Posted: Tue Sep 06, 2011 7:39 am Post subject: Low Emergency Air Pressure |
Yak 52 or CJ6?
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 9/6/2011 10:05 AM, Bill1200 wrote:
Just noticed emergency air pressure low, reading about 1, otherwise everything else normal pressure, compressor brings pressure up to normal on the other side during flight, just not the emergency side. Any suggestions on where to start looking for leak?
http://forums.matronics.com/viewtopic.php?p=351539#351539
kingcj6(at)aol.com Guest
Posted: Tue Sep 06, 2011 7:50 am Post subject: Low Emergency Air Pressure |
Probably the check valve located on the upper right firewall. Doug has the rebuild kits.
byronmfox(at)gmail.com Guest
Posted: Tue Sep 06, 2011 7:57 am Post subject: Low Emergency Air Pressure |
Most likely the check valve on the starboard firewall above the start solenoid. Mine was leaking not so long ago. Doug Sapp has an overhaul kit, assuming your referring to a CJ.
On Sep 6, 2011, at 8:36 AM, "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net> wrote:
Yak 52 or CJ6?
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
brian(at)lloyd.com Guest
Posted: Tue Sep 06, 2011 7:59 am Post subject: Low Emergency Air Pressure |
On Tue, Sep 6, 2011 at 8:05 AM, Bill1200 <billdykes52(at)gmail.com (billdykes52(at)gmail.com)> wrote:
| Quote: | --> Yak-List message posted by: "Bill1200" <billdykes52(at)gmail.com (billdykes52(at)gmail.com)>
Look for a corroded check valve going over to the emergency side. If it is stuck closed the compressor won't be able to charge the emergency side.
Brian Lloyd, WB6RQN/J79BPL
3191 Western Dr.
Cameron Park, CA 95682
brian(at)lloyd.com (brian(at)lloyd.com)
+1.767.617.1365 (Dominica)
+1.916.877.5067 (USA)
yakplt(at)yahoo.com Guest
Posted: Tue Sep 06, 2011 8:30 am Post subject: Low Emergency Air Pressure |
On a YAK-52, the emergency bottle is not filled by the compressor. Only by the external fill port.
On the YAK-50, the compressor charges both main and emergency.
Mark Bitterlich
To: yak-list(at)matronics.com
Sent: Tuesday, September 6, 2011 11:56 AM
Subject: Re: Low Emergency Air Pressure
3191 Western Dr.
=nofollow target=_blank>http://www.matronics.com/Navigator?Yak-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
Bill1200
Joined: 19 Oct 2008 Posts: 111 Location: medford oregon
Posted: Tue Sep 06, 2011 10:27 am Post subject: Re: Low Emergency Air Pressure |
It is a YAK 52, didn't know the compressor doesn't fill it. I'll fill it externally and listen for leak, thanks. Are the check valve post only for CJ, or does that apply to 52 as well?
Bill1200
Posted: Tue Sep 06, 2011 11:30 am Post subject: Re: Low Emergency Air Pressure |
Found schematic for air system. What does the "protection" valve do? On the schematic it is between the taps and the gear actuator.
Posted: Tue Sep 06, 2011 11:37 am Post subject: Low Emergency Air Pressure |
Protection valve is a check valve.
For the Yak 52, the check valve for the emergency system is inside the
fuselage, just behind the external air fill port. You can test this
fairly easily, if it is a check valve leak. After filling the system
from the external air fill port, spray some soapy water on the external
port opening and see if it bubbles. If it does, the check valve I just
mentioned is leaking.
Before going further, let's do the simple test above and let me know
what you find.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
Bill1200
Posted: Tue Sep 06, 2011 11:55 am Post subject: Re: Low Emergency Air Pressure |
Thank you Dennis. Won't be back home until tomorrow. But when I do that test, I'll post results.
LawnDart
Posted: Tue Sep 06, 2011 12:04 pm Post subject: Re: Low Emergency Air Pressure |
I'm betting on the square o-ring in one of the red emergency valves in either the front or rear cockpit. I've had two leaks in 11 years - each time it was one of these o-rings. Item 6 on the attached diagram (the one on the bottom fitting).
