japhillipsga(at)aol.com Guest
Posted: Sun Aug 14, 2011 9:46 pm Post subject: RV-8aAP Bank Servo Backwards |
RV-8 Buds, flew my 8a this afternoon and finally screwed up the courage to turn on the AP. Took a mil second for the plane to snap roll to the right. Stopped her about vertical and flipped the switch. Must have wired the bank servo backward. Anybody know the easiest fix? I have a MGL EFIS Odyssey with Trio AP servos. Shocking moment. Thanks, Bill of Georgia N288WP, 15.1 Hrs in Phase l
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Speedy11(at)aol.com Guest
Posted: Mon Aug 15, 2011 6:42 am Post subject: RV-8aAP Bank Servo Backwards |
Bill,
Do some ground testing of the AP. See if it instantly reacts and in which direction while on the ground. My AP would very slowly move after a short delay while on the ground. You can also detect and correct reverse sensing at the same time.
I'm surprised yours rolled so quickly. That is very unusual for an AP. It sounds as if it went quickly to full deflection. I make a habit of guarding the stick each time I engage it.
You may not have anything wired backward. For example, if it engaged in heading select mode and the heading bug was set to the right of the present heading, the AP would quickly direct a right bank - although not to the extreme you described.
Have you called Trio about it? I would talk to them first.
Your gains may be set wrong also.
Good luck,
Stan Sutterfield
In a message dated 8/15/2011 3:08:20 A.M. Eastern Daylight Time, rv8-list(at)matronics.com writes:
| Quote: | RV-8 Buds, flew my 8a this afternoon and finally screwed up the courage to
th Trio AP servos. |
Posted: Mon Aug 15, 2011 9:27 am Post subject: RV-8aAP Bank Servo Backwards |
Stan, thanks for the shoulder, I'll call MGL & Trio the P.M. Best to you, Bill
