phactor9
Posted: Sat Aug 13, 2011 6:42 pm Post subject: Welding? |
It's time I bought a welder and learned how to weld; mainly 4130 tubing and other light stock. Could some of you expert welders out there lend a few suggestions?
1. MIG or TIG? I know the difference, I just don't know which is more appropriate for 4130 welding. I'm guessing TIG?
2. How much should I spend on my first welder? I see some $110 boxes out there.
3. Is a 120v unit sufficient?
4. Any other tips and advice would be appreciated!
Phil H.
lcottrell
Posted: Sat Aug 13, 2011 7:11 pm Post subject: Welding? |
The better work is done with a TIG. As a retired welder I can only say "Don't scrimp on your machine" Buy the absolute best you can afford.
Larry
Posted: Sat Aug 13, 2011 7:20 pm Post subject: Welding? |
Phil- A few things come to mind. Anyone with reasonable eye/hand coordination can learn to weld. If you have little or no experience, your local dealer usually gives short introductory lessons. Or, a course at your local tech school, adult education program, or community college will be a great help. Plan on practicing a lot, before trying it for keeps.
Equipment: Harbor Freight has a nice electronic welding helmet for under $50. I got mine with a coupon for $39. Welding machines: Do yourself a favor, and buy a name brand machine- Lincoln, Miller, Hobart, etc. The cheap Chinese made ones may or may not last, and parts will be difficult to find. Visit your local welding supply dealers.
Type: The bulk of my experience is with stick welding, but I used a Lincoln flux core MIG to fabricate a new front cage for my old Firestar. Inside, you can use a gas MIG or a TIG, but if the wind is blowing the shielding gas gives you a hard time. I have no TIG experience. For someone of limited experience, use a good flux core machine. 110v is okay, as the machine will not overheat with the service you will give it.
Clean your materials! Oil, mill scale, or the "soap" preservative will interfere with a good weld. Slag from a torch cut should be ground down.
Get a 110v Dremel tool, with accessories. You will never regret it. Get a 4" or 4 1/2" angle grinder. I have a Ryobi. Got it on sale at Home Depot for $39. Works great. use grinding wheels for shaping, and use "flap" wheels for clean and polish. Remove any slag, both between welds, and after welding.
Practice, practice, and practice. The time and material are never wasted. Remember to wear dark clothing, and welding gloves. Never cool with water! Air cool only, so the steel won't get brittle. You have to play with a machine to know the heat ranges and wire feed speeds.
Good luck, and have fun.
Bill Sullivan
Windsor Locks, Ct.
FS 447
--- On Sat, 8/13/11, Phil <phactor9(at)yahoo.com> wrote:
Subject: Welding?
Date: Saturday, August 13, 2011, 10:40 PM
Phil H.
get=_blank rel=nofollow>http://www.matronics.com/Navigator?Kolb-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
| [quote][b]
DAquaNut(at)aol.com Guest
Posted: Sat Aug 13, 2011 7:23 pm Post subject: Welding? |
I agree with Larry. Also if you get high frequency you will have the capability to weld aluminum.
Ed Diebel FF # 62
In a message dated 8/13/2011 10:11:39 P.M. Central Daylight Time, lcottrell1020(at)gmail.com writes:
| Quote: | The better work is done with a TIG. As a retired welder I can only say "Don't scrimp on your machine" Buy the absolute best you can afford.
Larry
pc.king(at)comcast.net Guest
Posted: Sat Aug 13, 2011 7:24 pm Post subject: Welding? |
Have you considered attending a Sportair workshop? They take place around the country on everything from fabric to welding. The latest one is in Griffin GA on Aug 20/21. It's well worth the $359 price. The $110 welder is not even a player. Check the schedule for a workshop in your geography.
LIMITED SPACE LEFT IN SPORTAIR TIG WELDING COURSE
There's still room left in the EAA SportAir Workshops TIG Welding course being held in Griffin, Georgia, set for next weekend, August 20-21, presented in conjunction with Lincoln Electric and the Alexander Technical Center. Students learn in a state-of-the-art welding workshop with 12 professional welding booths using Lincoln Precision TIG 225 welding units for instruction. Also included is classroom time learning welding basics. Tuition for EAA members is $359 and includes all materials. Register online here or call 800-967-5746. And you can pay class fees in three easy installments with EZ Pay. To learn more about this affordable option, call 800-967-5746 and speak with an EAA member representative.
6.93 KB |
19765 Time(s) |
Richard Pike
Posted: Sun Aug 14, 2011 4:09 am Post subject: Re: Welding? |
I have always used acetylene/oxygen and been very happy with it. Also, the ability to heat and bend stuff comes in handy. OTOH, welding aluminum is reeeely tough...
PS: Remember to demagnetize any joints you weld that are anywhere close to your compass.
Richard Pike
MKIII N420P (420ldPoops)
frank.goodnight(at)att.ne Guest
Posted: Sun Aug 14, 2011 4:18 am Post subject: Welding? |
Hi, Been a welder for most of my life(now 70 years old) used all types of welders.
