devices.
If I were to do a WAG . . . I'm guessing that you're
getting repetitive stress cracks in the filaments.
These things operate somewhat hotter than their older
cousins . . . most seem to have heavier filaments too.
There are two things that erode filament integrity . . .
evaporation (total operating hours issue) and stress
cracks (combination of vibration and temperature cycling).
I'm wondering if the halogens are not more highly stressed
during each illumination cycle. Since a wig-wag operates
on the order of 2 flashes per second, 10 hours of flashing
would offer 72,000 or so temperature cycles. Far more cycles
than would be expected in automotive applications. Just
assuming 200 cycles per day in a high-beam lamp for night
highway driving would take 360 straight days of such service
to equal 10 hours of wig-wag.
Any insight, suggestions into the failure mode and how to work around
it would be greatly appreciated.
Not sure 'current ramping' would have a very useful effect.
Some of you may recall an experiment we did some years back
to evaluate the usefulness of inrush-limiters in wig-wagged
landing lights. Remember this plot?
http://www.aeroelectric.com/Pictures/Curves/Wig_Wag_Currents.jpg
We discovered that the lamp temperature stays pretty warm
during a 250 mS off-cycle such that you don't see the typical
cold-filament inrush each time the lamp is powered up. But
the temperature excursions between no-visible light and full
intensity is still significant. It may well be that the very
thing that makes the halogen a stellar illuminator amongst
incandescent lamps is it's Achilles Heel as well.
Just a guess . . . but until I hear/get a better idea, I'm
sticking with it.
skywagon
PostPosted: Fri Sep 09, 2011 4:52 pm    Post subject: Halogen bulbs with wig wag circuitry....failure mode Reply with quote
I think that you are totally correct concerning the thermo rapid cycle being
the stress failure mode.
When viewing the filaments with a mag. lens they look completely normal and
intact until you look carefully at one end of the filament. They are broken
at the very end.
Odd that I have not run into others that are having the same problem as
these bulbs are used in a lot of recognition applications.
I suspect that if I left them ON continually, they would last a normal life.
And, as you outline, in PULSE mode the thermo aspect is too much stress. I
wonder now, if there is a heavy duty version of this bulb with bullet proof
filament structure.
I am installing new bulbs when delivered and will report back when I have a
similar failure. Hopefully, I may have learned more.
Thanks, David
___________________________________________________________________________
sprocket(at)vx-aviation.c
PostPosted: Fri Sep 09, 2011 7:03 pm    Post subject: Halogen bulbs with wig wag circuitry....failure mode Reply with quote
I used inrush current limiters on my halogens (450+ hours so far). Since
this also causes the lamps to take more time to reach full brightness, I
modified the B&C flasher to slow it down by doubling the capacitance of the
electrolytic capacitor inside the can. Double the resistor value would also
work.
V
skywagon
PostPosted: Fri Sep 09, 2011 10:02 pm    Post subject: Halogen bulbs with wig wag circuitry....failure mode Reply with quote
Vern,
I am unfamiliar with the "current limiters" that you mention.
Your solution looks great. Please give a bit more detail...
I will check for my solid state flasher model and if it can be
modified...(not potted, etc.)
It was part of the RMD wing tip system.
David
andrew.d.zachar(at)gmail.
PostPosted: Sat Sep 10, 2011 3:09 am    Post subject: Halogen bulbs with wig wag circuitry....failure mode Reply with quote
Awhile back, I did a post about this exact modification. http://n999za.com/2010/11/07/hacking-the-wig-wag-flasher/
Of course, I was only successful because if this list's gracious help and advice. Hoping the pictures assist the discussion...
__
Andrew Zachar
andrew.d.zachar(at)gmail.com
On Sep 9, 2011, at 10:57 PM, "Vern Little" <sprocket(at)vx-aviation.com> wrote:
I used inrush current limiters on my halogens (450+ hours so far). Since this also causes the lamps to take more time to reach full brightness, I modified the B&C flasher to slow it down by doubling the capacitance of the electrolytic capacitor inside the can. Double the resistor value would also work.
V
PostPosted: Sat Sep 10, 2011 8:22 am    Post subject: Halogen bulbs with wig wag circuitry....failure mode Reply with quote
I used the CL-21 from
www.ge-mcs.com/download/temperature/920_325a.pdf
Available at Digi-Key
Thanks, V
PostPosted: Sat Sep 10, 2011 8:24 am    Post subject: Halogen bulbs with wig wag circuitry....failure mode Reply with quote
.. this is a circular reference... your quoting my own posts on your site!
