Prop spinner advantages on a pusher ???
AtomicDog
PostPosted: Fri Aug 12, 2011 8:33 am    Post subject: Prop spinner advantages on a pusher ??? Reply with quote
I am working on my firestar and ready to order my prop. However one of the options is for a spinner. My question is, are there any advantages to putting a spinner on a pusher type aircraft. I can see the aerodynamic advantages on a tractor aircraft, but I think these advantages are lost on a pusher.
I do like the looks of a prop with spinner however I am trying to keep the weight down.
Building Firestar II
Dana
PostPosted: Fri Aug 12, 2011 9:09 am    Post subject: Prop spinner advantages on a pusher ??? Reply with quote
At 12:33 PM 8/12/2011, AtomicDog wrote:
--> Kolb-List message posted by: "AtomicDog" <MStudio828(at)aol.com>
A spinner can be as much of an advantage on a pusher as a tractor. There was an article in Ultraflight magazine a year or so ago, a guy put one on his PPC... he reported 5-10% thrust increase, which translates into a similar improvement in rate of climb.
-Dana
Bismark said God looks after fools, drunks, and the United
States.
He didn't say how long the Almighty's patience might endure.
byoungplumbing(at)gmail.c
PostPosted: Fri Aug 12, 2011 9:24 am    Post subject: Prop spinner advantages on a pusher ??? Reply with quote
pusher.
weight down.
what little i have been schooled that in aerodynamics,,,, at least at the
speeds we fly, it doesn't make much difference in how you disturb or open
up the air space,,, but it makes more difference in how you close it,
example: for total drag reduction, a blunt leading edge and tapered
trailing edge, is better or has less drag than a tapered leading edge and
a blunt trailing edge. so the spinner would be better on a pusher than a
tractor, for total drag reduction,,, now as fer purdy,,, that is a whole
different ball of wax.
boyd young
mkiii
utah
Richard Pike
PostPosted: Fri Aug 12, 2011 9:29 am    Post subject: Re: Prop spinner advantages on a pusher ??? Reply with quote
Here's a cheap spinner: a Motorcraft air filter.
If anybody is interested, I'll try and find out the part number, anyway it is plastic and easy to do.
Richard Pike
MKIII N420P (420ldPoops)
 Filesize:  52.03 KB
 Viewed:  17665 Time(s)
 Filesize:  95.64 KB
fs2kolb(at)aol.com
PostPosted: Fri Aug 12, 2011 10:13 am    Post subject: Prop spinner advantages on a pusher ??? Reply with quote
Motorcraft Air Filter FA1632
--> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Richard Pike
Rex Rodebush
PostPosted: Fri Aug 12, 2011 11:50 am    Post subject: Re: Prop spinner advantages on a pusher ??? Reply with quote
When I ordered my Warp Drive prop I asked the guy (don't remember his name) about a spinner and he said it would be for looks only on a pusher. But it seems to me there should be some drag reduction. How much is the question??
Rex
Richard Pike
PostPosted: Fri Aug 12, 2011 2:57 pm    Post subject: Re: Prop spinner advantages on a pusher ??? Reply with quote
[quote="fs2kolb(at)aol.com"]
Hey! I bet that's why that particular picture had the tag it did!
(Facepalm)
Richard Pike
Mic
PostPosted: Fri Aug 12, 2011 4:01 pm    Post subject: Re: Prop spinner advantages on a pusher ??? Reply with quote
Good idea Richard.
I suspect from previous experience with boat hulls being designed for optimum benefit as the water passes aft of the greatest beam, that aircraft would experience a similar benefit as they move through the air. A quick review of leading and trailing edge wing design would probably show this quite clearly.
I like the simple solution of this suggestion as well. After all it's not quite rocket science is it?
Mic
"It is far better to grasp the universe as it really is than to persist in delusion, however satisfying and reassuring."
— Carl Sagan
"Education is not filling a bucket, but lighting a fire."
