601 owners... something to watch for - engine mount fittings
mtherr(at)yahoo.com
PostPosted: Sat Aug 13, 2011 7:29 pm    Post subject: 601 owners... something to watch for - engine mount fittings Reply with quote
Hi group!
I had a major unpleasant surprise today when I dismantled my firewall-forward installation.  While removing the engine mount, I felt there was too much "play" in the movement of an upper engine mount fitting bolt. This is part 6-F-7-2 in the plans.
My upper left fitting was indeed cracked in such a way that the side angle was no longer united to the front side of the fitting. There might be more and I will know later when I remove the four fittings to inspect, sand blast and repaint them. At first glance, the lower fittings appear OK.
These are parts I never really inspected when I did my annuals so I don't know if I have been flying with broken engine mount fittings or not and for how long. But I don't like the idea that I did.
Michel Therrien CH601-HD, C-GZGQ
http://mthobby.pcperfect.com/ch601
http://pages.infinit.net/mthobby
[quote] [b]
dgraham7(at)TWCNY.RR.COM
PostPosted: Sun Aug 14, 2011 4:23 am    Post subject: 601 owners... something to watch for - engine mount fittings Reply with quote
Thanks. I have been working on the issues that you two brought up during the annual and I will send you a report when I finish.
Damien
On Aug 13, 2011, at 11:24 PM, Michel Therrien <mtherr(at)yahoo.com (mtherr(at)yahoo.com)> wrote:
[quote]Hi group!
s.clive.richards(at)homec
PostPosted: Sun Aug 14, 2011 10:43 am    Post subject: 601 owners... something to watch for - engine mount fittings Reply with quote
Michel
We found the cross channel in the engine compartment cracked on the Left side about 6 years ago on Rays 601 HD with 0-200 when changing Bungee, suspected we had cut off to much material near engine mount, replaced with a thicker channel and carried the L angle above completely across fire wall as noticed they had done this on the XL, have done another 400 hrs since with no problem.
Clive
G CBDG 460 Hrs
carlossa52(at)gmail.com
PostPosted: Sun Aug 14, 2011 11:01 am    Post subject: 601 owners... something to watch for - engine mount fittings Reply with quote
Clive, are you talking about 6F8-2?
Carlos
On 14 August 2011 14:36, Clive Richards <s.clive.richards(at)homecall.co.uk (s.clive.richards(at)homecall.co.uk)> wrote:
[quote] Michel
Clive
G CBDG 460 Hrs
steve.freeman(at)syntaxds
PostPosted: Sun Aug 14, 2011 5:38 pm    Post subject: 601 owners... something to watch for - engine mount fittings Reply with quote
Hi Michel,
Can you post any pictures?
Thank you,
Steve Freeman
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Michel Therrien
Sent: Saturday, August 13, 2011 8:25 PM
Subject: 601 owners... something to watch for - engine mount fittings
Hi group!
mtherr(at)yahoo.com
PostPosted: Sun Aug 14, 2011 6:23 pm    Post subject: 601 owners... something to watch for - engine mount fittings Reply with quote
Right now, not much to take pictures of... I will when I will remove the parts.
From: Steve Freeman <steve.freeman(at)syntaxds.com>
Sent: Sunday, August 14, 2011 9:33:25 PM
Subject: RE: 601 owners... something to watch for - engine mount fittings
Hi Michel,
Thank you,
Steve Freeman
Hi group!
PostPosted: Mon Aug 15, 2011 1:15 am    Post subject: 601 owners... something to watch for - engine mount fittings Reply with quote
Carlos
I donot have the drawing here to check number but pictures attached. before & after replacement .
Clive
 Filesize:  359.01 KB
 Viewed:  5331 Time(s)
 Filesize:  364.44 KB
PostPosted: Mon Aug 15, 2011 9:22 am    Post subject: 601 owners... something to watch for - engine mount fittings Reply with quote
Clive, tx for the pictures !
Carlos
On 15 August 2011 05:06, Clive Richards <s.clive.richards(at)homecall.co.uk (s.clive.richards(at)homecall.co.uk)> wrote:
[quote] Carlos
Clive
paulrod36(at)msn.com
PostPosted: Thu Aug 18, 2011 2:22 pm    Post subject: 601 owners... something to watch for - engine mount fittings Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I guess I've seen one of the blessings of scratch building---I didn't feel comfortable with the mounts built as per plans; maybe a little chicken, but I built my upper mounts of 3/16th inch steel, with double facings, all welded together. Ugly? you bet. Heavy? Yup. Strong? Much more comfortable with that.
Paul R
foxatgibsons(at)gmail.com
PostPosted: Thu Aug 18, 2011 3:27 pm    Post subject: 601 owners... something to watch for - engine mount fittings Reply with quote
hello everyone i cant help but add a few comments  RE: cracked motor mounts
it  looks to me that there may be two issues that may be overlooked
a. there seems to be some irregular bead on the area where the tubes join/undercutting
b.  4130 tubing has a real issue with carbide formation at the HAZone .did the welder pre heat and
    did the welder nomalize  the cluster after the weld process
 knowing that a dh2c beaver motor mount  is made from .035 wall tube and it supports a much larger engine than a subaru
somehow i think the problem may not be just the thickness of the tube
cracks usually form at the end of a weld if the post heat is not applied properly
On Thu, Aug 18, 2011 at 3:17 PM, <paulrod36(at)msn.com (paulrod36(at)msn.com)> wrote:
[quote] I guess I've seen one of the blessings of scratch building---I didn't feel comfortable with the mounts built as per plans; maybe a little chicken, but I built my upper mounts of 3/16th inch steel, with double facings, all welded together. Ugly? you bet. Heavy? Yup.  Strong? Much more comfortable with that.
Paul R