Nice to see you documented it properly.
Cheers, V
Eric M. Jones
PostPosted: Sat Sep 10, 2011 9:19 am    Post subject: Re: Wig Wags etc. Reply with quote
I've been selling Wig-wags for many years. Our wig-wags do not depend on lamp resistance. They consist of two big mosfets driven by a mosfet driver and some simple internal timer. They cost more than the automotive type, and they are 100% solid state, so in theory that will last forever.
Early on, it was discovered that HIDs would destroy them for two reasons: 1) the starting current surge on an HID is very large (okay, short but tall), and the lamp and the + line sees a HV pulse at the same time. The solution to these issues was to supply a surge arrestor and an HV suppressor for those who wanted to wig-wag their HIDs. There are additional issues--these vary by lamp and ballast manufacturer--but people seem to be having very few problems.
Wig-wagging LEDs is trivial, but some LEDs require a voltage booster or constant current supply to function well. These employ little switch-mode power supplies that frequently make noise on the audio or HF transmitter lines. Bob published a fix for these, but I am not convinced.
Wig-wagging really big halogen lamps is also easy providing a current surge protector is used. I have demonstrated 2X 250 watt lamps wig-wagging happily with our WW(c) or WW(d).
After using these on my white LED tail lights, I finally had to give up and return to a simple, reliable (but not as efficient) LM317 current regulator (which I offer as a free design if you want to roll your own).
One final note: BMW is now testing white LASER auto headlamps. No, the lasers won't poke holes in things--lasers are used because they can be made to be several times more efficient (Lumens/Watt) than LEDs.
But LEDs are not slackers either...Cree has demonstrated a white LED of 231 Lumens Per Watt. And it keeps going up and up.
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
PostPosted: Sun Sep 11, 2011 7:57 am    Post subject: Halogen bulbs with wig wag circuitry....failure mode Reply with quote
Inrush current beyond the initial cold
start is not an issue for incandescent lamps.
The reason I plotted the this data . . .
[img]cid:.0[/img]
was to show that while the first, cold start inrush was the typical
30+ amps, subsequent start up currents were quite nominal. The lamp
being tested had a nominal on current of 4A (55w) but as you can see here,
the average start up current in the wig-wag mode was a tad above 5A.
This is because the filament doesn't cool off enough between flashes
to push the inrush even close to a cold-start value.
It isn't inrush killing these lamps by flashing them, it has to
be temperature cycling . . . for which there is no mitigating 'fix'.
After all, the reason these filaments produce white light is because
they've been elevated from below a dull red glow to the white light
produced by a metal glowing at 5000 degrees F. THATS a big temperature
shift.
I need to re-plot that trace above. There was some very strong
noise source going on at the time that produced the fuzzy spikes
on my data.
 Filesize:  257.77 KB
 Viewed:  13354 Time(s)
Eric M. Jones
PostPosted: Sun Sep 11, 2011 9:27 am    Post subject: Re: Halogen bulbs with wig wag circuitry....failure mode Reply with quote
Quite true Bob, however I tried not having a first cycle, but it never seemed to work. You ALWAYS have a first pulse.
Also, most timers using a 555 have an initial 1.5X times longer pulse than the second pulse. I no longer use the 555 for this reason. What I do now is have a faster r/c oscillator and a divider to get the correct timing. I'd be glad to share the schematic with interested parties.
Nice graph of the pulses.
I'd still bet that many halogen lamps have declined in quality. I've seen this first-hand. There are many variables in the making of halogen lamps.
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
PostPosted: Mon Sep 12, 2011 6:06 am    Post subject: Halogen bulbs with wig wag circuitry....failure mode Reply with quote
Sure . . . The purpose of study was to support a
discussion about the NTC thermistor style current limiters.
These things 'work' when allowed to heat up past the
resistance vs. temperature break point where the
device's resistance falls to some low, tolerable value
of series resistance.
I think we were talking about the CL series limiters
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=KC023L-ND
http://www.ge-mcs.com/download/temperature/920_325a.pdf
These stay in a low resistance state by a sustained
current flow and have a 'cool down' requirement of
2 to 20 seconds for them to 'reset' and be capable
of limited the next inrush event.