23.51 KB |
17338 Time(s) |
Posted: Tue Sep 06, 2011 12:24 pm Post subject: Low Emergency Air Pressure |
Good point. There is a test that one can do to see if the problem is
one of the emergency air valves. Very easy to do.
- Observe and write down the pressure in both the emergency and main
systems.
- With the main air valve off, (assuming both emergency valves are
closed tightly), squeeze the brake handle until all air is depleted in
the system or until you no longer hear the "woosh" sound when you
release the brake handle.
- Now leave the pneumatic system alone overnight or for at least for a
few hours.
- When you come back to the airplane, squeeze the brake handle again and
if you hear the "woosh" sound again AND the emergency side of the
pressure instrument has leaked down, one of the two emergency air valves
is leaking.
Now it is just a matter of isolating which valve is leaking.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
Posted: Tue Sep 06, 2011 2:12 pm Post subject: Low Emergency Air Pressure |
On Tue, Sep 6, 2011 at 9:25 AM, Yak Pilot <yakplt(at)yahoo.com (yakplt(at)yahoo.com)> wrote:
| Quote: | On a YAK-52, the emergency bottle is not filled by the compressor. Only by the external fill port.
Mark Bitterlich
Sorry Mark. I was thinking CJ6A. Emergency side is filled from the compressor.
3191 Western Dr.
On Tue, Sep 6, 2011 at 11:27 AM, Bill1200 <billdykes52(at)gmail.com (billdykes52(at)gmail.com)> wrote:
Mark answered. The CJ6A fills the emergency system from the engine-driven compressor through a check valve.
3191 Western Dr.
k7wx
Posted: Tue Sep 06, 2011 2:46 pm Post subject: Low Emergency Air Pressure |
Dennis,
Some air leaks can be insidious. Picked up a used ultrasonic leak detector on eBay for a little over $100 and this has helped me to cure all the leaks in both the main and emergency systems. With the probe tip properly placed, even the smallest leak is easy to locate.
Warren
On Sep 6, 2011, at 1:21 PM, A. Dennis Savarese wrote:
Good point. There is a test that one can do to see if the problem is one of the emergency air valves. Very easy to do.
- Observe and write down the pressure in both the emergency and main systems.
- With the main air valve off, (assuming both emergency valves are closed tightly), squeeze the brake handle until all air is depleted in the system or until you no longer hear the "woosh" sound when you release the brake handle.
- Now leave the pneumatic system alone overnight or for at least for a few hours.
- When you come back to the airplane, squeeze the brake handle again and if you hear the "woosh" sound again AND the emergency side of the pressure instrument has leaked down, one of the two emergency air valves is leaking.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
> I'm betting on the square o-ring in one of the red emergency valves in either the front or rear cockpit. I've had two leaks in 11 years - each time it was one of these o-rings. Item 6 on the attached diagram.
> http://forums.matronics.com/viewtopic.php?p=351569#351569
> http://forums.matronics.com//files/em_valve_904.jpg
Posted: Tue Sep 06, 2011 5:19 pm Post subject: Low Emergency Air Pressure |
Warren,
You are 110% on the money. I have one myself. But yours must be better
than mine. Probably because I paid too much for it in the first place.
I assumed Bill did not have one and gave him the two easiest
troubleshooting procedures based on the most common causes of emergency
system leaks. Hopefully the soapy water on the external air fill port
will show the problem. If not, I'll help him figure it out.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 9/6/2011 5:44 PM, Warren Hill wrote:
Dennis,
Warren
> Dennis
> A. Dennis Savarese
> 334-285-6263
> 334-546-8182 (cell)
> Skype: Yakguy1
> www.yak-52.com
wlannon(at)persona.ca Guest
Posted: Tue Sep 06, 2011 8:33 pm Post subject: Low Emergency Air Pressure |
On the CJ if you wish to charge the emergency tank only, for example with nitrogen rather than air simply leave the main air valve closed.
