carlossa52(at)gmail.com Guest
Posted: Fri Aug 05, 2011 7:02 am Post subject: polisher + accessories |
Hello, allI am thinking of ordering this polisher: http://www.aircraftspruce.ca/catalog/cspages/polishers.php What are the recommended accessories? Thanks in advance for your commentsCarlos CH601-HD, plans
Larry Webber
Joined: 05 Jun 2008 Posts: 63 Location: West Kingston Rhode Island
Posted: Fri Aug 05, 2011 7:37 am Post subject: polisher + accessories |
Hi Carlos Nuvite sells the same dual item for about 100.00 less
Larry
Date: Fri, 5 Aug 2011 10:56:58 -0400
Subject: polisher + accessories
Hello, allI am thinking of ordering this polisher:http://www.aircraftspruce.ca/catalog/cspages/polishers.phpWhat are the recommended accessories?Thanks in advance for your commentsCarlosCH601-HD, plans
target=_blank>http://www.matronics.com/Navigator?Zenith-List
ttp://forums.matronics.com
=_blank>http://www.matronics.com/contribution
_________________ how do you eat an elephant ? one bite at a time |
pmaxpmax(at)HOTMAIL.COM Guest
Posted: Fri Aug 05, 2011 8:26 am Post subject: polisher + accessories |
I have a Nuvite polished plane which is not intended to be an Oshkosh show winner, but the polish job does look nice. I have two main tools I use: 1) A grinder/polisher with 7" wool polishing pads attached by velcro, and 2) A Craftsman orbital polisher from Sears that I use with left-over flannel cloth. This orbital polisher is much cheaper than the one Nuvite recommends (the one you are looking at). Here are the steps I used to take the 6061 aluminum from the dull factory finish to bright:
1. Wet sand with 1000 grit sand paper
2. Wet sand with 1500 grit sand paper
3. Polish with grinder/polisher and wool pads using Nuvite "C" grade polish (repeat as necessary)
4. Polish with the orbital polisher and flannel using Nuvite "S"
5. Clean between stages with Nuvite Nuimage cleaner.
Your mileage may vary.
Phil Maxson
601XL/Corvair
Northwest New Jersey
jlatimer1(at)cox.net Guest
Posted: Fri Aug 05, 2011 9:11 am Post subject: polisher + accessories |
Carlos,
I have a polished 601 HDS. I used the method outlined on the Nuvite web site for polishing aluminum. I used a polisher that I purchased from Harbor Freight tools.
http://www.harborfreight.com/7-inch-variable-speed-polisher-sander-92623.html
I purchased the wool pads from Nuvite.
For the finish polish steps I used another polisher from Harbor Freight Tools.
http://www.harborfreight.com/10-inch-random-orbit-waxer-polisher-43424.html
Like Phil, I used flannel cloth that I purchased from a fabric store. Be careful here not all flannel is really soft. You need to feel the flannel and select the softest that you can find.
I'm sure the polisher that are looking at will do the job, but there are cheaper ways to do it.
Hope this helps
Jerry
601 HDS 912
http://www.zenith.aero/photo/my-second-passenger-1?xg_source=activity
aprazer
Posted: Sat Aug 06, 2011 12:20 pm Post subject: Re: polisher + accessories |
Greetings,
I've used Cyclo Polishers going on 40+ years. Very durable - haven't worn one out nor sent one back to the factory for a rebuild.
Factory sez they'll upgrade mine for a nominal fee, by why fix something that isn't broken?
Try E-Bay for a used one.
Mack
_________________ The poh-oh-unemployed farm boy from Idaho |