I belive that for most homebuilders that do only a small amount of welding . The best bang for the buck,
and the easiest to learn and use is oxy acetelean,welds thin wqll 4130 great. If you want to weld alu spend $100.00 for a good set of goggles, and get good flux--hard to find---.If you do those two things alu is easy.
Frank
Sent: Sat, August 13, 2011 9:40:04 PM
Subject: Welding?
Phil H.
[quote][b][b]
Dennis Thate
Posted: Sun Aug 14, 2011 7:51 am Post subject: Re: Welding? |
Practice, Practice, Practice on scrap material until you have it down. Before you weld the real thing. I took a welding course at a local Vo-Tec school and got a certificate.
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern |
Posted: Sun Aug 14, 2011 8:18 am Post subject: Welding? |
oxy-acetylene is the handiest thing in a workshop after the vise and the big hammer.
stubborn nut? heat.
bend and reshape metal
cut stuff off and burn down the shop
All the old airplanes were gas welded until the very last years of tube and fabric.
Very easy: right size tip for the thickness, neutral flame.
I don't recommend flux core wire feed. Good for welding a floor pan into a VW bug but not for airplanes.
the flux remains in some pockets and is corrosive
TIG is without question the very best but too expensive for a hobby.
My last refills lasted for years and only ran out after my last little airplane fix this spring.
My new refills will likely last the rest of my life.
BB
MkIII, suzuki, last flown friday evening
On 14, Aug 2011, at 11:51 AM, Dennis Thate wrote:
Faith is believing what you know ain't so.
Mark Twain
http://forums.matronics.com/viewtopic.php?p=349384#349384
captainron1(at)cox.net Guest
Posted: Sun Aug 14, 2011 5:19 pm Post subject: Welding? |
I bought a cheap one, and found it to be useless. Buy one that has HF spark starter, been a while so I forget the terminology. You want the one that will start the arc without first making contact between the electrode and the work, and you also want the one that has a foot pedal for current control.
A lot of them are stick welders that have a tig tip supposedly as a dual use. Be really careful at buying these if they are not designed for tig they are useless.
Ron (at) FHU
Phil H.
kugelair.com
Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Mon Aug 15, 2011 6:43 am Post subject: Re: Welding? |
If you get a gas welder make sure you get a two stage regulator. My set came with a single stage and it made welding very difficult as the flow was constantly changing. I bought a good two stage and it made a world of difference.
Rex
phactor9
Posted: Mon Aug 15, 2011 7:11 am Post subject: Welding? |
In fact, I found what seems to be a good price for the 0384-2550, which is the Victor Firepower 250 kit - $150 plus a little S/H.
I'm now in the process of looking for a couple of tanks locally; it doesn't make sense to buy them online cause they'll come empty and I'd have to fill them anyway.
But finding tanks locally has been really difficult (yellow pages, local internet...). Still looking. For the 10cf Acet. and 20cf Oxy tanks, I've gotten prices from $169 to $200, with refill rates of $21-27 for Acet. and $12-15 for Oxy.
And I've been watching YouTube videos; how to gas weld and even how to braze aluminum. Seems simple enough... I used to sweat tons of copper in a past life (MAPP gas); 1/2" all the way up to 2", 3" even 4" pipe. I used to do residential/commercial water heaters for a living out in the Bay Area.
Phil H.
--- On Mon, 8/15/11, Rex Rodebush <jrrodebush(at)gmail.com> wrote:
Posted: Mon Aug 15, 2011 7:23 am Post subject: Welding? |
Phil- If you have a local Tractor Supply, they usually have gasses. The regulators that come with the Victor 250 are great.
Bill Sullivan
--- On Mon, 8/15/11, Phil <phactor9(at)yahoo.com> wrote:
Subject: Re: Re: Welding?
Date: Monday, August 15, 2011, 11:08 AM
Phil H.
| [quote][b]
Mike Welch
Posted: Mon Aug 15, 2011 7:33 am Post subject: Welding? |
Phil,
I admit that TIG welding is the best of all, but it isn't very practical for a do-it-yourselfer,
in his garage.
For me, I couldn't imagine not having a wire feed MIG, AND a oxy/acetylene set. There
are just too many things for a guy that needs to fabricate and BOTH are indispensable.
I have a basic two-stage oxy/acetylene welding set. I bought the bottles USED from
my local gas supplier. They came filled!! Don't waste your money on new, because
when you need to go refill them, they'll switch yours out for a used set.
For my wire feed, I have one of those 110v Lincoln units. They handle 99% of the things
I ever need. I also bought the "optional" MIG conversion kit...a VERY worthwhile investment.
Flux cored is 'ok', but the gas adds a big improvement. I got the bottle & gas used, too.
With these two welding set-ups, the torch set and the 110v MIG wire feed, I can weld
or cut about everything I ever need to work on. For really big stuff, I have a 220v Lincoln
stick welder. Beyond that...I go to my local welding shop.
