Paint air water separator
carl.froehlich(at)verizon
PostPosted: Mon Aug 15, 2011 3:20 pm    Post subject: Paint air water separator Reply with quote
For those of you doing your own painting, attached photo is a water separator that I find to work well. When painting I add a few blocks of ice to the water. In the photo the red hose is air in, the orange hose is air out. The drain valve is connected at the bottom of the vertical PVC pipe. The vertical pipe acts as a water collector.
Carl
 Filesize:  122.09 KB
 Viewed:  3157 Time(s)
whd721
PostPosted: Tue Aug 23, 2011 7:47 am    Post subject: Paint air water separator Reply with quote
Carl,
Thanks for posting good ideas both your water separator and the air box. Good ideas I will file away.
Carl
<Water separator.jpg>
whd721
RV9A
Beaverton, OR
PostPosted: Tue Aug 23, 2011 4:31 pm    Post subject: Paint air water separator Reply with quote
Thanks for the note. Did a marathon paint session last week and finished the fuselage.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William DeLacey
Sent: Tuesday, August 23, 2011 11:43 AM
Subject: Re: Paint air water separator
Carl,
Carl
 Filesize:  100.85 KB
 Viewed:  3098 Time(s)
 Filesize:  107.76 KB
