AA5 - Winglets
Goto page 1, 2  Next
andrew(at)entro.com
PostPosted: Mon Aug 29, 2011 6:56 pm    Post subject: AA5 - Winglets Reply with quote
Has a winglet mod been made available for the AA5?
Andrew
[quote] NOTICE OF CONFIDENTIALITY. This communication, including any information transmitted with it, is intended only for the use of the addressee(s) and is confidential. If you are not an intended recipient or responsible for delivering the message to an intended recipient, any review, disclosure, conversion to hard copy, dissemination, reproduction or other use of any part of this communication is strictly prohibited, as is the taking or omitting of any action in reliance upon this communication. If you received this communication in error or without authorization please notify us immediately by return e-mail or otherwise and permanently delete the entire communication from any computer, disk drive, or other storage medium. [quote][b]
teamgrumman(at)yahoo.com
PostPosted: Mon Aug 29, 2011 8:36 pm    Post subject: AA5 - Winglets Reply with quote
Funny you should ask. I have teh drawings and the beginning of a mock up. Wheel pants are next.
Sent: Monday, August 29, 2011 7:53 PM
Subject: TeamGrumman-List: AA5 - Winglets
Andrew
h --> http://www.matronics.com/con================
Discover
PostPosted: Tue Aug 30, 2011 5:13 am    Post subject: AA5 - Winglets Reply with quote
Gary,
Do you mean winglets or wingtips?
ned
andrew(at)entro.com
PostPosted: Tue Aug 30, 2011 5:29 am    Post subject: AA5 - Winglets Reply with quote
Winglets. They are supposed to reduce/eliminate wingtip vortices thereby increasing speed, and fuel efficiency maybe wing loading. I have some loose drawings but I wouldn't know how to calculate what the effect would be. Would winglets add much to the AA5?
Andrew
Andrew Kuzyk BID, ACIDO, RGD // Partner
Entro Communications
122 Parliament St.
Toronto, Canada M5A 2Y8
T: 416-368-6988 x 222
M: 416-706-4490
F: 416-368-5616
www.entro.com
[url=http://www.entro.com/][/url]
On Aug 30, 2011, at 9:13 AM, 923te wrote:
[quote]Gary,
ned
[quote]---
Discover
PostPosted: Tue Aug 30, 2011 5:40 am    Post subject: AA5 - Winglets Reply with quote
On my lancair winglets add lift but also drag at lower altitudes but at higher altitudes they add controllability and the additional drag over the original wingtip is not so much up high. Without the winglets its pretty hard to fly by hand over about 22000 ft.
Don't know that winglets would be a benefit to a Tiger that flies down low but I think there is room for drag reduction and weight reduction over the factory wingtips.
ArjayS(at)AOL.COM
PostPosted: Tue Aug 30, 2011 6:21 am    Post subject: AA5 - Winglets Reply with quote
You are correct on all counts. There IS a little benefit on an AA5 wing but not a lot. However everthing counts and a knot here and there adds up. However, the biggest issue is certification and that is a big issue (read: expensive). Among other issues you are talking about a compete spin program. I'm getting dizzy just thinking about it.
Rj Siegel CEO/LoPresti Aviation Engineering
andrew(at)entro.com
PostPosted: Tue Aug 30, 2011 9:56 am    Post subject: AA5 - Winglets Reply with quote
Hi RJ,
I spoke with David Fletcher a while back, he mentioned someone had produced winglets but did not think that any where sold. So there may be winglets with all the appropriate paper work in someone's basement collecting dust. It may not have sold due minimal performance increase at maximum cost but then again maybe there is enough of a performance justification.
Andrew
122 Parliament St.
M: 416-706-4490
F: 416-368-5616
www.entro.com
href="http://www.matronics.com/Navigator?TeamGrumman-List">http://www.matronics.com/Navigator?TeamGrumman-List
ArjayS(at)AOL.COM
PostPosted: Tue Aug 30, 2011 10:11 am    Post subject: AA5 - Winglets Reply with quote
Hi Andrew
Yes, there are winglets with NONE of the appropriate paperwork, which is why it's in Steve Millers basement. When he found out how much it would cost to certify (after three years of fighting a losing battle) he tossed it in the corner.
