plated spinner
teamgrumman(at)yahoo.com
PostPosted: Wed Aug 17, 2011 9:12 am    Post subject: plated spinner Reply with quote
I have a spinner that someone had plated a long time ago. Most of the plating had come off.  Then it was painted. When I stripped it to repaint it, I found bits and pieces of the plating still there. I tried removing the plating by sanding, didn't work. Tried a wire wheel on an edge to see if I could pick up the edge, didn't work.
Question: How does one remove this plating?
dvonruden(at)generalequip
PostPosted: Wed Aug 17, 2011 9:40 am    Post subject: plated spinner Reply with quote
If it is truly nickel-chrome plated, the only real solution is to take it to a good plating shop that will “unplate” it. Much like stripping old chrome plating from an automobile bumper. What remains is very well adhered to the base metal and will not be removed with any other mechanical process.
From what you describe, the original plating process was not done properly. A good speed ship that has access to nickel-chrome plating will do an excellent job.
Dennis
Dennis Von Ruden
President
620 Alexander Drive S.W.
P.O. Box 334
Owatonna, MN 55060
800.533.0524 voice
+5074515510 voice
877.344.4375 fax
+5074515511 fax
dvonruden(at)generalequip.com (dvonruden(at)generalequip.com)
www.generalequip.com
Sent: Wednesday, August 17, 2011 12:09 PM
To: Teamgrumman List
Subject: plated spinner
[/b][/quote]ist Un/Subscription,[/b]http://www.matronics.com/Navigator?TeamGrumman-List[/b]t; http://www.matronics.com/contribution [/quote]0
ALL INFORMATION IN THIS EMAIL, AND/OR ATTACHMENT(S) IS CONFIDENTIAL. If you received this e mail in error, and are not the recipient(s) or responsible for receiving this e mail for the recipient, please inform the sender immediately, delete the e mail and any attachment(s) associated.
This email has been scanned by Barracuda - Email Security System.
 Filesize:  3.42 KB
 Viewed:  903 Time(s)