— W.B. Yeats
pj.ladd(at)btinternet.com
PostPosted: Sat Aug 13, 2011 12:38 am    Post subject: Prop spinner advantages on a pusher ??? Reply with quote
I am sure that my wife has a plastic bowl of about the right shape and
dimensions in the kitchen (Not an area of the house with which I am
familiar)
Cheers
Pat
Thom Riddle
PostPosted: Sat Aug 13, 2011 2:55 am    Post subject: Prop spinner advantages on a pusher ??? Reply with quote
Pat,
Do you mean to say that your wife does not allow you to enjoy cooking, not to mention the satisfaction derived from washing dishes? That is mean of her.
Do not archive.
Thom in Buffalo
On Sat, Aug 13, 2011 at 4:35 AM, Pat Ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote:
[quote]--> Kolb-List message posted by: "Pat Ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
I am sure that my wife has a plastic bowl of about the right shape and dimensions in the kitchen (Not an area of the house with which I am familiar)
Cheers
Pat
http://forums.matronics.com
le, List Admin.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
frank.goodnight(at)att.ne
PostPosted: Sat Aug 13, 2011 5:32 am    Post subject: Prop spinner advantages on a pusher ??? Reply with quote
Morning Richard,
I'm interested in a cheap spinner.Was thinking about a high priced one.cheap is better.
Frank
Sent: Fri, August 12, 2011 1:10:35 PM
Subject: Re: Re: Prop spinner advantages on a pusher ???
Richard Pike
[quote][b][b]
David d.
PostPosted: Sat Aug 13, 2011 5:54 am    Post subject: Re: Prop spinner advantages on a pusher ??? Reply with quote
Just walk thru walmart, dollar store etc.. There are plenty of plastic shapes that would make a spinner. But how is it to be attached to the hub?
And some of these plastics degrade in a year or so.
David d.
PostPosted: Wed Aug 17, 2011 10:09 am    Post subject: Prop spinner advantages on a pusher ??? Reply with quote
Do you mean to say that your wife does not allow you to enjoy cooking, not to mention the satisfaction derived from washing dishes? >.
Not only that. I make a point not to deprive her of scrubbing the floors, cleaning the windows or carrying the logs in (and chopping them)
Pat
captainron1(at)cox.net
PostPosted: Wed Aug 17, 2011 7:01 pm    Post subject: Prop spinner advantages on a pusher ??? Reply with quote
Hey Pat does your wife have a sister? I may be interested in taking her off your hands if she hangs around your house and on your dime (quids), hard to find good broads in Arizona you know.
Ron (at) KFHU
Pat
kugelair.com
PostPosted: Thu Aug 18, 2011 12:44 am    Post subject: Prop spinner advantages on a pusher ??? Reply with quote
Hi Ron,
Yeah she does but I can`t let her go. Who would feed the stock and drive the
mule?
Cheers
Pat
williamtsullivan(at)att.n
PostPosted: Thu Aug 18, 2011 3:17 am    Post subject: Prop spinner advantages on a pusher ??? Reply with quote
Ron- Where are you in Arizona?
    Bill Sullivan
Date: Wednesday, August 17, 2011, 10:59 PM
--> Kolb-List message posted by: "Ron (at)  KFHU" <captainron1(at)cox.net (captainron1(at)cox.net)>
Ron (at) KFHU
Not only that. I make a point not to deprive her of scrubbing the floors, cleaning the windows or carrying the logs in (and chopping ww.matronics.com/Navigator?Kolb-List" target=_blank>http://www.matronics.========================
PostPosted: Thu Aug 18, 2011 6:27 am    Post subject: Prop spinner advantages on a pusher ??? Reply with quote
You got a point there, it was a long shot.
Ron (at) KFHU
Hi Ron,
mule?
Cheers
Pat
kugelair.com
PostPosted: Thu Aug 18, 2011 6:34 am    Post subject: Prop spinner advantages on a pusher ??? Reply with quote
I am in ( KFHU) Fort Huachuca / Sierra vista.
Ron (at) KFHU
                                   Bill Sullivan
Ron (at) KFHU
Pat
kugelair.com
le, List Admin.
kugelair.com