The discussion concluded that the thermistor style
device would perform as needed for the initial cold-
start transient but was too slow to help for closely
space repeat transients. The data plot showed that
second and subsequent events in an incandescent wig-wag
system were insignificant.
interested parties.
Yeah, my favorite is the CD4060 oscillator/divider.
Hope these don't go obsolete soon. I'm putting one
into a high school electronics class project. The
critters are 40 years old and still great ol' work
horses.
An alternative (if you can live in a 5v world) is
a PIC microcontroller. I keep the 8-pin flash devices
around to emulate more complex logic and timing
functions. It's a jelly bean part at about 75 cents
and capable of dropping into a bunch of applications
with the right code. I used one to generate a pair
of 17 Khz outputs to drive a push-pull, dc/dc converter
design. The single chip replaced 4 parts in the next-best
choice and was more stable to boot.
That's a plotting feature of even the low cost lines
of most 'scopes these days. I can plug a thumbdrive
into my TEK TDS220 scope and dump the screen to a
.jpg file. I can also get a dump of the numbers for
use in other analysis.
You got that right. But I'll bet it's cyclical too.
Suppliers are always wrestling for contracts but
price cannot be the sole driver. I think the value
trends are generally upward.
shenglu
PostPosted: Tue Oct 11, 2011 6:25 pm    Post subject: Re: Halogen bulbs with wig wag circuitry....failure mode Reply with quote
Light resistance is not dependent on our wig grow up. They include the MOSFET drivers and some simple two large internal timer-driven MOSFET. They cost more than the type of car.
Gadgets | Flash Memory
skywagon
PostPosted: Wed Oct 12, 2011 9:17 am    Post subject: Re: Halogen bulbs with wig wag circuitry....failure mode Reply with quote
Since this bulb failure issue was my original message and problem, I can add only another piece of mechanical evidence that may or may not have anything to do with the H7604 filament failures....
1. Under magnification, both filaments separated not in the coil section, but, on the short straight ends just before their connection post.
2. I do not know if the filaments (bulbs) were originally installed in the vertical or horizontal orientation. Rumor has it, that installing with the filaments vertically removes some of the mechanical stress from wing vibration and landing stresses.
3. I have installed the new H7604's with the filaments in the vertical orientation and will report in the future if this seems to extend the bulb life.
David
PostPosted: Fri Oct 14, 2011 7:35 am    Post subject: Halogen bulbs with wig wag circuitry....failure mode Reply with quote
Hmmmm . . . I'm suspicious of any 'benefit' for
orientation of filaments to increase resistance
to vibration stresses. Most materials exhibit a
thing called a stress-to-events-ratio (S/N ratio)
where a number of events at a particular stress
level are required to structurally fail the
material. Further, the S/N curve is generally
not linear. In other words, raising the stress
level by a factor of 3 does not necessarily
result in failure at 1/3rd the number of cycles.
It might drop to 1/4th the number of cycles.
Stress transients on landing are short duration
but very few in number compared hours of in-flight
stimulus.
Tungsten has a unique metallurgical property where
the metal transforms from a brittle to a ductile
state at a rather low temperature. I think it was
on the order 500F. In any case, it was below the
dull-red-glow temperature. In the chapter on
lighting in the 'Connection, I described two
techniques for keeping a filament warm when the
light was OFF. Maintaining the brittle filament
at or above it's brittle-to-ductile transition
temperature has a marked effect on the S/N ratio.
It would be a very interesting experiment to
try some form of keep-warm system on an airplane
that exhibits a high failure rate for tungsten
filament lamps.
skywagon
PostPosted: Fri Oct 14, 2011 9:38 am    Post subject: Halogen bulbs with wig wag circuitry....failure mode Reply with quote
You are always surprising me with your knowledge background. My grey matter
stores a lot and I have a degree in electronics, however, I learn constantly
from your inputs to all these problems and questions.
Funny, I did not know that the halogen environment still included tungsten
filaments. I was assuming, some other mixture of metal was the basis for
these brighter lamps.
You bring up an interesting option...to keep the lamp filaments in their
flexible or ductile stage while in any none use state. I wonder what level
of current would be needed for that in a 12 - 14 v. system. And, an option
would have to be planned in the case of an alternator failure to cut the
background lamp current. Thanks, David