Probably applies to the Yak 50 as well
Walt
Rob Rowe
Joined: 10 Jan 2006 Posts: 124 Location: Berkshire, UK
Posted: Wed Sep 07, 2011 2:52 am Post subject: Re: Low Emergency Air Pressure |
Dennis / Bill,
Believe the protection valve Bill enquired about is the one located under the starboard side of the front cockpit seat (YAK-52).
Its vents the emergency air line (between the tap(s) and gear shuttle valves / uplocks) to atmosphere below 5 kgf/cm2 line pressure, to stop MINOR leaks from the taps or shuttle valve 'peas' interfering with normal gear operation.
For that very reason if you need to operate the emergency air system for real then open the tap quickly and fully to make sure the protection valve snaps shut (>5 kgf/cm2), otherwise you'll just waste the precious 3 litres reserve air ventilating the P1's derriere! Keeping in mind, having lowered the gear, you may well need what emergency air is left to also operate the brakes post landing.
Similarly the overnight air tap leak test suggested will probably be inconclusive for a YAK-52 because the air will most likely have been dumped externally by the protection valve as <5 kgf/cm2.
If the emergency air bottle has recently been disturbed for maintenance then I believe they can be troublesome to seat back on their seals ... which may be another aspect to consider in your leak down quest.
Good luck.
brgds, Rob R
| dsavarese0812(at)bellsout wrote: |
fuselage, just behind the external air fill port ...
Posted: Wed Sep 07, 2011 6:08 am Post subject: Low Emergency Air Pressure |
No, it does not. The YAK-50 has four check valves. Two for air input: One from the compressor, one from the external air. These come together at the pressure relief valve and prevent reverse flow.
Out of the pressure relief valve you go to a "T" connector which feeds an air strainer. The output of the air strainer, goes to another "T" connector where there are two more check valves. Top one goes to emergency air bottle, bottom one goes to main air bottle. Both go DIRECTLY to the bottles. The air shut off valve in the cockpit does not control air INPUT in any way to either bottle. It only controls air output.
Mark Bitterlich
Sent: Wednesday, September 7, 2011 12:30 AM
Subject: Re: Yak-List: Low Emergency Air Pressure
Walt
Posted: Wed Sep 07, 2011 7:00 am Post subject: Low Emergency Air Pressure |
On Wed, Sep 7, 2011 at 7:05 AM, Yak Pilot <yakplt(at)yahoo.com (yakplt(at)yahoo.com)> wrote:
| Quote: | No, it does not. The YAK-50 has four check valves. Two for air input: One from the compressor, one from the external air. These come together at the pressure relief valve and prevent reverse flow.
Mark Bitterlich
Has anyone else noticed that there are a lot more check valves in our airplanes than are needed to ensure system integrity after a partial failure? While helping Dennis Nickson troubleshoot an intermittent problem with the pneumatic system in his CJ it was pretty obvious that I could replace several of the check valves with straight pipe and it would have no effect on either the normal operation or how the system would fail if it was breached at various places. And I suspect that pieces of straight pipe are less likely to fail and cause problems than the various unnecessary check valves.
I am thinking that, right after removing and throwing away the arcane and unnecessary complexity of the electrical system, we could probably to do the same for much of the pneumatic system as well.
3191 Western Dr.
Posted: Wed Sep 07, 2011 7:23 am Post subject: Low Emergency Air Pressure |
All excellent points Robb. Regarding the "fart" valve you mention and
refer to as the protection valve, if there is a leak from either one of
the emergency air valves and the protection valve bleeds the low
pressure off as you suggest, then one could use either a leak detector
or soapy water (or for that matter, stretch a balloon on the top of the
valve which would expand slowly) to determine if the leak is from one of
I can say this with carnal knowledge; the overnight test I previously
mentioned does work for a leaking main air valve.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
On 9/7/2011 5:52 AM, Rob Rowe wrote:
Dennis / Bill,
http://forums.matronics.com/viewtopic.php?p=351640#351640