Hi RJ,
PostPosted: Tue Aug 30, 2011 11:01 am    Post subject: AA5 - Winglets Reply with quote
A little of both.  It's a modified wingtip. Calculations show a 1-3% increase in speed at 10,000 feet. Worth it? No. But they look bitchin'
Sent: Tuesday, August 30, 2011 6:13 AM
Subject: Re: AA5 - Winglets
Gary,
ned
haveblue1(at)mac.com
PostPosted: Tue Aug 30, 2011 1:04 pm    Post subject: AA5 - Winglets Reply with quote
Gary,
Something like these?
http://www.minix.fr/english/abstract.php
Bruce
On Aug 30, 2011, at 2:58 PM, Gary Vogt wrote:
[quote]A little of both. It's a modified wingtip. Calculations show a 1-3% increase in speed at 10,000 feet. Worth it? No. But they look bitchin'
To: teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
Gary,
ned
ferdi
PostPosted: Fri Apr 13, 2012 9:33 pm    Post subject: Re: AA5 - Winglets Reply with quote
Hi Guys, I own a Traveler registered as experimental in South Africa. If there are winglets that are just lying around I would like to give it a try. How can I get hold of the owner?
n76lima(at)mindspring.com
PostPosted: Sat Apr 14, 2012 3:45 am    Post subject: AA5 - Winglets Reply with quote
Winglets??? For a Grumman?
Did you mean wing TIPS, as in the fiberglass ends of the wing? There would be no Whitcomb Winglets for a certified Grumman. We should be asking YOU about such things on an experimental.
--Bob Steward
Sent from Samsung mobile
http://forums.matronics.com/viewtopic.php?p=370766#370766
andrew(at)entro.com
PostPosted: Sat Apr 14, 2012 6:50 am    Post subject: AA5 - Winglets Reply with quote
A while back I was looking for winglets and there was an email thread that suggested someone had developed some but would require an expensive STC to make them viable. I'll look through my emails. I too am still interested - ideally it would be great to know what kind of anticipated numbers the enhancement would give.
Andrew Kuzyk
M: 416-706-4490
On Apr 14, 2012, at 7:44 AM, Bob Steward wrote:
[quote]--> TeamGrumman-List message posted by: Bob Steward <n76lima(at)mindspring.com (n76lima(at)mindspring.com)>
--Bob Steward
ferdi <ferdi_koekemoer(at)yahoo.com (ferdi_koekemoer(at)yahoo.com)> wrote:
[quote]--> TeamGrumman-List message posted by: "ferdi" <ferdi_koekemoer(at)yahoo.com (ferdi_koekemoer(at)yahoo.com)>
http://www.matronics.com/co=================
Discover
PostPosted: Sat Apr 14, 2012 7:58 am    Post subject: AA5 - Winglets Reply with quote
PostPosted: Sat Apr 14, 2012 9:03 am    Post subject: AA5 - Winglets Reply with quote
Really not worth the aggravation. You'd only see about 1-3% speed improvement above 10,000 feet.
Sent: Friday, April 13, 2012 10:33 PM
http://www.matronics.com/Navigator?TeamGrumman-List<========================
ferdi
PostPosted: Sun Apr 15, 2012 12:17 am    Post subject: Re: AA5 - Winglets Reply with quote
[quote="ArjayS(at)AOL.COM"]Hi Andrew
Hi RJ, �
I spoke with David Fletcher a while back, he mentioned someone had produced winglets but did not think that any where sold. �So there may be winglets with all the appropriate paper work in someone's basement collecting dust. It may not have sold due minimal performance increase at maximum cost but then again maybe there is enough of a performance justification.
This is what I am interested. The only aggravation would be getting it to South Africa.
Discover
PostPosted: Sun Apr 15, 2012 7:17 am    Post subject: AA5 - Winglets Reply with quote
Ferdi,
Can you tell us more about your experimental Traveler? Does it have anything done to it beyond what the factory did?
ned
ferdi
PostPosted: Sun Apr 15, 2012 7:51 am    Post subject: Re: AA5 - Winglets Reply with quote
Ned, I have only had the plane for a year now. I recently fitted an 0-360A1AD. Empty weight with the new engine is 1360, and I intend to bring it down a little more (prince prop and spline driven alternator are some of my ideas.) I am also busy with glass panel at the moment (pic attached) crossover exhaust and RV wheelpants. I am slowly fixing her up as she stood idle for 20+ years. I flew about 60 hours before the engine change.
 Filesize:  276.26 KB
 Viewed:  11073 Time(s)
 Filesize:  418.68 KB
flyv35b(at)minetfiber.com
PostPosted: Sun Apr 15, 2012 2:49 pm    Post subject: AA5 - Winglets Reply with quote
http://forums.matronics.com/viewtopic.php?p=370864#370864
How were you able to get it licensed as an experimental?
The RV-10 fairings look nice. I assume you can get a hydraulic
controlled constant speed prop for it.
Cliff
andrew(at)entro.com
PostPosted: Sun Apr 15, 2012 7:42 pm    Post subject: AA5 - Winglets Reply with quote
Thanks, Its a shame it didn't have more performance benefits I do like the look of them.
A
Andrew Kuzyk
Hi RJ, �
http://forums.matronics.com/viewtopic.php?p=370828#370828
- The --> &n========================
Goto page 1, 2  Next
Page 1 of 2