Mike Welch
On Aug 15, 2011, at 10:08 AM, Phil wrote:
[quote]In fact, I found what seems to be a good price for the 0384-2550, which is the Victor Firepower 250 kit - $150 plus a little S/H.
Phil H.
--- On Mon, 8/15/11, Rex Rodebush <jrrodebush(at)gmail.com (jrrodebush(at)gmail.com)> wrote:
| [b]
Posted: Mon Aug 15, 2011 7:44 am Post subject: Welding? |
Mike- Basically, you described the equipment I have here. Same MIG Lincoln, but I don't have the gas add-on. I also have a 220 volt Lincoln "tombstone" AC welder that handles everything else. Good recommendation on the bottles- they switch mine out, too. 1/8" 6013 Lincoln rod handles most stuff you run into, and is not moisture sensative.
Most problems with weld quality are in the skill of the operator. Practice!!!
Bill Sullivan
--- On Mon, 8/15/11, Michael Welch <mdnanwelch7(at)hotmail.com> wrote:
Date: Monday, August 15, 2011, 11:29 AM
Phil,
in his garage.
Mike Welch
| Quote: | In fact, I found what seems to be a good price for the 0384-2550, which is the Victor Firepower 250 kit - $150 plus a little S/H.
Phil H.
| [quote][b]
phactor9
Posted: Mon Aug 15, 2011 7:45 am Post subject: Welding? |
Darn. Tractor Supply! Why didn't I remember that? Just called 'em. Good prices, in stock, initial purchase is reasonable, refills are reasonable...
The guy didn't even wonder what I was talking about; started right in describing what they had and the swap-out procedure/prices.
Always did like that place.
Thank you, Bill - Phil H.
--- On Mon, 8/15/11, william sullivan <williamtsullivan(at)att.net> wrote:
From: william sullivan <williamtsullivan(at)att.net>
Date: Monday, August 15, 2011, 11:21 AM
Bill Sullivan
Phil H.
=nofollow target=_blank>http://www.matronics.com/Navigator?Kolb-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
| [quote][b]
Posted: Mon Aug 15, 2011 8:35 am Post subject: Welding? |
Tractor Supply- the big boys toy store! Love it!
do not archive.
Date: Monday, August 15, 2011, 11:43 AM
Bill Sullivan
Phil H.
| [quote][b]
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Tue Aug 16, 2011 5:00 am Post subject: Re: Welding? |
BEST WELDING ADVICE – Keep a container of cool water within arms length for the inevitable burns. Skin keeps burning after heat source is removed. Immediate dunking into cool water stops the burn and often leaves only the top surface singed with NO blister and NO pain.
Skin needs protection from UV burns, especially with MIG or TIG. Wear a bib to protect your neck area below your helmet or you will live to regret it years down the road.
_________________ Jerry King |
racerjerry
Posted: Tue Aug 16, 2011 6:56 am Post subject: Re: Welding? |
Stick welding and MIG is relatively easy and you can probably learn on your own trough practice before beginning a serious project. As a matter of fact, you might get much more out of a welding course if you already have experimented with the welding process. Of course, you may have to un-learn some mistakes. Reading helps, especially in diagnosing poor welds; but as they say: practice, practice and practice some more before working on anything important. Stick and MIG is kind of like walking a tightrope and juggling with one hand at the same time.
Gas welding adds another dimension. Got to push the ‘bubble’ around and occasionally feed rod – like walking the tightrope and juggling with two hands.
TIG welding adds a third dimension (foot pedal). Got to walk the tightrope, juggle with two hands and a foot and HOP across the tightrope. Seriously, you need all of your gas welding skills down before learning TIG. A trade school should work well to see if you really want to invest in the equipment.
MIG vs TIG
Another aspect is that MIG lays down welding wire rapidly. Too rapid for welding small thin 4130 tubing unless you know what you are dong. Often you can get a good looking weld bead but in reality the bead is just sitting on top with little penetration. MIG is great for stock car roll bars and general welding, is fast, requires little clean-up, is a lot of fun and requires much less skill than TIG. With MIG, I like to weave a bit to get as much heat into the joint as I dare to insure penetration. MIG (&TIG) also has the advantage of being able to join thick materials with thin (difficult with stick or gas welding). In trying to weld small round tubing joints with MIG, you are going to have lots of stops and starts and that is where problems arise.
Because of the extra skills, time and equipment investment required, it would probably be better to gas weld your aircraft project.
John Bickham
Joined: 10 Jan 2006 Posts: 170 Location: St. Francisville, LA
Posted: Wed Aug 17, 2011 5:46 am Post subject: Re: Welding? |
I would suggest:
http://www.weldingtipsandtricks.com/index.html
Look under "TIG" welding section and "Welding 4130" section.
There is a lot of info here. A bit of advertising and products too.
_________________ Thanks too much,
John Bickham
Mark III-C w/ 912UL
I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for. |
