chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Fri Jul 29, 2011 5:50 pm Post subject: AOA with Dynon |
Hi
Has anyone successfully used their original Zenith supplied Static probe to get the Dynon D100 Angle of Attack indication to work?
And if you did how did you do it and what angle was it bent down to??
Or do you have to bite the bullet and buy Dynon's Unheated probe????
Chris..
don.honabach(at)pcperfect Guest
Posted: Sat Jul 30, 2011 2:38 pm Post subject: AOA with Dynon |
Chris -
I'm using Dynon's Unheated Probe for the AOA on my D180. Works well. Never tried the ZAC one.
Don
Alan Smith
Joined: 10 Jan 2006 Posts: 12 Location: Anderson, Missouri
Posted: Sun Jul 31, 2011 1:26 pm Post subject: Re: AOA with Dynon |
You must have twp pressure ports for the angle of attack to work.
There is a drawing on the Dynon web site that may help.
AL Smith
_________________ alschief |
merlin
Joined: 05 Oct 2008 Posts: 15 Location: Fair Play, S.C.
Posted: Sun Jul 31, 2011 1:55 pm Post subject: Re: AOA with Dynon |
Check with Gus at "flywithgus.com" or call him.
I've seen a video on how he does this with the supplied pitot tube. It may be on the EAA website.
chris Sinfield
Posted: Wed Aug 03, 2011 1:32 am Post subject: Re: AOA with Dynon |
anyone got a good Email address as his "flywith gus" one just bounces back?
Chris
Ron Lendon
Posted: Wed Aug 03, 2011 6:58 pm Post subject: Re: AOA with Dynon |
Chris,
The angle of attack uses two pitot pickups, one is straight into the wind, the other is at a forty-five degree angle to the wind. The hole sizes are the same ( tube ID ) and it works by pressure differential. You can add a tube to the straight tube as long as you bend the new tube so the end is presented to the wind 45 degrees away from the original tube.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
chris Sinfield
Posted: Thu Aug 04, 2011 5:03 am Post subject: Re: AOA with Dynon |
So Ron
if I bend the bottom tube of the Zenith probe down 45 Deg and use another static vent source from the fuse sides then it should work if connected to a Dynon?
Chris
psm(at)att.net Guest
Posted: Thu Aug 04, 2011 5:38 am Post subject: AOA with Dynon |
Hi Chris,
I have a Lift Reserve Indicator (LRI) I built while waiting for one of
my sub-kits to arrive. It seems to work in a similar fashion to the
Dynon AOA. It uses a metal divider to choose which of two input ports
gets the larger amount of air pressure - depending on the attitude of
the airplane. Rather than having one direct pitot tube and one at a 45
degree angle it has one input pointed up and another pointed down.
I mentioned all that to allow me to point out that the idea works just
fine but the actual implementation needs to be adjusted and calibrated
to be useful in flight. I have an analog gauge that shows the
differential pressure. Dynon just shows a few points of data which
(presumably) show similar information. You might need to tweak the
angle of the second pressure input tube to get a reading on the Dynon
that is useful.
Paul
Camas, WA
On 8/4/2011 6:03 AM, chris Sinfield wrote:
| Quote: | So Ron
Chris
mcr01steiner(at)mac.com Guest
Posted: Thu Aug 04, 2011 6:56 am Post subject: AOA with Dynon |
Sam Buchanan successfully used a different pressure source for the Dynon AOA indicator:
http://www.vansairforce.com/community/showthread.php?t=36346
How to build your own is described here, ( I think this is the one Paul is referring to):
http://www.pegazair.on-the-net.ca/ClareSquared/pictures/airframe/lri.htm
It seems a similar probe with only the lower port, mounted at an appropriate location, should work with the Dynon.
Christoph
| Quote: | --> Zenith601-List message posted by: Paul Mulwitz <psm(at)att.net (psm(at)att.net)>
Hi Chris,
I have a Lift Reserve Indicator (LRI) I built while waiting for one of my sub-kits to arrive. It seems to work in a similar fashion to the Dynon AOA. It uses a metal divider to choose which of two input ports gets the larger amount of air pressure - depending on the attitude of the airplane. Rather than having one direct pitot tube and one at a 45 degree angle it has one input pointed up and another pointed down.
Paul
Camas, WA
| Quote: | So Ron
Chris
Ron Lendon
Posted: Fri Aug 05, 2011 5:32 pm Post subject: Re: AOA with Dynon |
| chris Sinfield wrote: | So Ron
Chris |
Yep!
CH 601 XLB
N601LT - Flying
alsmith
Posted: Fri Aug 05, 2011 6:06 pm Post subject: Re: AOA with Dynon |
It takes two Ram Air inputs and one static
